Old 20th April 2009, 09:14   #1
Default Maruti SX4 - Squealing sound while starting
Hi All,
I bought a SX4 in Oct 2008 and has driven it over 7000 kms.
Whenever I start the engine after a long break (more than 4 hrs), I hear a squealing sound - like something is jammed. This has been there right from the begining but now it has become so unbearable.
Could you please tell me has anyother SX4 owners in this forum has experienced this or know what might be the reason?
thanks
rdee
rdee is offline   Reply With Quote
Old 20th April 2009, 10:37   #2
Thanked: 298 Times
rdee,
I have a one year old SX4 and have not faced any such problems. What does MASS have to say abou the problem and have you brought it to their notice when you got your car serviced.
rajneeesh is offline   Reply With Quote
Old 20th April 2009, 10:42   #3
wanderernomad's Avatar
Thanked: 805 Times
Check your engine belts. Most probably the alternator belt.
wanderernomad is offline   Reply With Quote
Old 20th April 2009, 11:01   #4
krish3's Avatar
Thanked: 21 Times
I too had it in my ZEN where i used to hear a prolonged sqeal when I first start the car with hand-brakes on. But it automatically vanished after a service. There was nothing in the bill to suggest any work done on it.
But they said that my rear brakes were jammed and they had replaced the rear brake master cylinder and something else. Dont know if this squeal was related to this. Why dont you check yours for the same (even though this might not be the problem)?
krish3 is offline   Reply With Quote
Old 20th April 2009, 11:09   #5
There could be a problem with the Timing Belt, too tight a belt which has also damaged one of the bearings. Please get it checked immediately as your car should be under warranty.
This is just a wild guess and I am not an SX4 owner.
sandeep.mishra is offline   Reply With Quote
Old 20th April 2009, 11:18   #6
sudev's Avatar
Thanked: 2,649 Times
Most likely alternator or a/c belt. Try switching on the car with a/c at off position. If the sound disappears then it is the latter.
sudev is online now   Reply With Quote
Old 20th April 2009, 11:20   #7
im_srini's Avatar
Thanked: 398 Times
Post Belts need tightening
I second this If the sound is a loud squealing sound on start-up & lasts for 30 seconds or so, just have your alternator belt checked for proper tension. If it doesn't solve your problem, have the rest of the belts checked too.
im_srini is offline   Reply With Quote
Old 20th April 2009, 11:22   #8
rkbharat's Avatar
Thanked: 613 Times
I have not experienced it my SX4 but had similar problem in Indica
Does this sound continue while you drive or goes after some time? Could be Fan belt/AC belt, check as suggested by Sudev Saab
Originally Posted by rdee View Post
Hi All,
thanks
rdee
rkbharat is offline   Reply With Quote
Old 20th April 2009, 11:25   #9
Thanked: 141 Times
@ rdee, for some reading and understanding please go through http://www.team-bhp.com/forum/techni...t-s-sound.html (what's that sound??)
Since you can replicate this by waiting for 4 hours I would suggest take it to the service center and show them what it is, to identify and correction. To reproduce the mechanics put water on to the belt so that it cools out faster with water than normal cooling (in your case wait for 4 hours)
In the mean time watch it out to find exactly when it is squeeling (reverse / engaging clutch / AC on, parking etc) so that the identification can match with your finding.
Possible culprits are rubber belts (water pump alternator A/C) - which require tightening / replacement as necessary.
I had the similar issue and in my case it was not reproducible since it didnt appear all the time and only the first start of the day (that too not often). Hence just tightened the belt and on the observation period now. keep us posted on the outcome and solution for the benefit of others.
Cheers! narayanang76
narayanang76 is offline   Reply With Quote
Old 20th April 2009, 11:26   #10
neoranjit's Avatar
Thanked: 191 Times
I get this in my car too. And was told ( by other bhpians ) that its the belt noise . I get this when I switch on the AC in less than a minute after starting the car.
If I switch on the AC after about 5 mins, I dont get any noise. Assuming this should be taken care of while servicing the car this week
neoranjit is offline   Reply With Quote
Old 20th April 2009, 11:27   #11
sjcherian's Avatar
Thanked: 362 Times
Had the same exact issue in the Swift. Was annoying me for quite a while till I took it in for service and mentioned. This happens only after starting up the vehicle after a break of 4+ hours. Otherwise the sound goes away. Fan belt loosening up is definitely the issue. Do check it out with your service center.
sjcherian is offline   Reply With Quote
Old 20th April 2009, 13:14   #12
Rehaan's Avatar
Thanked: 25,038 Times
Please SEARCH the forum before creating new threads. All this information already exists.
http://www.team-bhp.com/forum/techni...uld-sound.html (What could this sound be?!)
http://www.team-bhp.com/forum/techni...ise-800-a.html (Strange noise from 800)
http://www.team-bhp.com/forum/techni...-starting.html (Indica Turbo --Screeching sound while starting??)
http://www.team-bhp.com/forum/techni...my-esteem.html (Squeking Sound From My Esteem)
cya
R
About Squealing Brakes idrive Technical Stuff 24 31st May 2015 10:37
Weird squealing/hissing noise from the back srinath_mys Technical Stuff 4 24th May 2010 20:38
Squealing Getz.. Nilesh5417 Technical Stuff 14 22nd July 2009 11:23
Low volume high pitched squealing noise in Siena 1.6 ece2k2 Technical Stuff 3 18th August 2007 20:53
Indica Turbo --Screeching sound while starting?? werfish Technical Stuff 8 4th March 2007 14:18
