Old 23rd April 2009, 16:06   #121
rudrah's Avatar
Thanked: 29 Times
Originally Posted by umapathy1972 View Post
I own a Palio Stile Sport (Red) for the past one and a half year, done 41,000 kms.
i have no complains on the service of Fiat as well as Tata. Excellent. i do my service with manipal motors where i bought my Palio.
41,000 kms in one and a half year
Do you run your Palio across countries??
Glad to see a happy FIAT Palio customer. The service is gradually improving and a good positive sign for FIAT!
rudrah is offline   Reply With Quote
Old 27th April 2009, 11:06   #122
after my palio, i have stopped any means of public transport :-).
umapathy1972 is offline   Reply With Quote
Old 9th July 2009, 18:48   #123
rudrah's Avatar
Thanked: 29 Times
Question Water clog in the Rear Brake light and Wiper blade sound
Case 1:
After every car wash, I notice water marks (dry ones) inside the rear brake light on the windshield. I used to think may be it was by default since i bought the car.
Now after rains, I see quite no. of water droplets inside the brake light. Thats when i realized there is a gap from where the water penetrates. I'm still clueless how the water enters in.
Any idea how I can block the water entering?
Case 2:
When front wipers run, it makes a dry sound bit loud when the rubber reaches the top end(the one on driver side). Is this normal or a problem? Can this be solved?
Case 3:
Also the water in the washer seems on empty side as when i trigger it, there is very less of water coming out that too not in jet force.
What solution can i put in and how much quantity?
Old 10th July 2009, 11:15   #124
planet_rocker's Avatar
Thanked: 368 Times
Originally Posted by rudrah View Post
Case 1:
Do you mean to say the third stop light? if yes, then check the rubber beading/washer on the rear wind shield - check for cracks
if it is ok - open the bootlid and see if the rubber washer that holds the roof mould is ok - i think the real culprit is this washer
or else check the water jet (washer) for the rear wind shield.
Case 2:
time to get a new wiper - cheap/temporary solution - rub the wiper blades with cotton soaked with glycerin (spelling??)
Case 3:
clean the front jets with a string of copper wiper / string from a tooth brush.
i use colin and mix with water and fill up the washer tank till it over flows. (colin:water - 1:3)
planet_rocker is offline   Reply With Quote
Old 10th July 2009, 14:24   #125
rudrah's Avatar
Thanked: 29 Times
Case 1:
You are right, its the third stop light on the top rear windshield. I've to check for the rubber beading/washer or a crack.
Today after starting the car, I observed water leaking from inside the stop light cover on the windshield(on the inner side of the car)
Case 2:
I'll try your formula cleaning wiper blade. Seems a bad quality rubber or due to unused wipers for so long has become too hard.
Case 3:
I don't have colin. I'll try getting a ready made windshield washer liquid.
Thanks a lot for your help, Rocker!
Cheers~
Old 10th July 2009, 15:04   #126
Thanked: 368 Times
Case 1:
then it is the windshield rubber - get it checked / replaced - sit inside the car - ask someone to pour a mug of water at the edge of the roof and the bootlid - the water should seep inside from there - check the water drainage line (rubber washer) near the roof mould / boot lid.
Case 2:
lemme know if that helps.
Case 3:
- you don't use colin at home? if not - top it up with plain water - the handbook has details on how you can change the water jet pressure / flow / direction.
Old 10th July 2009, 16:51   #127
Ravveendrra's Avatar
Thanked: 406 Times
The water in the high stop light at the top of the rear windshield is probably coming from the top check all beadings.
Replace all wiper blades at least every two years (preferably every year). Otherwise they become hard and start scratching the glass (besides not wiping properly).
That foggy appearance is due to dirty glass / wiper blade. Clean the glass with a windshield shampoo (Sonax is good) or good old Colin spray. Add glass shampoo / windshield cleaner to the washer reservoir alongwith clean water. Spray liberally when using wipers.
If it is actual condensation on the windshield use A/c. judiciously - with / without ventilation as per requirement. There is a nice article about this by GTO somewhere here.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 9th March 2010, 17:55   #128
rudrah's Avatar
Thanked: 29 Times
Default Car has now done 14k kms in 1.6 years
Its been almost 8 months i've updated this thread! The car has done around 14k kms in 1.6 years which I know is very less. With me being a new driver on the roads, it has given me enough pleasure I could expect in that price bracket! Yes, there were niggling issues due to poor quality. But that overcomes once I touch the highways
It has consistently given me a FE of 9.8-11kms/ltr in City and highways around 14+.
Its still a head turner no questions about it? Why? Because there is no Stile 1.6 Sports Formula Red in my City So I enjoy the exclusivity. I still see people go circles round the car or comment with curious expressions.
I've seen people getting confused for a Punto! I heard one saying "Yeh Punto hai" hehehe
The most cute one was when i was passing through a lane, I saw couple of kids shouting "FIAT" and a mother telling her small daughter "No its not ... its a FIAT". This is somethin I've never experienced for other cars ofcourse excluding the Mercs, BMW, Audis.
The ownership till date has been good with no major issues. I've heating issues at the moment which I would soon be sorting out by Radiator flushing orelse let the service guys troubleshoot it.
Service has been expecting my needs thou it could have been much better if FIAT had its own garage. These ants like TATA cars has just made it suffocating when you enter there.
Found a good service center, i.e Fortune Cars at Powai where there have old FIAT mechs with older FIAT cars experience. So its easy for them identify the problems and the history behind the cars and its problems.
No modification done. Just added the old 100 16v monograms to side fenders. I may add running board in future or the S10 side skirts!
Well this being the last lots of the 1.6 DOHC 16v 100 PS engine, its sad it will no more reproduce a new gen in existing or upcoming FIAT cars. Feels lucky to own one like this.
Its just love at first sight and I'm still Loving It
Cheers~
Old 9th March 2010, 18:05   #129
Cartman's Avatar
Thanked: 225 Times
Nice little review buddy. Straight from the heart. Liked it. ..
Get rid of the front number plate. Lot of Palio Stile owners here in Mumbai have done it and it looks nice. You can paint/stick the number on the front.
Cartman is offline   Reply With Quote
Old 10th March 2010, 12:00   #130
rudrah's Avatar
Thanked: 29 Times
Default Fiat Free check up camp on March 13th & 14th
Thanks for your comment, Cartman. Reg the number plate, i was initially looking for the square shaped having embossed numbers with Ashok chakra in it. But couldnt find it here. Anyways I shall think upon it.
Wanted to update something, as most TBhpians driving FIAT cars are aware of the Fiat Free check up camp started all over. The camp for Mumbai, Thane and Kalyan is scheduled on March 13th and 14th 2010. Yesterday I got a call from Mr. Rajendra - Service Advisor FIAT of Fortune Cars@Powai. He is personally calling to whosoever nos he has. Below is the link for details of the location where the camps are held:
http://fiat-india.com/servicecamp.aspx
Myself, along with Roms and other PUG members would be visiting Fortune Cars at Powai on Sunday early morning around 10am. Anyone wishes to join us?
The benefits of this camp which is as below:
1. Free vehicle check up
2. Free top up of oils, coolant & battery fluids
3. Special discounts on spares & labour
4. Complimentary gifts
I guess if major of our members are meeting at Fortune Cars @Powai, it will be a mini meet. I guess Mr. Mangesh Kodalkar, FIAT CSM would also be visiting us those days. Good chance to convey any issues faced with dealers and service.
Cheers~
Old 11th March 2010, 07:44   #131
arishi1's Avatar
Thanked: 12 Times
Fiat India
Cheers~
Rudrah, hope to see you at Fortune on Sunday. I am planning to take my GP for the checkup.
arishi1 is online now   Reply With Quote
Old 11th March 2010, 15:09   #132
rudrah's Avatar
Thanked: 29 Times
Glad to hear for your participation! If you see a Formula Red Stile 1.6 with the PUG logo at the front and rear with MH-43 series, thats mine or a Palio S10, thats Roms. We will be reaching there at 9.30am and will be around with Mr. Rajendra.
Old 11th March 2010, 16:57   #133
roms's Avatar
Thanked: 22 Times
Great report and 'fantastic' pictures . You know the reason for that smiley, isn't it?
I think the side skirts of the S10 will do complete justice to the side profile of the Palio Stile. It should help disguise the slightly raised rear suspension on the Stile apart from looking sporty and 'cool'.
Also, since the car has done about 14 K kms already, I think its time you get your tyres rotated, if not done already.
And yes, the Palio Stile and the S10 shall have a meet this Sunday, 14th March at Fortune Powai at 9.30 ish in the morning for Fiat's free check up camp. Any more Fiats interested to join in ? Lets see how successful / helpful this event turns out for us Fiat owners.
@ Arishi 1- Come along, we shall definitely meet on Sunday.
roms is offline   Reply With Quote
My New Fiat Palio Stile 1.6 - Formula Red RAINMAKER Test-Drives & Initial Ownership Reports 16 2nd October 2009 21:44
Fiat Palio Stile 1.6 Sport (Formula Red) guyonblackybx Long-Term Ownership Reviews 65 29th February 2008 22:15
Palio Stile 1.6 Sports (Formula Red) guyonblackybx Long-Term Ownership Reviews 106 28th February 2008 21:21
New Formula Red Palio Stile 1.6 - 500 kms Report ReNaGade Test-Drives & Initial Ownership Reports 32 7th November 2007 08:16
My new Fiat Palio 1.6 Stile Sport(Formula Red) rakesh Long-Term Ownership Reviews 25 22nd October 2007 17:08
