| Test-Drives & Initial Ownership Reports First hand enthusiast reviews of test-driving and owning (initial stages) an Indian car |
| | Thread Tools |
| | #61 (permalink) | |
| BHPian | Quote:
Hope they dont change it to JK by the time the car gets delivered ![]() | |
| | #62 (permalink) |
| BHPian Join Date: Apr 2008 Location: Trivandrum
| Quite unlikely that they do that(change to JK)-nevertheless an upgrade to wider tyre's are necessary ie from 165 to atleast 185 section. There is some confusion regarding 195 section tyres being mounted on the standard 5J rims-tyre walla saying that it can be done(obviously-business!) and 'gurus' saying it can be done but should not be. I do touch 140kmph regularly and the XM1+ are a revelation. |
| | #63 (permalink) | |
| BHPian | Quote:
| | #65 (permalink) | |
| BHPian | Quote:
Car: Dzire VDi Car would be ready by Saturday by wife/mom are stating that the best day to pick the car up is the coming Wednesday, hence will have to wait till next Wednesday :-( | |
| | #66 (permalink) |
| The odo reads a bit over 6K kilometers and it has been 6 months since delivery. The car was not used for a month in between as i was out of station. Here is a round up of how things are now: Engine and drive train:- The diesel clatter has settled a bit now, there was an annoying flat spot between 1500-2000 rpm(no not the turbo lag), which was traced to a dirty accelerator sensor. The 'kick' perse has become linear( not decreased as i have done some timed acceleration runs-just to make sure). The gearbox has loosened up quite a bit and now feels like a well oiled rifle bolt. No issues with engaging reverse gear as some of the other swift users have experience. Built: Flimsy-especially for the inside plastics. Rattles have not been a big issue till now(maybe because i am running on softer sidewall tyres and on better roads). The boot makes a 'tinny' sound while being closed(also contributed by the number plate vibration). The doors feel reasonably well made. The switch gear are all holding up well. Glove box is quite useless and poorly designed. FE: Excellent- consistently 17kmpl plus in the city and 21kmpl plus on the highway both with 100% AC. Using IOC(COCO) normal diesel. The fuel gauge is very non linear. The halfway mark actually corresponds to 1/4 tank and the 'E' mark still has 10-12 liters below the same. Faults: None till now. Had a small 'sqeeking' sound from the steering boss rubbing against the column covering, which was rectified at service. Tyres-XM1+ - had a single puncture-overall are very good. The noise levels are also one of the best i have come across. Thread wear is also minimal if any. Gripe could have been better though(compared to PP/yoko's). Running with 37PSI all around. After acquiring a digital tyre gauge finding most of the tyre gauges at tyre shops/petrol stations to be inaccurate! Servicing: Both free services done at the main dealer-experience has been satiafatory. Follow up is good, because of the large volume of vehicle attention to detail is poor. Have gone for Oil and filter changes at both 1K and 5K services, and i feel has done good. The oil drain lug nut was replaced after each drain-dont know if the same is routine procedure. Notes/observations:The circular vents are poor in directing air compared to the central vents. The rear seats(especially the backrest angle) for two are quite comfortable(personally observation,myself-5feet 11inches, 101kg frame) unlike what has been reported in case of all swift/dzire reviews, more so in the dzire because of the larger windows making it a little less claustrophobic. The music system has never skipped on CD's but the FM reception seems quite poor. The antenna also looks like a poor quality item. Power steering does not respond well to quite direction changes at low speeds. Brakes could do with more feel and bite, guess the rotors and pads are not updated to account for the uprated/heavier diesel engine! |
| | #68 (permalink) | |||
| Senior - BHPian | Hi, Quote:
I have the same doubt as Eddy!
__________________ Rajesh -Marina LS, Oct 05, 61918 (63574) kms, 13.97 kpl, 44km/day -City CVT, Sep 07, 40473 kms, 13.29 kpl, 53 km/day | |||
| | #69 (permalink) |
| Senior - BHPian | TOR,congrats on your perfect buy, dzire is truely a VFM with vdi/zdi models to choose from, and what a superb picturrial review you shared which shows and expresses the exact words you want to say, drive safe and keep updating.Any plans to get alloys??
__________________ CHEERS!! V I J A Y |
| | #70 (permalink) | ||
| Recommended is 36-37 for the front and 32-34 for the back. The reason for the increased pressures is but due to a personal choice and a personal logic-that filling the correct pressure will leave the tyre under inflated soon after(due to the customary leak), so filling a bit higher will enable to run the tyres at recommended levels over an extend period of time-This logic might be flawed-do give your inputs. Quote:
My bill had a quote of change of nut and not the washer(maybe because the same is magnetic?!) Quite true the back rest angle is different(better) but the biggest difference i feel is the welcome change to the ergonomics to the people sitting at the sides could be due to change in the trim of the rear door which is different from the swift. Never sat behind with the front seats set to my comfort, the two occasions that i experienced rear seat travel, the driver was 'less endowed(if i may) than i was .Quote:
Alloys are next on list-cant get to like most of the designs that are on sale now-so will wait. | ||
| | #71 (permalink) |
| BHPian Join Date: Jul 2007 Location: goa bangalore
Infractions: 0/1 (4) | TOR, I have read all 6 pages of this thread and loved your style of writing and frank comments. I esp liked the conversation with the tyre wallah just for my info.. you changed only 4 tyres to XM1s? what if you have a flat? I imagine your total bill for the car (accessories incl) would be about 5.8?
__________________ Fiat 1975 sold Omni 1995 sold Matiz 2000 handed down Dzire VDI Jul 2009 |
| | #72 (permalink) | |
| BHPian Join Date: Nov 2008 Location: Mumbai
| Quote:
37 psi? Maruti recommends 32 for front and 29 for rear in ZDi. Why do you maintain 37? I have just changed to Michelin XM1+ and I maintain 33 and 30.
__________________ We didn't start the fire; Me and my Dzire! | |
| | #73 (permalink) | ||
| Quote:
The onroad price of the car was 6.6 lacs and accessories came up to about 20k. Quote:
Another observation was that normal air leak will result in the car running at below recommended pressures till the next air check.(if the tyres were inflated to the 'recommended levels') | ||
| | #74 (permalink) | ||
| BHPian | Quote:
good report. yesterday, i drove my friend's dezire for @300km on all types of road. its 4 month old car with just 6000km on odo. i felt gear shift is really notchy. as you mentioned in 6 month report, gearbox has loosened. i wonder after same running of 6000km on my friend's car, it is still very notchy. have you done anything extra to loosen the gears?
__________________ Aim of every argument or discussion should not be victory but progress. | ||
| | #75 (permalink) |
| @Ashish Have done nothing extra to 'smoothen' up the gear box, guess the experience was because of driving your friends car-maybe the your friend would be finding the gearbox loosened up. So in effect it would be do to the driver as well as the car getting 'used to each other'! |
| Thread Tools | |
Similar Threads | ||||
| Swift Diesel, Saga continues. The DIESEL experience!Part II-31,000 kms Update Page 42 | Jaggu | Long-Term Ownership Reviews | 985 | 19th November 2009 21:06 |
| VW Jetta : 14,000 kms ; 6 months.... | akhilesh51 | Long-Term Ownership Reviews | 55 | 19th November 2009 17:46 |
| Tata Indigo XL Classic Dicor - 20,000 KMs & 3rd Service Update | Bouncer | Test-Drives & Initial Ownership Reports | 90 | 12th October 2009 14:36 |
| Passion Red Getz CRDi - Update - impressions post 2nd Service & Pete's Box | anarchist | Test-Drives & Initial Ownership Reports | 74 | 30th March 2009 19:22 |
| Swift DZire VDi - 20000 Kms Update - Few Problems | SumitBahl | Test-Drives & Initial Ownership Reports | 34 | 10th February 2009 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
