Old 26th July 2011, 19:17   #751
aks_karthik's Avatar
Thanked: 188 Times
Originally Posted by Ash_bn
@aks_karthik,
I am almost in a verge of buying race chip for my linea MJD. You have mentioned all good things about the chip. Would like to know if there is any negative affect or any change you noticed after installing the chip
regards
Ashok
Seriously nothing. But Engine Noise is increasing little bit still under acceptable level only.
But no idea about long term issue as I have been using it for last some months only.
aks_karthik is offline   (1) Thanks Reply With Quote
Old 24th August 2011, 09:53   #752
Thanked: 188 Times
Default Timing Chain Replacement
Heard from VST Service that some of the Linea/Punto (Chassis No) should be checked for Timing Chain.
My car is in the List and i might be going over there by Next Month.
Checking it is very time consuming (2 days) and need to remove some vital parts of Engine, So i am little bit skeptical in doing this.
But i got a call from VST Works Manager itself to reassure about the service the Timing Chain.
FIAT is very much concerned to check the faulty Timing chain and replace it atonce.
Symptom: If there any different noise coming out from Engine.
Please check with your Service Centre.
aks_karthik is offline   Reply With Quote
Old 24th August 2011, 10:21   #753
Thanked: 532 Times
Default Re: Silver Streak Linea :)
Which engine?? And what month is your car from??
julupani is offline   Reply With Quote
Old 24th August 2011, 21:22   #754
Thanked: 188 Times
Mine is March 2009. Please check it with your service station. The list has been distributed among all service station. You can check your car with Chassis No.
Old 25th August 2011, 10:01   #755
geeash's Avatar
Thanked: 127 Times
I warn you not to do. These guys retrofit my linea with a/c and then all the a/c problems started and then the battery problem. better keep the car as it is if it is not giving problem!!
geeash is offline   Reply With Quote
Old 25th August 2011, 10:20   #756
Thanked: 188 Times
seems it's a Major Issue identified by FIAT.
Already 2 cars were come to VST with Ceased Engine because of this problem.
No other go
Old 25th August 2011, 14:15   #757
drdeepudev's Avatar
Thanked: 53 Times
kartik, had a talk with sa of concorde motors, cochin. He is unaware of this issue (or pretending). Mine too is a march 2009 model mjd emotion pk. He says if the timing chain is loose, we will replace it. Otherwise no need of it.
Is there any other means, so that i can find my car is included.
drdeepudev is offline   Reply With Quote
Old 25th August 2011, 14:37   #758
BulZire's Avatar
Thanked: 131 Times
Mine is from April 09 batch, would like to know if we can check the cars listed for the fix through online by giving chassis number or any other detail.
Any lights ?
BulZire is offline   Reply With Quote
Old 25th August 2011, 19:13   #759
Thanked: 18 Times
@AKS:
Called Kirubakaran and he said, there is no such timing chain recondition program going on. surprise...
ndinesh is offline   Reply With Quote
Old 25th August 2011, 23:49   #760
Thanked: 188 Times
I am going to VST this Saturday. I'll update you once I return from there.
Old 28th August 2011, 13:42   #761
Thanked: 188 Times
Car has come after fitted with new timing chain, rubber cover (suggested by Fiat)for front mounts cavity to prevent rusting and water logging on washing the car and 2 ltrs of coolant.
Old 28th August 2011, 17:32   #762
geeash's Avatar
Thanked: 127 Times
karthik can you confirm whether my car is in the list too? is it for diesel cars only or for petrol too?
Old 28th August 2011, 21:35   #763
Thanked: 188 Times
Seriously no idea.
I'll check and tell you tomorrow.
Old 7th September 2011, 10:42   #764
Thanked: 188 Times
After changing the Timing Chain, i had done a Trip to my native and no surprises.As usual Linea was poised and got a very good FE.
But heard some belt noise kind of sound comes from the Engine bay which is not heard before. I am not sure though.
But VST guys told me, it's normal.Need to check in some other cars.
Again i got a bill for Rs.773 for sealent/Glue used for this change and rest under Extended warranty and VST guys claimed that it's not under warranty and FIAT is not accepted to reimburse this amount and this amount should be borne by the customer.
I raised my voice and they will accept my concern and come back after speaking with FIAT.
Any how i won't pay this amount.
Old 7th September 2011, 12:30   #765
Thanked: 18 Times
Default Re: Timing Chain Replacement
@aks_Karthik
I checked with Concord again and they confirmed they don't have any such note from Fiat to replace the timing chain for Linea. I tried to reach Kirubhakaran@ VST. His mobile is switched off. You have any other contact?
Dinesh
VW Vento Highline TDi, My Silver Streak - 5 years, 78000 kms and still raring for many more souravc Long-Term Ownership Reviews 147 27th June 2016 10:16
A Beauty in Shimla - Pontiac Silver Streak! Cyrus43 Vintage Cars & Classics in India 19 1st July 2011 16:26
Escape Velo'city' - Polished Metal Metallic V-AT (Quasar) joins Silver Streak, Shadow foodie Test-Drives & Initial Ownership Reports 5 11th May 2010 13:14
Silver Audi A8, REAL silver! karthik247 The International Automotive Scene 6 5th September 2005 01:52
