Old 12th January 2009, 01:55   #121
iraghava's Avatar
Thanked: 156 Times
Originally Posted by Sahil View Post
Does the Auto also suffer from this upshift rpm jump problem?
If toyota does realize this problem I dont think it will be a hassle to repair as adjusting the ECU should do the trick.
No, I've driven two AT cars & they don't have this problem.
Old 14th January 2009, 10:02   #122
I filled the tank and checked the mileage till now. I got exactly 13kmpl in Bangalore city. I was surprised. But, I was driving very slowly, keeping 60-70 whenever possible. Hope, once I start driving faster, my mileage will come down.
I felt, the gears and the clutch are little bit tight. may be because it's a new car, hope, it will be better after driving some more days. I drove around 600km in 15 days...
pjordy is offline   Reply With Quote
Old 15th January 2009, 12:19   #123
Thanked: 49 Times
Hey Abhinav
Found this excerpt at TOVA.
" As the new L15A i-VTEC features Drive-By-Wire and paddle shifters, this also means two characteristics which many enthusiasts have minor complaints about with previous Hondas employing this technology. DBW as implemented by Honda introduces a little bit annoying 'rev-hang'. This is the engine sustaining its rpm for a short while after the throttle has been released. However, this rev-hang is annoying mainly when used with manual gearboxes. With the 5AT, it should not be that much of an issue as the gear-change is coordinated by the ECU so I think this might be a trivial point"
It seems the Rev Hang situation you found in Altis be attributed to Drive by Wire technology.
zoom_vroom is offline   Reply With Quote
Old 19th January 2009, 13:05   #124
Vid6639's Avatar
Thanked: 21,086 Times
I sent an e-mail to TKML to explain this problem/feature. They were very prompt and called up the next day. A technical guy spoke to me and explained the whole thing in detail.
He says that the Altis uses DBW and this feature is a known one and not a problem. Basically it holds the rev's rather than drop to allow for a smooth downshift. Since many people do not rev-match to downshift and just slot the gear in without increasing the revs it loads the engine and drive train. To prevent this the car holds on to the higher revs so a down shift is not jerky.
The disadvantage is the jerky upshift which he says you can get used to and after driving it a while you will not realise.
Old 19th January 2009, 13:39   #125
Thanked: 49 Times
Absolutely fantastic of Toyota to be willing to explain things !!!
Quite in line with what TOVA said about the ANHC,attributing the RPM surge to DBW.Do we have any ANHC owners seeing the same RPM surge while shifting gears?
Old 19th January 2009, 16:52   #126
Thanked: 139 Times
Having a CVT NHC I have turned anti-CVTs, I like them for the FE they return but the rubber band effect is horrible.
I think the rubber band effect is there in the old Corolla, but is not a bother, pretty tolerable, and is perhaps perceptible only in perhaps hard revving. I sort of rationalise it this way that the rubber band effect is even in a manual, as we shift gears.
vasudeva is offline   Reply With Quote
Old 20th January 2009, 14:06   #127
Ym-enjn's Avatar
Thanked: 55 Times
Has anyone seen cars hood jumping up and down in few english hip hop videos. That is caused by pressing the accelarator fast and leaving it fast, then again pressing it and leaving it. If you do that in Altis and any other car with this tech, it will minimise that jerk. (I know it is funny) but this is an extreme example. This tech makes the ride very very smooth, sepcially at speeds above 30, you just leave the accelarator suddenly (which we do often in trafic) and it doesn't jerks a bit. I never found this tech unusual as it is there also in my 2005 Ikon flair.
Ym-enjn is offline   Reply With Quote
Old 20th January 2009, 14:10   #128
Akshay1234's Avatar
Thanked: 7,243 Times
ummm.. hydraulics?
Old 20th January 2009, 21:56   #129
R2D2's Avatar
Thanked: 2,052 Times
Thanks for this info Vid6639. A perfectly good reason after all.
Rgds,
Old 29th January 2009, 15:25   #130
Thanked: 103,685 Times
Spot the Difference Competition: Corolla versus Altis.
Old 29th January 2009, 15:56   #131
vnabhi's Avatar
Thanked: 1,317 Times
Both cars look similar, but on closer examination, I think the one on the left is the Altis.
Old 29th January 2009, 16:04   #132
diwa's Avatar
Thanked: 45 Times
The one on the Right side is the Altis in the Golden color. If you look closely the curves on the bonnet can be spotted. I am not sure if corolla came out in Gold color.
diwa is online now   Reply With Quote
Old 29th January 2009, 16:53   #133
Sahil's Avatar
Thanked: 2,718 Times
The are really similar from the top view. Its the front end and interiors that make the major difference.
The gold one is the Altis.
Old 29th January 2009, 18:03   #134
The one on the right is the Altis. The difference in headlamps and tail-lights worked for me.
But it is interesting to see the way the body curves in in the Altis. Looks like more glass and less metal is used in the Altis.
swami is offline   Reply With Quote
Old 29th January 2009, 18:09   #135
Hahaha! See what I mean. It is the one on the right that is the Altis. They are just so similar, I firmly believe that the Altis isn't an all new platform.
Toyota Corolla Altis (1.4 D-4D) Diesel : Test Drive & Review GTO Official New Car Reviews 222 24th May 2018 10:06
Altis Diesel vs Micra Diesel ! Is Altis Diesel still underpowered ??? Hero Puch The Indian Car Scene 13 8th April 2011 16:20
Corolla Altis AT- Test drive shatrughna Test-Drives & Initial Ownership Reports 138 15th January 2010 18:27
