Old 20th March 2009, 11:56   #1
maverickxx2006's Avatar
Thanked: 47 Times
Default Palio Multijet - Starting vibration
Question to all Palio Multijet owners -
During test ride of Palio MJD, when I turned on the ignition, I felt like there was an earth quake and the car shuddered while starting. Thereafter it was silent. Is this normal? I' am not sure if the problem was in the TD vehicle. The salesperson said its common.
So just wanted to know from you folks -
1. If this is normal?
2. Has the vibration (during starting) reduced or increased after some usage.
I didn't find this problem during starting of Indica vista quadrajet.
Thanks!
maverickxx2006 is offline   Reply With Quote
Old 20th March 2009, 12:59   #2
lightpower's Avatar
Thanked: 15 Times
Except that starter motor goes for 2 revs extra than a Petrol there is no Earth shaking vibrations. I always depress the clutch fully even if in Neutral while starting. Don't know the reason for it but got used to.
lightpower is offline   Reply With Quote
Old 21st March 2009, 16:03   #3
Thanked: 68 Times
In fact, that's what the manual that came with the Palio MJD says, "Start the car with the clutch fully depressed".
I haven't seen any earth shaking vibrations in many Palio MJD. I believe there is some problem with the TD car. I suggest you get into another car in the showroom and check the noise level.
lejhoom is offline   Reply With Quote
Palio Stile Multijet Vs. Swift DDiS Vs. PalioStile1.6 Vs. Indica DiCOR Vs. Getz CRDi maxbhp The Indian Car Scene 524 20th July 2009 22:41
16000 kms with Fiat Palio Multijet architect Test-Drives & Initial Ownership Reports 204 7th March 2009 15:37
My new Palio Multijet aushdeep Test-Drives & Initial Ownership Reports 98 26th August 2008 01:55
wobbling/vibration problem in palio 1.6 Rahulkool Technical Stuff 31 7th April 2008 14:48
Fiat Palio Stile 1.3 MultiJet anymenu The Indian Car Scene 18 21st January 2008 20:07
