Old 23rd May 2008, 17:20   #106
Hi Sajan, congrats on your new car.
I would like to know how you are driving the car during the run-in period. Let me know as I am upgrading from Indica non-turbo to Verna VGT.
I always used to keep the engine in idle mode for 3 minutes before starting from home to office and vice versa. This would make the engine smooth and better pickup. The hyundai dealer mechanic told for any diesel car this is a good practice. So let me know if such a thing is needed in Verna.
girish.r is offline   Reply With Quote
Old 23rd May 2008, 19:14   #107
bblost's Avatar
Thanked: 6,980 Times
Idling for a minute after switching on and before switching off is a good practise.
For a car with Turbo it is not only a very good but rather an essential practise
Old 23rd May 2008, 20:42   #108
sajands's Avatar
Thanked: 144 Times
Hey girish.r.,
Thanks. I do keep the car idle for 2 mins atleast at the first start up after that, at the traffic signals, depending upon the duration, i switch off the car and then when the counter reaches 15 I start the car the leave it to idle.
Only after i crossed 500Kms, I turned on the AC till then did not switch the AC on. So far the car is smooth and pick up is too good. love to see the other cars as a dot in the rear view mirror
Waiting to finish 1000kms after which planning to post a detailed initial ownership report with pics.
Sajan.
sajands is offline   Reply With Quote
Old 23rd May 2008, 20:56   #109
Originally Posted by sajands View Post
Hey girish.r.,
Sajan.
Sajan, thanks for the info.
Please update on the RPM at which you are changing the gears and also in-gear speeds.
Thanks & Regards,
Girish
Old 25th May 2008, 19:03   #110
jeetu4444's Avatar
sajan putting some snaps with fogs light on and off
My view on Verna CRDi+ABS coming soon. EDIT : Advait Hyundai backs out of commitment-24052008001.jpg
My view on Verna CRDi+ABS coming soon. EDIT : Advait Hyundai backs out of commitment-24052008002.jpg
My view on Verna CRDi+ABS coming soon. EDIT : Advait Hyundai backs out of commitment-24052008003.jpg
jeetu4444 is offline   Reply With Quote
Old 27th May 2008, 13:49   #111
sajands's Avatar
Thanked: 144 Times
Hey Girish,
Thanks for the Pic's. well, I still have not crossed above the 3000rpm mark, changing gears within 2500 rpm.
Your car's fog lights looks better than mine, looking at your pics, you can atleast see that the fog lights are switched on, in mine i cant see even that. did you do any modifications to the fog lights??
Sajan
Old 27th May 2008, 20:22   #112
Awaiting Email Confirmation
Thanked: 20 Times
Thanks & Regards,
Girish
for city, heavy traffic driving, i.e bumper to bumper,
best to upshift really really early and let the idling engine carry you around. it does a good job in 3rd gear at idle.
basically upshift in bumper to bumper at1600rpm or so.
watch out for the ECU instructing the car to move forward rapidly at very low rpms if the car is about to stall(hope I made sense with that statement)
it takes some learning to actually drive the car smoothly in heavy traffic. but once you pick it up, its heaven.
for mileage - best to upshift at 2200 -2500
for pretty scary acceleration- upshift at 3500-4000rpm
try that on highways and clear roads only or when you are drag racing with overpriced petrol sedans
if your breaking in the engine- dont take it beyond 2500rpm.
dont know if the breaking in process is really reqd, but I did it any way, just to be safe.
BTW- if you're looking at the tacho- dont bother looking at the speedo.
you dont have time to look at both, the way this car takes off.
Old 27th May 2008, 20:30   #113
sajands's Avatar
Thanked: 144 Times
Hey rippergeo,
Thanks for the input. One question, can you tell me what's the exact use or should i say what can I connect into the 12V socket??? can i connect Laptop or a cell phone.
Sajan
Old 27th May 2008, 22:30   #114
Thanked: 20 Times
Hey rippergeo,
Sajan
its best not to use the 12volt outlet to charge any costly electronics, unless you have no other option.
screws up the device batteries sometimes.
inspite of that risk, I myself use it to charge my cellphone and Ipod while travelling.
Hyundai does offer a car inverter as an accessory which is supposed to make things easier and safer, but I have no reviews of it, neither have I seen it in action.
Old 28th May 2008, 19:45   #115
hellstar's Avatar
Thanked: 17 Times
Hey rippergeo,
Sajan
I have used the invertor from AXIOM which is being promoted by the Hyundai A.S.S in blore. It works fine in an emergency situation, although i havent had any long term issues with using the invertor of the 12v port. I have run the Lpatoo, Digi cam charger and even a small amplifier off this invertor...
hellstar is offline   Reply With Quote
Old 28th May 2008, 20:49   #116
sajands's Avatar
Thanked: 144 Times
Hey Hellstar,
Which invertor from AXIOM do you use, the 75w or the 120w??? and by using this does it affect the battery and how much did it cost you and which A.S.S did you pick it up from. sorry for long questions.
Sajan
Old 29th May 2008, 11:16   #117
hellstar's Avatar
Thanked: 17 Times
Hey Hellstar,
Sajan
Its the 150W one i believe there is also a 300 W one available but i didn't foresee any use for it at the moment...
Old 29th May 2008, 13:59   #118
sajands's Avatar
Thanked: 144 Times
Is it ok to use the 150w in a 120w socket???? and normally does it strain the battery??? while you connect the laptop while the car is not moving.
Sajan
Old 29th May 2008, 15:50   #119
hellstar's Avatar
Thanked: 17 Times
Sajan
Oh my god if the socket is 120 w then i would have already blown my fuse when i ran the 150 W amp from that socket , but It didnt ...anyways i have to get this checked out if its 120 W then better stick to the numbers
The View on your Rear-View (Pictures taken through your rear view mirrors) Pri2 Shifting gears 127 12th February 2017 10:53
Ford Fiesta Diesel Zxi Vs Hyundai Verna Crdi Sxi ABS aks_karthik Sedans 146 7th July 2011 10:52
My Hyundai Verna Crdi SX with ABS pras.oct25 Test-Drives & Initial Ownership Reports 285 27th June 2010 12:49
Hyundai Verna CRDI (SXI) with ABS rippergeo Test-Drives & Initial Ownership Reports 143 6th September 2009 17:58
Coming soon.. the Automatic Verna!! EDIT : Now here! V-16 The Indian Car Scene 54 9th February 2009 02:16
