Old 31st July 2009, 15:52   #406
FastLove's Avatar
Thanked: 99 Times
Originally Posted by VahanPujari View Post
Another peculiar thing I faced today while coming home late evening. I was 2-3 kms away form home & suddenly found great difficulty in changing gears. It was B2B traffic & Clutch-Accelerator-Break was constantly on. Gears suddenly stopped working. In running car, after much much difficulties I was able to shift it from neutral to 2nd which was the only gear working. Drove for around 500 meters & then noticed that clutch seems to have sticked & was not coming out fully. Had to pull over the car to roadside & pulled out the clutch by hand. And the gear shifting became normal again. In fact, Gears became much more smoother after I applied higher force left/right/up/down when gears were not engaging.
Anyone of you face any sort of similar thing?
VP - are you refering to your FIAT Linea?? i think this is a joke. i have not heard of something like this before . if it really is the case , you should first rush to the TASS. I hope you already have !
and btw , i thought you were not in mumbai !
FastLove is offline   Reply With Quote
Old 31st July 2009, 17:31   #407
I have also faced such situation but not in Linea It was Maruti 800 that I used to drive about 9 yrs back. The gear used to stuck. sometime it used to stuck at reverse and sometimes on 3rd gear. I used to drive the car for about a km or so and then it used to get back to normal .
I am shocked you faced it in Linea.
nicesachin is offline   Reply With Quote
Old 31st July 2009, 18:10   #408
FastLove - This actually happened & I was scared to be left stranded on the road thinking some gear cable or clutch cable seems to have given way. But since, imdtly afterwards, it works really fine, I did not think of it as serious. Lets see. The car was not run for 15 days. and this was the 1st day post that.
Originally Posted by Sunilrj View Post
VP had you given the car for a full service including underbody / engine bay wash just before you left it on its own for 15 days ?? i also read that its been raining in Mumbai quite heavily since the past few days and am sure it was raining heavily during the first part of those 15 days. if yes all the car needs is a good long drive to heat up and drive all the moisture away from inside the components.
I also think so. Thats why have yet not visited TASS. Lets see how it goes for next 2 days
VahanPujari is offline   Reply With Quote
Old 31st July 2009, 19:28   #409
luky_13's Avatar
Thanked: 116 Times
Vahan, even i faced a similar situation once with my Zen. Was in a traffic jam for a long time, and clutch started behaving abnormally. Pulled over to the side and turned off the engine for 15 mins and everything was back to normal.
Another thing i forgot to mention in my 10K Linea update, while driving back from Ooty last week. Driving downhill at the ghat section for about 45 mins an "ABS Unavailable, refer handbook" message flashed on the car console, the amber ABS light on the dial came on, beeping at regular intervals. The braking was normal though. After madhumalai i pulled over and turned off the car for 15 mins. Started and the ABS light had disappeared. I guess the brakes had overheated on my way downhill. Nothing alarming but i thought Lineans should know !
luky_13 is offline   Reply With Quote
Old 31st July 2009, 20:45   #410
Thanked: 29 Times
I meant if leak is there & u park in sun for long than also clutch doesnt release but after 3-4 pushes it works fine.
Ohh Clutch Cylinder Leak? Since yday incident, I've not faced any issues with either clutch or gear. Thinking of obseving 1-2 days more. If issue does not arise, then will show it to TASS only when I scheduled to visit them after 15-20 days for some work. Is this Ok or is this an issue that needs immediate attention?
Yes, my car remains parked under the Sun always but never faced any such issues earlier in my Ford Ikon
oxymoron is offline   Reply With Quote
Old 1st August 2009, 10:17   #411
How do I know if leak is there?
BTW, When it happened, first the clutch was stuck not the floor but 1-2 inch above floor. When I pushed it hard 4-5 times, it improved slightly & I could engage atleast 2nd gear. After a minute it again stuck at the same place & refused to come up even after several frantic hard pushes. Actually it was damn scary. Was just released out of the traffic & was on clear road with cars moving around in speed now. Thankfully, because of the speed/ motion of my car, was able to pull over to roadside in motion & did not have to push it.
Though, it was perfectly normal yday - no sign of anything similar. Hope it stays the same way & hope that experience was a freak rare occurance
Thanks. Pleased to know its not serious & not entirely out of the way
Yes. Could be the case of brake overheating due to prolonged Engine Braking on downhill
Ouch!! This term for us makes me Roll Over the floor laughing everytime its mentioned
Old 1st August 2009, 12:49   #412
coolboy007's Avatar
Thanked: 1,441 Times
VP and F red Linea onwers,
Today i saw a brand new Flamenco red Linea with temp numbers and a family sitting inside (maybe they were bringing the car after delivery) and boy oh boy never seen so much shine on a red Linea.
I swear, dont know what paint protectio coating he got or if its the effect of paint being done at new fiat paintshop but the shine was way too awesome.
I was in Scorpio, if would have been in Linea would have stopped and asked him if he got any coating done?
If anyone gets to witness new Linea being painted at Fiat paintshop espeically in red colour, do tell me if really there is a diff or that man must have done some polishing.
What a beauty..
coolboy007 is offline   Reply With Quote
Old 1st August 2009, 13:10   #413
After looking at awsome red color on Punto, I was always suspecting that Linea colours would also be changed in new batches of Linea. Punto colors have deep gloss. If thats the case we initial Linea-owners are llike this
BTW, another Saturday. Another chance of my Linea to display her Multiple Personality Disorder. Another drive with 16.1 kmpl FE (100% AC ON), of course @ 50 kmph avg speed
Yday night while going back hom, it gave me FE of 7 kmpl @ 16 kmph avg speed. But today being Saturday, its my day !!
Old 2nd August 2009, 03:31   #414
Tom Sunday. I've to do something tom for that stolen Badge space without which those 2 holes look ugly & I'm going to Goa again for 3-4 days
Old 2nd August 2009, 06:53   #415
Sunilrj's Avatar
Thanked: 538 Times
What a beauty..
coolboy, the gloss is due to paint protection / polishing. most probably he has done the waxoyl treatment. tata has a tie up with wuerth, waxoyl and 3M for paint protection and surface polishing. waxoyl is not taken by many as it costs about 1000 more than 3M. even dealers dont push waxoyl as their margin is lesser with waxoyl than 3M
Sunilrj is offline   Reply With Quote
Old 2nd August 2009, 16:03   #416
Trying to be a Playboy ? Huh..
Guys, check this out & let me know if I should put this temporarily in place of stolen badge.
This is how it looks from far
Fiat Linea 1.4 FIRE Emotion Pack (Petrol) - My Dates with the RED Beauty !!!-20090620058r.jpg
From slightly nearer
Fiat Linea 1.4 FIRE Emotion Pack (Petrol) - My Dates with the RED Beauty !!!-20090620059r.jpg
And Close-up
Fiat Linea 1.4 FIRE Emotion Pack (Petrol) - My Dates with the RED Beauty !!!-20090620055r.jpg
Old 2nd August 2009, 16:56   #417
bnzjon's Avatar
Thanked: 125 Times
Amit, sorry to say that the Linea doesnt deserve to be like this.
Please, get the logo for one last time (my god, is there an option to get it insured ?). The sticker spoils the whole look of your beauty.
bnzjon is offline   Reply With Quote
Old 2nd August 2009, 19:35   #418
dude, blue color on the sticker doesn't look good. maybe a silver&red sticker would look good.
Although the playboy sticker looks kinda cool
But again, whats the point. You can't drive with a sticker forever na :(
neotraveller is offline   Reply With Quote
Old 2nd August 2009, 23:27   #419
Yes. I also thought so. Blue color is spoiling it. The generous look is compromised.
No, she won't be without Logo forever. I'm looking for a decent temporary solution only till monsoon lasts as there will be times I won't be able to put covers on & in that case even if I purchase logo right now, it'll be gone the next day.
I've 3-4 smalled playboy images in Red 2 of which I can use on Blue or I'll have to 'silver out" the Blue color !!
Old 3rd August 2009, 00:04   #420
Guys
Look at this pic which I posted earlier also. Car (Skoda?) with stolen Badge. I took the pic when I was behind this car in my Linea
Linea 1.4 Petrol E-Pack - Emotional(ly) Pack(ed) Experience rhenius Test-Drives & Initial Ownership Reports 127 25th October 2010 17:31
My Linea MJD Emotion Pack Flamingo Red opendro Test-Drives & Initial Ownership Reports 129 26th April 2010 10:40
My flaming red Fiat Linea Emotion pack arrived at last thumpingbull Test-Drives & Initial Ownership Reports 16 10th April 2010 00:06
Fiat Punto 1.4 FIRE (Emotion Pack) from Pandit Auto (Pune). Edit: First Service done EssYouWe Test-Drives & Initial Ownership Reports 51 21st January 2010 20:16
Punto MJD Emotion Pack or Linea MJD Dynamic Pack atilla Hatchbacks 1 4th August 2009 14:16
