Old 8th April 2009, 22:44   #106
netarchie's Avatar
Hi Karthik,
Awesome ride you got there buddy, nice colour choice too. Drive safe and take good care of her.
My friend booked the linea a week back. awaiting the delivery of his linea ;-).
netarchie is offline   Reply With Quote
Old 9th April 2009, 09:40   #107
aks_karthik's Avatar
Thanked: 215 Times
Originally Posted by luky_13 View Post
Karthik did you manage to get body colored parking sensors or got them painted ? I too am thinking about installing parking sensors but don't want to go with black ones, they look like someone punched a black hole in the bumper.
Silver and Black colors are readily available in Xenos galleria.
if you need other colors, they will do it for 500 bucks extra and takes 4 days.
aks_karthik is online now   Reply With Quote
Old 9th April 2009, 10:02   #108
RedOne's Avatar
Thanked: 19 Times
aks_karthik, Did you get the car cover? Concord says both mats and car cover are not available. In fact, no accessory is available currently but is on order? What about your dealer?
Gears,
Red-One.
RedOne is offline   Reply With Quote
Old 18th April 2009, 22:36   #109
Thanked: 215 Times
Gears,
Red-One.
Mats and Car Covers are readily available in VST Motors.
Mud Flaps will be coming soon as per the sales guy.
I'll check with Tata CSM and let you know.
Old 18th April 2009, 22:46   #110
Thanked: 215 Times
Just travelled 1200+ kms to my native and came back to Chennai with 5 adults and fully loaded boot.
Got around 19.3 kmpl with 100% AC including 300+ city driving.
reached almost 175 kmph @ 4300+ rpm top speed.But little bit panic after 150 kmph.
Car was very solid at any speed.
But the only negative thing is ,it scraps bottom often even in small speed brakers and potholes.
need more care on passing speed brakers and potholes.
will add more on monday with some nice photos.
Crossed 2750 kms.
Old 19th April 2009, 21:39   #111
-xplora-'s Avatar
Thanked: 230 Times
Crossed 2750 kms.
Excellent FE ( was it the trip comp or a manual calculation ? ). And good to hear that it goes till 175kmph without major hassles. I agree for GC, although it is an issue with several cars that have near bout GC, except the likes of SX4 etc.
-xplora- is offline   Reply With Quote
Old 19th April 2009, 23:08   #112
Thanked: 215 Times
Yep it's manual calculation(Tank fill method) .Trip comp shows 19.7kmpl only.
About GC,i used to travel the same stretch with WagonR,Accent Viva,Verna Crdi,M800 and Zen.
I never faced sraps/GC issue.
Old 19th April 2009, 23:19   #113
neeld's Avatar
Thanked: 101 Times
Thumbs up
Today morning while coming to office,i engaged 5th gear,the car is like driving in a cloud/Air.Very smooth and handling is very good.
I turned the car almost 70 Degree in 80Kmph speed.the car handled it as a dream.
I usually did it in my Old WagonR/Indica.it screamed like anything and we felt under/over steer.
I think the European engineering comes to work on the handling part .
neeld is offline   Reply With Quote
Old 22nd April 2009, 01:43   #114
GROUND CLEARANCE!!!!!!!
Common check out civic and you will feel any car in india will have better ground clearance.
but the good thing with civic is within 2 or 3 hits you will understand how to avoid getting hit in bumps without reducing the speed. its like at first left side front tyre has to go over bump followed by right side front tyre and then comes back side tyres(first right & then left)..you will avoid these hits..
deepanonline is offline   Reply With Quote
Old 22nd April 2009, 09:47   #115
Thanked: 215 Times
Yes both Civic and Linea have GC 160mm only.
But linea has little stiffened suspension setup than civic.
still Llinea hits almost all bumps when fully loaded (5 Adults with heavy load in trunk).
we can avoid it easily.but we need some extra car while driving in good speed.
roads in Country side and railway crossing have some big breakers and potholes.
we unable to avoid those without scracthing the bottom of our car.how much care we could have taken.
Old 22nd April 2009, 19:00   #116
trrk's Avatar
Thanked: 12 Times
You have my NHC for company. In my recent trip to Tamil Nadu, I found that beyond a point (with 4 people and luggage) the car will scrape the speed breaker.
trrk is offline   Reply With Quote
Old 22nd April 2009, 23:28   #117
-xplora-'s Avatar
Thanked: 230 Times
Wow ! I wonder how do you do that when its full-traffic. Linea does scrape when there is more load.
As mentioned, I think "Indianization" of the cars is a bit too on the optimistic side or rather they might have taken an average. ie how many of us will drive the car with 4+ adults in it vs. how much of time we spend alone or with one more in the car. Still would have preferred a wee bit more GC 170 maybe ?
Old 27th April 2009, 09:57   #118
Thanked: 215 Times
Below are my few observations needed to be taken car at the time of First service.
1. Steering column creaking sound (very irritating)
2. Door Rattling (All doors especially Rear Left door. Panel gap is evident, so the vibrations)
3. Shock Absorbers (Heard a lot of booming sounds)
4. Door handle in Rear left (opening the door is cumbersome)
5. Boot Lid rattling sound (hear some noise while opening the boot using remote)
6. Fuel Lid is not working properly.
7. Glove box is not closed completely (Panel gap is evident)
8. Head light adjustments. High beam is not efficient in Highway driving.
Beam is fallen very near, so distance hurdles can not be seen.
9. Outside air/smoke will be coming in while AC recirculation is activated.
10. Screeching noise while braking in slow motion. (It’s not because of ABS. I tried some other car having ABS)
11. Speakers jarring to be checked.
12. Steering alignment is not appropriate.slight turns to the left.
13. Front bonnet has a bend near the nose.
14. A small scratch in the Left Front door and Front Bumper Underbody.need to repaint it.
Planned to give service by this week or next.
Old 27th April 2009, 10:12   #119
Thanked: 105 Times
@aks_karthik: You should write to Fiat about these issue. Its a quality issue for sure. Whenever I go to service my Palio, lot of such minor issues I see in each Linea comes for service.
pawan_pullarwar is offline   Reply With Quote
Old 27th April 2009, 11:11   #120
I also had this steering alignment issue. While car goes straight, steering was tilted slightly left side. & if you straighten the steering, car slightly goes to right side. Dealer sales exe first & then service advisors tried hard to convince me that its normal & the alignment machine is not detecting any gap. But I persisted & asked them to rectify it. They did it after 2-3 trials.
Am not facing other rattling/ squeaky noises yet or may be not noticed
VahanPujari is offline   Reply With Quote
VW Vento Highline TDi, My Silver Streak - 5 years, 78000 kms and still raring for many more souravc Long-Term Ownership Reviews 147 27th June 2016 10:16
A Beauty in Shimla - Pontiac Silver Streak! Cyrus43 Vintage Cars & Classics in India 19 1st July 2011 16:26
Escape Velo'city' - Polished Metal Metallic V-AT (Quasar) joins Silver Streak, Shadow foodie Test-Drives & Initial Ownership Reports 5 11th May 2010 13:14
Silver Audi A8, REAL silver! karthik247 The International Automotive Scene 6 5th September 2005 01:52
