Old 6th March 2009, 22:03   #196
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by Proxima View Post
PSI motorsport's website shows that there are 2 models for the PSI box.
1.4 TDCi 50kW 68 HP (5G) 2002
1.4 TDCi 50kW 68 HP (5GA) 2002
One with 5G and the other with 5GA. So which is the engine model for the Ikon/Fiesta sold here?Is the Ikon's engine the SIEMENS version or the BOSCH version?
I think its SIEMENS piezo system but not sure. Email Psi for a conformation. Check to see if you have any Siemens or Bosch labels on your ECU and injectors.
Old 7th March 2009, 13:40   #197
Thanked: 1,642 Times
I plan to buy one from one of these guys, because the Petes box seems overpriced at > 40k.
Neither. If I'm not mistaken, the Ikon/Fiesta TDCi uses a Delphi Common Rail, not Bosch. Its a Peugeot engine that is also used by Citroen and Ford (for Euro markets).
Steeroid is offline   Reply With Quote
Old 7th March 2009, 23:52   #198
Proxima's Avatar
Thanks Steer. Are powerboxes different for different injectors?
Proxima is offline   Reply With Quote
Old 8th March 2009, 19:19   #199
Proxima's Avatar
TDCi is Ford's Common Rail brand name. The 1.8 Duratorq in the Mondeo wasnt labelled TDCi though it was a Turbocharged Direct Injection - it was part of Ford's Puma series of engines that followed the rather antique Endura series. Great smooth engine but it had far too many issues - wasnt what you might call a reliable engine. HOpefully the TDCi will do better - at least its a Peuguot engine.
See here:
http://www.india.ford.com/servlet/Co...cs_temp&c=Page
http://www.india.ford.com/servlet/Co...ty_Temp&c=Page
The 1.4 TDCi is called the DV4
Wikipedia's response for a Ford Duratorq 1.4 TDCi search:
Ford Duratorq engine - Wikipedia, the free encyclopedia
The Duratorq DV4 (named the HDI 1.4 L by PSA, TED4 by CitroŽn, and Duratorq TDCI 1.4 L by Ford, and also called DLD-414) is a 1.4 L straight-4 turbo-Diesel. Output is 50 kW (67 hp) at 4500 rpm and 160 N∑m (117 ft∑lbf) at 2000 rpm.
The DV4 uses a Borg-Warner KP35 turbocharger but no intercooler. This is the same turbocharger as the Renault K9K Diesel. It is EURO3 compliant. It also uses Delphi Automotive's DCR1400 common-rail injection system.
Applications:
* Peugeot 206
* CitroŽn C3
* Ford Fiesta
I think it is a DELPHI system.
Now I need to know if the Fiesta's/Ikon's engine is the
OR
Old 11th March 2009, 21:17   #200
condor's Avatar
Thanked: 4,903 Times
Mpower : Check to see if you have any Siemens or Bosch labels on your ECU and injectors.
@Mpower, that was easy .
Old 11th March 2009, 21:26   #201
Proxima's Avatar
Attachment 110552
Wow Condor, I don't know how to thank you! Thank you soooo much.
Used up my 2 smileys. lol
I was struggling to find out if it was Siemens or Delphi but I know for a fact now thanks to you. Now to get a good tuning box for the Ikon...
Old 11th March 2009, 21:33   #202
condor's Avatar
@Proxima : actually, thanks to Mpower ..
You should also have the same one - but do check once on your car, just in case it has a different make. ECU's left of the battery. The label's very visible.
Old 11th March 2009, 21:45   #203
Proxima's Avatar
Good idea. I'll check it out. I tried looking for it but didn't know where to look. I'll look to the left of the battery tomorrow morning.
Old 30th May 2009, 16:33   #204
d_payne's Avatar
I drove the TDCi last week - Paprika Red, 10,000kms already on the clock. The clatter was definitely noticeable at idle and on the road at low speeds. Noise was better in the mid-ranges and was back with a bang at 80+kmph. I only took it up to 100kmph by which time I ran out of road.
What I loved:
1. The linear way in which the engine pulls in any gear. Seriously could not tell it was a turbo-diesel! There is enough torque available in every gear for city driving and quick overtakes. (Definitely muuuch more than my Indica DLS :P )
2. Great steering wheel and driving stance. Very sporty - as all iKons have been over the years.
3. Fresh interior looks - the biege look.
4. Great handling. This is after all the ikon!
What I did not appreciate:
1. The clatter at idle and in the beginning. (Of course, my good ole Indica will make the TDCi sound like a electric-engined car. )
2. The quality of the door trims could have been better, feel was a bit cheap.
3. Very sudden braking on this TD model. No idea why, hope it was only with this car. Its exactly like another member posted - like an on/off switch. The sales guy kept lurching forward in the passenger seat even on light braking! Anyone else facing this issue?
I drove this in the night for only 20 mins (was late for dinner) so I can't really say much for the exteriors. I am sold on this car though. The way the engine behaves at moderate speeds (which is 80% of our driving) is enough reason to buy it! Its tractable, feels solid and is great VFM.
Going to drive a Ritz diesel, i20 petrol, Vista Diesel today or tomorrow. But I don't see myself choosing another car - am emotionally attached to this car!! Will definitely take another TD to closely understand: gearstick vibrations, clutch feel, rear-seat comfort etc.
A few queries:
1. How much would a good set of 14" alloys (preferably black/silver) cost?
2. Cost of tire upgrades? (185/60 - including sellback of stock wheels and tires)
3. Any headlamp mods possible? (white-light! - I know projectors will be difficult with the new units)
4. Pete's box for the Fiesta's engine. Does it drastically alter NVH characteristics and mileage?
Thanks a ton!
Payne
d_payne is offline   Reply With Quote
Old 4th June 2009, 23:08   #205
condor's Avatar
d_payne : The sales guy kept lurching forward in the passenger seat even on light braking! Anyone else facing this issue?
No, not seen atall.
Your observations are pretty much what I have seen during these 3500+ km of driving this car. I had forgotten about the gear lever vibrations that some people had complained about .. let me check for it again tomorrow.
Alloys : about 3.5 - 4k each ?
Tires : 3.3 k each., approx ?
Stock tire buy-back : you have to check with your dealer.
If you are going for this car, definitely upgrade the rubber.
d_payne : 4. Pete's box for the Fiesta's engine. Does it drastically alter NVH characteristics and mileage?
What makes you think a Pete's box can even alter NVH characteristics of the car ?
Old 4th June 2009, 23:29   #206
d_payne's Avatar
Nothing at all. I know its an ECU remap, but being a newbie to Pete's box I just found it a bit amazing that a silent upgrade can give such an amazing boost in power. Newbie to car mods as well. So please to excuse.
Am still not decided on the car yet, a pre-owned Cedia seems like a very good option for my purpose so still hanging in the balance while I check out some examples I am.
(My first car! (Down to new iKon TDCi vs Pre-owned Cedia))Here's my What Car? thread.
Thanks!
Payne
Old 5th June 2009, 10:34   #207
benbsb29's Avatar
Thanked: 4,277 Times
Payne, you have your observations spot on with what a lot of others have also commented upon during their TDs.
As for the braking, as compared to the braking on the previous model of the Ikon, it has been improved, but the bite is sure felt. I felt the same as well, and managed to brake hard on a couple of occassions, whereas the same would not have been so abrupt on my car. I feel its just a matter of getting used to - the braking characteristics, i mean.
As for the interior trims, they may not be beautiful, but they're durable.
Old 5th June 2009, 11:02   #208
condor's Avatar
Went searching for the gear lever vibrations : it is there, but I am that oblivious to it now.
condor is online now   (1) Thanks Reply With Quote
New Ford Ikon TDCi brochure! sidindica The Indian Car Scene 295 12th February 2012 21:18
Ikon TDCI discontinued ? EDIT: Confirmed: Ford stops Ikon production greatmana2000 The Indian Car Scene 61 10th February 2011 19:20
700 km Report of my new Horses, Ikon TDCI. EDIT: 2500km update! S_budhiraj Long-Term Ownership Reviews 70 26th February 2009 18:06
Ford Ikon TDCi normally_crazy The Indian Car Scene 17 28th November 2008 15:14
