Old 16th September 2010, 22:32   #196
JVH
JVH's Avatar
Thanked: 148 Times
Originally Posted by lohithrao View Post
AM not sure about that, as per am aware if you need to change the strut then its recommended to change both but lower arm i dont think so. the right arm in my car was weak for sometime and i have ben pushing it
Aah! my bad, I misunderstood that you would also be changing the strut.
On kms i meant after you picked the car?
16,000 kms
JVH is offline   Reply With Quote
Old 17th September 2010, 09:54   #197
lohithrao's Avatar
Thanked: 163 Times
Jayant, so you are changing both struts with the lower arms? how about the rare struts?
What a coincidence even i have done about 16k+ kms after i picked the car
meanwhile whats the total kms on the odo now?
lohithrao is offline   Reply With Quote
Old 17th September 2010, 10:00   #198
JVH
JVH's Avatar
Thanked: 148 Times
Rear struts do not have a problem. According to mechanic's assessment, they can run another 7-8k kms and I sure can save some bucks by postponing them.
It sure is a coincidence. The odo now reads 85,8XX kms.
Old 17th September 2010, 10:43   #199
planet_rocker's Avatar
Thanked: 368 Times
Jayanth - rear struts donot require change unless its almost toast - rear load is less most of the time (under normal wear and tear)
I picked up my car in March 2008 when the odo read 43,4** Kms and now as on date it reads 54,8**kms. Its is my daily ride - but the average distance covered per day is at most 10kms
Lohith - it is a very good idea to share price figures with Jayanth since both you guys are changing suspension parts at the same time.
take care.
planet_rocker is offline   Reply With Quote
Old 17th September 2010, 10:56   #200
lohithrao's Avatar
Thanked: 163 Times
Yes the rear struts hold up longer, i presume the damage to you pocket should be around 14k? including both the lower arms??
Old 17th September 2010, 11:01   #201
JVH
JVH's Avatar
Thanked: 148 Times
Thats what the mech told me but also insisted on a check after 8k kms.
Buddy - You've got to take it to the highway
No Idea, honestly. I have to check with him this weekend.
Old 17th September 2010, 11:10   #202
Thanked: 368 Times
Yes i did twice - but the distance from my house to the destination were:-
186Kms and 53kms respectively. Oh! also the small highway drives to a Highway Dhaba on NH6. but then thats about it.
Old 17th September 2010, 11:21   #203
lohithrao's Avatar
Thanked: 163 Times
Surya i agree, also if your usage is mostly city then the suspension related issues are much lesser compared to the hiway usage. in my case where the car as seen mostly hiway with lots of bad roads added with some hi-speed driving, i did expect the suspensions to give up. however considering the car had run some good amount of kms am pretty impressed with the quality....
Old 17th September 2010, 14:01   #204
thalavoy's Avatar
Thanked: 62 Times
thalvoy am a bit confused with your question:
When you turn the ignition key on(1st) the injector light glows for a moment and goes off this is when the fuel pump gets activated and even can hear a slight sound when its on. but for the first time when you turn the engine on the duration of this process is longer, after you have done some kms it tends to get shorter.
but as far as i can see from your query it seems to be normal to me...
No. I get the check injector light after some time. I make sure I start the car only after this light goes off. When running in cold conditions (early morning or late evening) the light came on (2 or 3 times so far). The temperature needle would be stuck at the min mark.
Anyways, took the car to Raj Motors in bellandur (near to my home + TASS didn't have any slots this week + I had to travel this weekend). They thought it could be because of bad spark plugs. Mine were bad (as they said - the distance between the electrodes were quite far compared to new ones) and the light could come one to say the sparks were not strong enough. Believable? I will check and monitor with the new spark plugs and take it back in case the light comes on again like before.
Looks like lower arm assembly replacement season Looks like my right side is 'weak' and might need replacement. As of now, no need to change.
thalavoy is offline   Reply With Quote
Old 18th September 2010, 19:36   #205
JVH
JVH's Avatar
Thanked: 148 Times
Lohith, I forgot to ask you the individual cost of each lower arm? And what make?
I just got the job done today and its looking expensive :-(
@Surya - The excel you have attached are for Stile models. Is there a similar table for the pre-Stile models?
Old 18th September 2010, 21:25   #206
lohithrao's Avatar
Thanked: 163 Times
Default Back from Service...
Firstly let me talk about how the car feels post service,
Earlier the car used to shudder a bit at lower rpm now this seems to be have taken car though i dint mention it to SA, not sure what was the issue?
Car has got real smooth, the acceleration is fine and at ilde the car feels much smoother.
post lower arm change dont hear any unusual noise..
Damage to the pocket 9k
WIll post up the lower arm pics tomorrow...
Old 19th September 2010, 19:49   #207
lohithrao's Avatar
Thanked: 163 Times
Default Short drive and car feels good...
Driving around mangalore means a good mix of winding roads and the some straights and not to forget bad roads, i guess whichever way you head you will come across a good % pf stretch which will be bad. i really pity those low gc cars!
Adventure wont show any stress while while climbing up and this time the engine seemed to be very refined. at idling i felt the car is more relaxed but i guess i need to get the alignment done.
Old 20th September 2010, 12:41   #208
lohithrao's Avatar
Thanked: 163 Times
Default Temp Check
Question
Am putting down the representation of the needle position of the temp gauge.
1. when on highway or free road.
2. In city condition and slow moving traffic(w/o AC)
3. Very slow moving traffic, 1/2 gears and with AC (W AC)
Now what you guys think?
Old 20th September 2010, 14:29   #209
JVH
JVH's Avatar
Thanked: 148 Times
I do get case 3 occassionaly and the only solution I have used is - clean the radiator with water spray
Your problem could be as simple as mine. Try this and let us know.
Case 1 and 2 are normal.
Old 20th September 2010, 14:31   #210
Thanked: 368 Times
1 = OK
2 = OK
3 = Looks Ok, if restarting in stop-go traffic - shouldn't happen when idle. Fan should switch on when needle reaches half mark. Abnormal if with AC
Did you check the position at which fan switches on when idling?
+ 1 to JVH - Better clean with compressed air first and then pressure wash. I haven't used water in the engine bay since last 5000kms - only used compressed air to clean the engine bay / radiator.
Reference Threads: Check my posts - post number 27 in the first link. Also vipul's post.
http://www.team-bhp.com/forum/techni...re+doubt+palio (Palio 1.6 Sport Temperature doubt)
http://www.team-bhp.com/forum/techni...re+doubt+palio (Palio stile 1.6 overheating issues)
Embarking on an Adventure: My pre-owned Fiat Adventure Samar117 Test-Drives & Initial Ownership Reports 44 28th December 2017 21:26
Honda recalls 3,879 units of the City CVT - Updated software to optimize CVT hydraulics ashwin.terminat The Indian Car Scene 6 27th October 2015 16:57
Honda City Vtec-20000 km report - updated to 61500km ajmat Long-Term Ownership Reviews 185 15th March 2014 12:46
Any News of an updated Adventure 1100D The Indian Car Scene 10 11th June 2007 19:23
help me decide-palio sport or adventure sport 1.6 for city driving premchetan Hatchbacks 46 9th February 2007 17:44
