Old 18th August 2008, 12:30   #1
no_boundaries's Avatar
Thanked: 99 Times
Default Engine Tuning for Swift VXI for better FE
Hi,I purchased my first petrol car - Swift VXI 1 week ago and I LOOOVE this car's feel and response (compared to other petrol cars too). My previous car was an Indica DLS and it used to give me a mileage of 15-16KMPL in bangalore peak hour traffic conditions.
Now since my new car is much powerful than the old one and runs on Petrol.
I have 2 issues.
1. I have enormous power and low mileage
2. High cost of fuel that relates to Low mileage.
Apart from optimum driving conditions and practices I would like to know if there are any modifications that can be done to improve FE without affecting the power and the warranty from MUL.
I've heard from a friend that there is a workshop in Kormangala Bangalore where a guy who used to be a Rally driver is into tuning engines and is a specialist in Swift engines.
If any of you know this guy I would love to get some reviews on this guy and his service. Since its a new car I'm a little sceptic in letting unknown people get their hands in the hood.
Note from mod: Do not use FONT or SIZE Tags
no_boundaries is offline   Reply With Quote
Old 18th August 2008, 15:41   #2
.anshuman's Avatar
Thanked: 9,159 Times
What are fuel consumption figures? MASS is the best place to get the issue sorted.
Old 18th August 2008, 15:45   #3
jkdas's Avatar
Thanked: 1,436 Times
Try changing your driving style.
I have seen that Swift get more kpl when driven at high speeds on highway. In city you will need to rev it to keep it moving as it has bad low end torgue.
Better air filter and header job should help increase low end grunt.
Old 18th August 2008, 15:55   #4
Thad E Ginathom's Avatar
Thanked: 8,377 Times
After being used to a diesel the cost of driving on petrol must be really shocking!
I too feel that tuning is not the answer. Make your driving as utterly boring as you can: that's the way to spend less on fuel!
Old 18th August 2008, 16:21   #5
plz keep the RPMS below 2000
shantyrocks is offline   Reply With Quote
Old 18th August 2008, 16:47   #6
yzfrj's Avatar
Thanked: 119 Times
Hmmm... Is't it a bit too early to worry ?
Its just one week right ? and assuming that its a new car, give it some time like till 2nd service is over so you can actually comment about the FE.
In a new car the FE will the low, new parts more friction something like that...
How much is you FE now ?
If its a new car, let it "run-in" and then if you feel its bad look into it.
As its suggested here,
1. Changing driving style
2. After market air filter
3. Slight over inflation of tyres (not recommended in wet)
4. Switching off engine at lights.
5. Not running A/C at full blast.
6. Headers (Yup anything which increases efficiency in theory should improve FE)
I don't think its really fair to comment about the mileage of a brand new car that has not even been serviced.
yzfrj is offline   Reply With Quote
Old 18th August 2008, 22:12   #7
.anshuman's Avatar
On my first 500kms i got 17kpl highway ~90kmph absolutely no pushing but now under some condition it easily returns 20kpl.
Old 18th August 2008, 22:19   #8
CtrlAltDel's Avatar
Thanked: 24 Times
are you sure you are talking about the Petrol Swift?
CtrlAltDel is offline   Reply With Quote
Old 18th August 2008, 22:22   #9
.anshuman's Avatar
I am so sorry,i forgot to mention its a diesel and its mentioned in my signature.
Old 18th August 2008, 22:26   #10
senindra's Avatar
You are talking about VXI or VDI ?
senindra is offline   Reply With Quote
Old 18th August 2008, 22:33   #11
.anshuman's Avatar
Ive made it clear in Post no. 9 ,its VDi ABS.
Old 19th August 2008, 01:06   #12
theMAG's Avatar
Thanked: 1,574 Times
.. I would like to know if there are any modifications that can be done to improve FE without affecting the power and the warranty from MUL.
Do not get swayed by any marketing content that claims to be a miracle cure for mileage. The only thing they would probably end up doing is to ruin your engine in the long term and leave you feeling silly about that purchase later on.
Also, since you've only just got the car, defer judgement till the 2nd service after which the mileage would have picked up.
Everything does finally depend on how you run it in, how well you maintain it and your driving style.
Old 19th August 2008, 13:59   #13
Thanked: 103,710 Times
If FE is your aim, there simply isn't a modification or tune job that is as effective as a conservative driving style. Please read our article on FE (ARTICLE: How to get the maximum Fuel Efficiency) to extract the most FE of your car.
Old 19th August 2008, 14:32   #14
Thanked: 53 Times
If you are comparing the mileage with a diesel car, a diesel in inherently efficient engine, By the way what figure are you getting on the petrol swift.Let it run in properly first than look into the efficiency part of the engine.
Also it is hard to get use to the difference in prices of petrol and diesel fuel, and since you have been using an Indica that will be the main reason that you feel the mileage is low..when you go to a fuel station. as you pay more per km for the same distance covered in the old [diesel] car and the new [petrol] car.
dinar is offline   Reply With Quote
Old 19th August 2008, 14:57   #15
watashi75's Avatar
Some of the ways to improve FE that I can think of -
1. Use large diameter low profile narrow tyres for improving FE. However it will reduce the low end torque further.
2. Make the body more aero-dynamic, remove ORVMs (many people in Hyderabad do that).
3. Stiffen up the suspension
4. Reduce car weight by removing back seats, spare tyre etc.
5. Keep mimimum fuel. Full tank means an extra 30-40 kgs.
6. Use parking lights instead of headlights if street lights are bright
7. Reduce idling rpm
watashi75 is offline   Reply With Quote
Tuning Box versus Remaps (Diesel tuning) Ravveendrra Modifications & Accessories 154 29th April 2018 22:45
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
swift-vxi,logan-dlx,esteem-vxi which one is better ???? uvais Hatchbacks 4 17th October 2007 10:17
Swift vxi or Esteem vxi ? bsm3477 Hatchbacks 11 15th October 2006 13:38
The Dawn of Turbo Diesel Tuning in INDIA - Pete's Tuning Box turboindia Modifications & Accessories 108 17th April 2006 12:33
