Old 16th July 2009, 11:57   #361
Originally Posted by aks_karthik View Post
Finally my car came with good condition.
Repainted the entire bonnet and small scratch in the Wheel Fender.
Quality of painting work is not good.
find some dust particles in the painting area though barely visible.seems they painted or dried it in open area.need some attention.
Rest everything works fine and there is no niggling issues so far.
Keep up the good work FIL and TASS.
How about the bulges? have they gone?
also what was the conclusion about the reason for bulges?
VahanPujari is offline   Reply With Quote
Old 16th July 2009, 12:28   #362
aks_karthik's Avatar
Thanked: 232 Times
They have done a good job on bulges.
Now the bonnet looks very neat like previous.
As they said,The bulges happened because of improper way of closing the bonnet.
They checked the locksand other parts in the bonnet .
Nothing found irregular to make bulges in the bonnet.
Just Pray Almighty for not intrude the same again.
aks_karthik is offline   Reply With Quote
Old 16th July 2009, 13:57   #363
karthik, How do you close the bonnet?
As per the manual, right way is to drop it from a height of 10cm or something. If bonnet doesn't close properly, DONOT press on the bonnet with hand. Just repeat the above dropping sequence again.
Hope you followed this way.
neotraveller is offline   Reply With Quote
Old 16th July 2009, 14:22   #364
Thanked: 232 Times
Whenever i open the bonnet i do the same as you said.
But the Bulge happened when i sent my car for servicing.
So those people in VST motors had done some thing to produce bulges.
Old 27th July 2009, 09:23   #365
Thanked: 232 Times
Default Shell Diesel
Hi All,
This is the first time i have filled Shell Deisel in my car.
Previously i used to have only IOC Diesels.
Now the car is super smooth,Engine Noise reduced and pick up is somewhat increased.
I don't know,Whether my perception is right or not.
But i am feeling a huge difference in driving.
I'll update FE after some mile munch.
Old 27th July 2009, 12:57   #366
Thanked: 232 Times
Default Bought Vacuum Cleaner
I bought a Handy Vacuum Cleaner from Eureka Forbes for Rs.4000.Life Time free service till today.
It's very useful.cleans the interior very well.
Definitely Every one needs it for cleaningthe car.very handy and powerful.
Eureka Forbes=
Old 27th July 2009, 18:19   #367
trrk's Avatar
Thanked: 13 Times
Does it have a 'blow' function too?
trrk is offline   Reply With Quote
Old 27th July 2009, 18:34   #368
Thanked: 232 Times
yes it has everything.
Check the URL in the other post.
Old 27th July 2009, 20:36   #369
Sunilrj's Avatar
Thanked: 536 Times
most properly they left some tool in the engine bay and closed the bonnet. happened once to me after i had given my swift for service. when i opened the bonnet 10 days later found a spanner, a oil filter removing tool and a screw driver in the cowl!
Sunilrj is offline   Reply With Quote
Old 28th July 2009, 09:59   #370
geeash's Avatar
Thanked: 132 Times
Eureka Forbes
I have this one at home and it works wonders on cars too. I use it every sunday to clean the carpet of the car and vacumming the mats and also for blowing the dust out of the car.
geeash is offline   Reply With Quote
Old 28th July 2009, 11:34   #371
Thanked: 232 Times
Default 100kms drive using Shell Diesel
I have driven the car for more than 100 kms with Shell Diesel for the first time.
Earlier the car feel very responsive.
But by yesterday itself,the car has been lugging in 1st and 2nd gear.
once the speed is increased it disappeared and crawl silently.
without giving acceleration the car can move forward in 10-20kms speed in any gear.i too experienced before.
But now the car is not moving easily and engine knocking is evident.
I don't know whether it's because of Shell Diesel.
But i am facing this issue for the first time only after changing to Shell Diesel.
Linea MJD Owners,Please let me know,if you too have the same problem on using Shell Diesel.
Old 28th July 2009, 11:36   #372
Thanked: 232 Times
Originally Posted by geeash View Post
Eureka Forbes
yes Geeash,
In my house in Native and cousin also has the same model.
it has wet cleaning option too.very useful to clean marble/tiles flooring.
But the power(Suck & Blow) is lesser than my model.check the specifications.
Old 29th July 2009, 09:37   #373
Thanked: 232 Times
From yesterday evening the car behaves as earlier.
It crawls without giving acceleration.
Back to Normal.
But i don't know,what the hell had happenned last 2 days after fillling Shell Diesel.might be some impurites chocked the injectors.
As of now,The car is smooth and drivable.
Reg.Seat Height Adjustment.
I have changed my seat setting before 2 days and stll it is not coming down to normal.
it's in the same position as i adjusted.
So my seat Height adjustment has no issues.
Any how i'll observe for some more days and let you know.
Old 29th July 2009, 13:50   #374
Guys
what about the boot of Linea. I have Epak Linea and I found that Boot of Linea is a little hard to close. We have to push it a little hard unlike other cars. Are you also facing such problem or is it just a setting that I might need to get done during 1st Service.
nicesachin is offline   Reply With Quote
Old 29th July 2009, 14:03   #375
Thanked: 232 Times
yes you need to give little more thrust.
Every car Boot lid has the same tendency.
Any how check with TASS while 1st service.
VW Vento Highline TDi, My Silver Streak - 5 years, 78000 kms and still raring for many more souravc Long-Term Ownership Reviews 147 27th June 2016 10:16
A Beauty in Shimla - Pontiac Silver Streak! Cyrus43 Vintage Cars & Classics in India 19 1st July 2011 16:26
Escape Velo'city' - Polished Metal Metallic V-AT (Quasar) joins Silver Streak, Shadow foodie Test-Drives & Initial Ownership Reports 5 11th May 2010 13:14
Silver Audi A8, REAL silver! karthik247 The International Automotive Scene 6 5th September 2005 01:52
