Old 24th May 2008, 12:22   #31
extreme_torque's Avatar
Thanked: 1,489 Times
There is only a slight difference in the specifications.
Swift has 75 bhp and 190 Nm of torque.
Palio has 73.9 bhp (75 PS) and 184 Nm of torque.
Manufacturers in India often use PS and BHP's interchangeably.
extreme_torque is offline   Reply With Quote
Old 24th May 2008, 12:30   #32
CrAzY dRiVeR's Avatar
Thanked: 19,908 Times
Originally Posted by AadiAtPlay View Post
Of course that is true and that is why reversing the rear wheel will make a tighter turn but why is it so painfully obvious on a Palio and not on other hatches?
Low turning radius and comparatively long wheel base.
Anyways, it obvious in other cars too. There was even an ad of WagonR where a guy reverse parks into a very small gap.
My Guess (and i could be horribly wrong here): Could it be that the Petra was designed first and then boot chopped of get the Palio instead of the other way round (as in swift/dezire indica/indigo may be)
Sienna was introduced as the booted version of the Palio.
Old 26th May 2008, 11:29   #33
thanks for the correction. My question is more like chicken and egg what came first Sienna or Palio?
did some research
Palio
Wheelbase - 2373
Turning Radius - 5.1m
(Palio does not mention front/rear track)
Source: Fiat India :: Showroom : Palio Stile Multijet
Swift
Wheelbase - 2390mm
Turning Radius - 4.7m
Front Track - 1,470mm
Rear Track - 1,480mm
Source: Maruti Swift - Specifications Diesel
How is a longer wheel base in the swift account for a shorter turning radius?
is it something to do with the front track being smaller than the rear track?
(An extreme example would be an auto rickshaw ; front track is zero and is very maneuverable, no offense meant to the swift only trying to bring forth a point )
I guess the steering system should also play a factor, right?
AadiAtPlay is offline   Reply With Quote
Old 26th May 2008, 12:24   #34
As per Wiki, seems Palio made it first.
If you drive an auto rickshaw, you'll realize that the handles turns all the way to almost 90 degrees. Seriously freaky, considering a bikes handle doesn't go more than half as much.
So much so that, in full lock, the handle is almost in between the legs of the driver.
Old 26th May 2008, 16:22   #35
Thanked: 36 Times
That is the reason for auto rikshaw being highly unstable during turns done at speeds. It topples over like a toddler out of balance
did some research
Palio
Wheelbase - 2373
Swift
Wheelbase - 2390mm
I feel it more of the steering than anything, the Swift could have the front wheel axle turn a 1/4" more at full turn than the Palio leading to a shorter turning radius.
Last edited by Technocrat : 27th May 2008 at 15:42. Reason: Please use Multi Quote option
zaks is offline   Reply With Quote
Old 27th May 2008, 15:23   #36
Yes, true. But i dont think its a mistake here. Specially because of almost 2 sec difference in the 0-100 timings.
Figo TDCi Titanium Vs Punto MJD Emotion Pack - 2 Diesel cars, 1 buyer - Tough Choice rahulmd Test-Drives & Initial Ownership Reports 103 20th May 2014 16:58
Finally finally finally finally... s4ch Introduce yourself 3 29th March 2012 19:44
My Story of Going from Petrol (Palio 1.1) to Diesel (Palio MJD) ant_vas Test-Drives & Initial Ownership Reports 13 8th November 2010 14:28
Indica Vista MJD vs Palio MJD vs Swift DDiS greenhorn The Indian Car Scene 452 24th April 2010 18:11
Palio 1.6 Sport Vs Palio MJD- pure economics zaks The Indian Car Scene 11 17th March 2008 14:22
