Old 29th April 2009, 20:25   #136
aks_karthik's Avatar
Thanked: 232 Times
Taken this picture near Ford Factory,Chennai.
It's new Endeavour.
Silver Streak Linea :)-hpim3504.jpg
Silver Streak Linea :)-hpim3505.jpg
aks_karthik is offline   Reply With Quote
Old 29th April 2009, 21:41   #137
geeash's Avatar
Thanked: 132 Times
Default ok sure!!
Aswin,
can you check with 3M?
Yes. not an issue. Ill call dennis tomorrow morning and enquire and keep you people posted about it
geeash is offline   Reply With Quote
Old 29th April 2009, 21:53   #138
pranava999's Avatar
Thanked: 19 Times
post the ford pics as a separate thread karthik
pranava999 is offline   Reply With Quote
Old 30th April 2009, 20:15   #139
trrk's Avatar
Thanked: 13 Times
Originally Posted by geeash View Post
It doesnt peel off the coating is 2 inch thick i suppose.
Two inch would be about 5 cms. You will lose 5 cms of your ground clearance!
Originally Posted by VIKING View Post
The 5 year warranty that Prerana Motors provides in Bangalore is more like a 5 year cover. What they claim is whenever you go in for service or repairs, if they find the coating has been damaged, they will redo that area to make sure the underbody is not exposed to the elements.
And how frequently would you be going for service? And what about the time frame between the damage and the next service?
Frankly, if an after market person can do this for a car at this price, I am sure the manufacturer can do it at a fraction of the cost in his assembly line.
But like any other accessory, it is the customer's choice.
trrk is offline   Reply With Quote
Old 4th May 2009, 10:22   #140
Thanked: 232 Times
My Car got it's First Service from VST Motors Chennai @ 3500 kms.
All issues were handled well.
Car was cleaned (Usual interior and Exterior cleaning job) and Wheel Alignment also done.
No Oil change.only Top up has been carried out.
Painiting job has been done in the Front Left Side Door and costed Rs.1900.Piant Job is Good and there's no Visible difference.
As of now there is no rattling sound.
Still there is no OEM Mud Flaps and Boot Mat.Yet to arrive.
Speaker jarring is unattended as Blaunkpunkt Service Advisor is not available.Awaiting them to check and fix.
Old 4th May 2009, 19:29   #141
trrk's Avatar
Thanked: 13 Times
How much did you have to pay?
Was wheel alignment a part of this service?
Did the oil (or any other fluid) need any top up?
Old 4th May 2009, 22:37   #142
geeash's Avatar
Thanked: 132 Times
Best way is to throw the speakers out and get a couple of pair of great speakers of the same size and fit it there . The speakers are crap.
Old 5th May 2009, 10:35   #143
Thanked: 232 Times
Zero
Yes it's thepart of the First Service
Yes they did topup.
Old 5th May 2009, 10:37   #144
Thanked: 232 Times
yes planning to change the speakers.
But the Blaunkpunkt System is not good enough to handle high RMS as it's only 30*4 rms only.
we need to have Amplifier.But heard there is no o/p.
Please let me know if there is a way to add amp and woofers and High end speakers.
Old 5th May 2009, 12:14   #145
trrk's Avatar
Thanked: 13 Times
Thanks for the responses.
Zero
Yes they did topup.
Sorry for being persistent.
What top up was done? Since you have not paid anything, I doubt about the top ups, as the consumables are chargeable even for free services.
There should not be any need for top ups, in my opinion, if all the fluids were correctly filled to start with.
Old 5th May 2009, 12:48   #146
Thanked: 232 Times
Originally Posted by trrk View Post
Oops I am not sure though.
I asked Service Guy,He told they topped up windscreen,Gear,Brake,Engine fluids.
But i haven't checked it personally.
I'll check with Works Manager and let you know.
yes i too have the same doubt.without spending single penny how they did topup.
Old 5th May 2009, 13:47   #147
trrk's Avatar
Thanked: 13 Times
While you are at it, ask them to tell you the specific quantity used for each top up.
I am sure that is a standard statement that is given to make you feel that they have done all the checking.
I will trouble you (or any Linea owner) for one more thing. The owner's manual would have a service schedule chart. Could you scan it and put it up?
Old 7th May 2009, 10:08   #148
Thanked: 232 Times
Hi Linea Owners,
Any one knows how the Trip Computer works?
IMO,it does work quiet good but strangely.
Every time both A and B Trip Meter is running,if you reset either A or B.
But at my Third refueling,i did something in trip meter and only B trip was running and not A Trip.
There's no clue in Manual.
Please let me know.
What i want is i need to run either A or B trip as my wish by resetting.
Old 7th May 2009, 10:32   #149
check again. probably only A trip is running & not the B trip. There is no option to turn off A trip. You may have turn off the option of B trip.
Go yo Menu on the dash, Right Hand Side below steering. Select TripB option & turn it ON & check. Both A & B should work then
VahanPujari is offline   Reply With Quote
Old 7th May 2009, 10:35   #150
karthik,
As far as I know tripA will always be there. You have option to turn OFF tripB from the settings menu.
IMO its useful to have both. Although its a pain to cycle through each entry.
I keep tripA for mileage stats. And trip B will hold one particular trip (long drive etc) Data.
neotraveller is offline   Reply With Quote
VW Vento Highline TDi, My Silver Streak - 5 years, 78000 kms and still raring for many more souravc Long-Term Ownership Reviews 147 27th June 2016 10:16
A Beauty in Shimla - Pontiac Silver Streak! Cyrus43 Vintage Cars & Classics in India 19 1st July 2011 16:26
Escape Velo'city' - Polished Metal Metallic V-AT (Quasar) joins Silver Streak, Shadow foodie Test-Drives & Initial Ownership Reports 5 11th May 2010 13:14
Silver Audi A8, REAL silver! karthik247 The International Automotive Scene 6 5th September 2005 01:52
