Old 7th June 2012, 19:33   #1681
Originally Posted by mail4ajo
Guys, what difference are you seeing on the dashboard fuel efficiency figures compared to actuals?
I see a variation of 1 - 1.5km.
My Jazz also has similar variation. 0.8-1 when driven on highway and around 1.2 in the city. I had suggested the SM guy to reset the ECU. But he did not agree. Any other suggestions to reduce this variation ?
kbrtz125 is offline   Reply With Quote
Old 7th June 2012, 22:32   #1682
mail4ajo's Avatar
Thanked: 261 Times
Default re: Review: 2nd-gen Honda Jazz
Do not think an ECU reset will help. I tried it. Looks like that how its build into the system. My face glowed when I saw 22.3km/l on my last trip to BLR.
mail4ajo is offline   Reply With Quote
Old 9th June 2012, 00:35   #1683
Thanked: 27 Times
Default Beat low end torque but preserve FE - possible?
To overcome the Jazz's low-RPM lethargy, many posts have suggested that the car be driven "enthusiastically" - a term which I understood to mean upshift late / downshift early and let the engine run at high RPMs.
Doesn't this driving style affect the FE adversely? Or is the ivtec designed to run at higher RPMs?
I'm a bit confused because during my test drive, I was told that the best way to maximize FE was to drive in the higher gears as far as possible. Demonstrating this technique, the sales guy drove the car in 4th gear while at 25-30 kmph in city traffic. As promised, the instant FE meter went all the way up when he did this!
qaqa is online now   (1) Thanks Reply With Quote
Old 9th June 2012, 07:26   #1684
gkrishn's Avatar
Thanked: 37 Times
Default Re: Beat low end torque but preserve FE - possible?
The higher the rpm, the more the fuel that will be consumed. i-vtec or not.
If you want to extract fe from jazz then it needs to be driven around, a bit, lethargically!
gkrishn is offline   (1) Thanks Reply With Quote
Old 9th June 2012, 08:49   #1685
aravind.anand's Avatar
Thanked: 2,043 Times
Though I agree that higher rpm = more fuel consumed, lower rpms is not always equal to better efficiency!
Consider the following cases-
  • Car is in 5th gear at around 40 kmph (about 1000 rpm), the car in front slows down / obstacle ahead, so I slow down to 30 kmph (800 rpm, so barely any torque to accelerate and pull the car) , now I want to speed up to 40 kmph again, so instinctively, I stomp the accelerator, and slowly speed rises to 40 kmph, in about 10 seconds. So the car is driven with full throttle condition for 10 seconds.
  • Similarly, Car is in 3rd gear at around 40 kmph (about 2500 rpm), the car in front slows down / obstacle ahead, so I slow down to 30 kmph (about 1500 rpm, better torque to surge ahead), now I want to speed up to 40 kmph again, a gentle tap on the pedal for about 8 seconds will get me there!
So 'Lugging' the engine would never help one get better fuel efficiency figures, i-Vtec or not!
aravind.anand is offline   (1) Thanks Reply With Quote
Old 9th June 2012, 09:08   #1686
Parthasarathig's Avatar
Thanked: 494 Times
Originally Posted by aravind.anand
!So 'Lugging' the engine would never help one get better fuel efficiency figures, i-Vtec or not!
But ideally youd downshift and probably at 40kmph i doubt if youd be in 5th gear. Trick is to keep the rpm between 1500 to 2500 for maximum fuel effeciency. Thus change gears effectively to maintain that rpm.
Parthasarathig is offline   Reply With Quote
Old 9th June 2012, 10:12   #1687
Thanked: 27 Times
That's interesting. I thought that the Jazz remains sluggish till ~2k RPM (Jazz owners, correct me if I'm wrong). So, effectively, the car needs to be driven in a narrow range of 2000-2500 RPM to get decent FE and torque.
Seems to be a tough ask, especially for the not-so-careful drivers like me..
qaqa is online now   Reply With Quote
Old 9th June 2012, 14:21   #1688
Not necessarily, though all Honda engines lack the low end juice, they are pretty fuel efficient. So driving your Jazz between 2000 and 3500 rpm would not grab a huge slice out of your economy pie. My personal view is that, the slight deterioration in fuel efficiency is well worth all the extra fun that you have compared to life at 2000 rpm
Edit: Figure this - the best fuel efficiency I managed to squeeze out of my Dad's Honda City is 12.2 Kmpl, but the worst I have got, with carefree driving, top speed tests et all is 10.93! So I prefer the adrenalin rush compared to the 1.3 kmpl I save
aravind.anand is offline   Reply With Quote
Old 9th June 2012, 21:14   #1689
Thanked: 27 Times
Default Real world FE and ride
If I were to drive a bit "enthusiastically", what kind of FE can I expect ? Since most of my driving will be in the city, I don't expect to cross 3rd gear very often.
I heard that the ivtec's aggressive cam kicks in at speeds > 90kmph, killing the FE. What kind of real-world numbers can I expect for highway driving, doing say 90-100 kmph for extended periods?
How does the Jazz's ride compare against the new Swift, at city speeds? Is the new Swift's ride as harsh as the Jazz?
Old 9th June 2012, 21:36   #1690
misquitas's Avatar
Thanked: 272 Times
Edit: Figure this - the best fuel efficiency I managed to squeeze out of my Dad's Honda City is 12.2 Kmpl, but the worst I have got, with carefree driving, top speed tests et all is 10.93! So I prefer the adrenalin rush compared to the 1.3 kmpl I save.
Don't know about the FR of the Jazz, but complaints have begun to surface regarding the build-quality, ride-quality and fuel economy of the small Brio. Check out the following post and the posts below it:
http://www.team-bhp.com/forum/offici...ml#post2801852 (Honda Brio : Test Drive & Review)
Let hope the problems, if any, are specific to the Brio. I'm seriously considering a Jazz/Ertiga or a Sumo/Bolero as my next car and I would certainly not want a beauty like the Jazz to have a poor FE or poor build-quality.
misquitas is offline   Reply With Quote
Old 9th June 2012, 22:08   #1691
vb-san's Avatar
Thanked: 4,657 Times
Unlike the Brio, Jazz is a proven vehicle in different markets, and even on our forum, there are quite a few long term reviews from very satisfied Jazz owners. Personally, I find the Jazz build quality top-notch.
With Brio, the said niggles maybe due to the fact that it was build to play the cost advantage.
vb-san is offline   (1) Thanks Reply With Quote
Old 9th June 2012, 22:12   #1692
misquitas's Avatar
Thanked: 272 Times
It's good that Jazz build quality is top notch and it certainly has a loyal following. I'm one of them. If there were a Jazz lover club, I'd probably have been a life member!
In fact, wife and I went to a Honda showroom here in Panjim, but unfortunately, the TD vehicle was at its other branch at Verna, 25 kms from Panjim. So, our TD has been postponed for now.
Old 9th June 2012, 23:09   #1693
Thanked: 494 Times
I can only comment about the highway driving part. After the first 1000kms as you know the engine shapes up pretty well. On my very new honda city which had done only 600kms i managed to squeeze out 13kmpl on the hills and around 16 to 17kmpl on the plains. Im known to be a very sedate driver. You can see my posts on the figo thread, my petrol figo has given me mileage of upto 18 to 19kmpl when driven very sedately. Even the i-vtec has responded pretty well to my driving pattern and hopefully you'll be able to get good mileage out of your car too. At 90 to 100 kmph constant speeds you can expect 15kmpl at the most i guess.
And regarding the previous posts, my honda city even pulls in 3rd gear at speeds of 30kmph without a hassle. Probably cause the engine hasnt completed the break in period?! And jazz is known to be a better car than the swift. If my choice wasnt a sedan, i was going for the jazz.
Parthasarathig is offline   (1) Thanks Reply With Quote
Old 12th June 2012, 09:38   #1694
_Vyenky's Avatar
Thanked: 13 Times
At last after almost 15 months I will finally book the Jazz in 2-3 days.
I will try to see if I can get some accessories free. But if not, I have a list of accessories which I feel important but Money factor may prevent me to do so. Can existing Jazz owners and experts help me in decide must have accessories.
1. Seat Covers.
2. Sun Film
3. Carpet Lamination.
4. Mud Flaps
5. Mats.
6. Reverse Sensors.
I also feel I should opt for 3M underbody coating and paint protection.
From above list, Seat Covers and Sun Film will charge the most.
Please help me in deciding the accessories list.
Vyenky
_Vyenky is offline   Reply With Quote
Old 12th June 2012, 11:24   #1695
Thanked: 230 Times
If you are booking other than X model, seat covers may be necessary since the seats are beige.
Sun film - in view of the ban on films, I suggest you wait a while. While the Jazz does cry out for film in our climate, wait and watch better for time being.
Door pad lamination (they are beige too) may help more. Just put mats of your choice on the carpets.
Car comes with mud flaps.
Reverse sensor is the mirror type, which I am not too fond of, but again your choice if you feel you cannot judge the rear.
3M underbody and panel rust protection is a must, IMO.
sandeep108 is offline   (1) Thanks Reply With Quote
The 2015 Honda Jazz (3rd-gen) JayPrashanth The Indian Car Scene 1642 8th July 2015 14:03
Honda issues recall for faulty power window switch on 2nd-Gen City Achyuth Vaibhav The Indian Car Scene 13 3rd July 2013 09:46
Honda to raise car prices, and Jazz launch soon. EDIT : Jazz spotted testing on pg.14 GeekSrik The Indian Car Scene 463 9th March 2010 11:17
Honda/Toyota cars considered very boring by 2nd Gen NRI kids? pgsagar The International Automotive Scene 23 6th February 2010 21:11
