Old 6th August 2009, 17:37   #346
aqualeo2040's Avatar
Thanked: 248 Times
Originally Posted by manjo View Post
Please let me know what is the magic behind this...
Mine is showing just 12.6..
Originally Posted by smilenow View Post
Hey amogh,
What the $%$&?
I am getting 11kmpl,but this is my first diesel,
disclose some of that fe magic,my walet will love you for that.
P.s. average speed of my punto is 19km/hr in Delhi,seems to me,the neela aur main lady will shout back one of these days "should have bought a bicycle instead"
Guess its the experience and Pune traffic. I'm getting between 12 & 13 in Blr traffic. Avg speed is 19km/hr.
aqualeo2040 is offline   Reply With Quote
Old 6th August 2009, 18:48   #347
Originally Posted by VahanPujari View Post
The difference is city my friend. Mumbai B2B traffic.
If you wanna check, pls check your avg speed on MID
If not that, then comes driving style
Manjo
now let me guess your avg speed basis your FE & amogh's FE @29kmph
as per my gustimate, your avg speed on MID should be around 20. pls check
VahanPujari is offline   Reply With Quote
Old 6th August 2009, 20:09   #348
amoghchaphalkar's Avatar
Thanked: 257 Times
Well .. 19-20 km/hr average speeds are terribly low (not that 29 km/hr avg speed is good !!)
Avg Speed : 19 km/hr - FE : 13 km/lit
Avg Speed : 29 km/hr - FE : 18 km/lit
For 52% more average speed I am getting 38% more fuel efficiency ??
Amit is also getting similar FE to what I am getting. And I am pretty sure his average speed is better than mine.
In any case, here is how I drive my car.
First thing when I start the car, I keep the engine running at idle for around 30-45 secs. Only then I shift into first gear.
While driving.. I make sure that the rpm stays between 1100 and 2200. Punto does stroll happily in higher gears at low rpm. But if you check the "Instantaneous Fuel Consumption" .. it starts shooting up if you drive at low rpm's in higher gears. So I make sure that I am maintaining the right rpm - gear combination.
Tip : To check how the engine responds to your driving style set the on board display to "instantaneous fuel consumption" and observe how the figures change.
I am pretty sure if you do this over a considerable amount of time you will tone your driving style to achieve optimum fuel efficiency.
amoghchaphalkar is offline   Reply With Quote
Old 6th August 2009, 21:11   #349
Thanked: 85 Times
Yep,been doing that for the past 3 or 4 days,have raised the, f-e from 11 to 13 by observing the instantaneous f-e stat tracker,thank you so much for the advice,one question though... why the idling engine at the start?
smilenow is offline   Reply With Quote
Old 7th August 2009, 07:33   #350
Thanked: 257 Times
Well.. just a habit. I have been doing this for all my cars.
I think its always better to warm up an engine before you start putting it through its motions.
Even we humans do a warm up before starting to work out dont we ?
One more thing : I observed this when one of my friends was driving a Punto. He is used to driving a Hyundai and Maruti and this was the first time he was driving a Fiat.
Since he was not used to the "long" clutch play of the Fiat, I observed that he was not releasing the clutch fully. The on board display was on instantaneous fuel consumption mode. When I asked him to take his foot off the clutch the FE figure jumped by almost 1.5 - 2.0 km/lit.
Old 7th August 2009, 08:14   #351
Ravveendrra's Avatar
Thanked: 406 Times
Warming up while stationary will affect the overall FE figure. Manufacturers now recommend that you drive off as soon as the engine starts and to go easy on the acceleration for the first few minutes.
The GP has a hydraulic clutch and there will be no 'play' in the pedal (at least on a new car). What you are referring to is the pedal 'travel'. Riding the clutch even marginally causes more damage in the form of wear and tear on clutch and pressure plates, clutch release bearing etc. in cabled clutches (Hyundai & Maruti) than on the hydraulic variety. Advise your friend to lose the habit as soon as possible.
Cheers,
Ravveendrra is offline   Reply With Quote
Old 7th August 2009, 09:59   #352
Thanked: 630 Times
Default Prob with gear lever..
@amogh,
My gear lever moves up and down while I accelerate and break, though the movement is very small, I find it uncomfortable. Are you also feeling the same with your gear lever?
CliffHanger is offline   Reply With Quote
Old 7th August 2009, 10:04   #353
manjo's Avatar
Unhappy will check.. a small question too..
Manjo
Will get back in the eve wen i get to the car. I use the instantaneous fuel consumption mode nowadays and i changed my reading from 11.5 to 12.6
but sometimes i tend to do so much a feather touch that i have to move from 5th to 4th even if its a slight incline. I will keep track of the RPM too and see.
One other thing; i take my GP twice a week for a full body water service. They asked me if i want to do a engine bay + underbody cleaning too.
I thought the underbody is fine, but will the engine bay cleaning be fine, its a local waterwash centre.
And day before wen i was getting it serviced i noticed that the reversing light has come got loose, is rather hanging. i pushed it back into position but still feels not perfect. Should i take it to the dealership immediately?
Also my bonnet release inside is loose, came off while driving ones.
manjo is offline   Reply With Quote
Old 7th August 2009, 14:43   #354
Thanked: 257 Times
Cheers,
Thanks Ravveendrra !! Yeah .. I did mean the "clutch travel" and not the "clutch play"
But one query though : I have read on numerous forums (on TBHP and other websites too) that a diesel engine consumes far less fuel at idling than a petrol engine. So would 30-45 secs of idling have a significant impact on fuel efficiency ?
The reason why I am asking is all the 3 diesel cars we have in the family give excellent fuel efficiency (Octy, Safari and Innova). I will now calculate the FE by driving off as soon as I start the engine.
Originally Posted by CliffHanger View Post
@amogh,
Hi Cliffhanger !!
No .. I have not observed anything like this. I suggest you get it checked from the dealer. I don't see any reason why this should be happening on a new car.
Old 9th August 2009, 12:55   #355
manjo's Avatar
Post
Hi Cliffhanger !!
The attached are my readings...
Fiat Grande Punto : 1.3 Multijet : Emotion Pack : 4000 km report-img_3647.jpg
Fiat Grande Punto : 1.3 Multijet : Emotion Pack : 4000 km report-img_3649.jpg
Old 9th August 2009, 14:23   #356
Thanked: 257 Times
@ manjo
I see that you are looking at the Trip A average consumption.
I suggest you reset your "Trip B" to zero and then track the FE. If you look at Trip A figure, it is bound to be low than what you are actually getting. If anything, it will improve with time.
The reason is "Trip A" includes all the running the car has done from the time it was built / tested at the factory / driven to your dealer's warehouse / driven for PDI etc. And the consumption during these drives is bound to be high (Those drivers are not as careful with new cars as we are. After all, they don't own the cars !!) You can read some "horror stories" about how new cars are driven here : http://www.team-bhp.com/forum/indian...showrooms.html (Transport of Brand New Cars from Factories to Showrooms)
Yes, I do agree that your "Trip A" FE is low. My current "Trip A" FE is 14.7 km/lit.
Ignore the "AcA" figure for the time being, reset "Trip B" to zero and keep an eye on the "AcB" figure.
Hope this helps
Old 9th August 2009, 14:38   #357
kuttapan's Avatar
Thanked: 12 Times
@ manjo
Is Tripmeter A non-resettable? What is he has reset his Trip A figures out from the factory?
kuttapan is offline   Reply With Quote
Old 9th August 2009, 15:07   #358
Trip A is also resettable just like Trip B. What I do - I reset Trip A while filling petrol to tank-full everytime. This gives me tank-full to tank-full FE & also kms reading which helps me manually calculate tank-full to tank-full FE
I reset Trip B to monitor FE, distance, avg speed etc for shorter trips like daily residenace to office etc
Old 9th August 2009, 16:40   #359
Thanked: 257 Times
Oopss .. sorry .. I conveniently assumed that Manjo makes use of "Trip A" the same way as I do (I use Trip A to keep a log of my monthly running .. I have not yet reset Trip A since I got the car)
But looking at the km reading I don't think Manjo has reset the Trip A meter
@ Manjo : what is your current AcB ? (Trip B average consumption)
Is it same as AcA ?
Old 10th August 2009, 14:26   #360
manjo's Avatar
Wink
Is it same as AcA ?
I have not resetted any.. My AcB is same as AcA now..
My wife starts yelling wen i start sitting with my car.. (She is really mad me buying this after a new Innova..)
I will do today and see after a week or so..
Fiat Grande Punto Multijet Emotion PK amit Test-Drives & Initial Ownership Reports 415 9th October 2012 13:20
Grande Punto, Red Emotion Pack Multijet Diesel 9000 km - 4 months - Saga continues SamtheLeo Test-Drives & Initial Ownership Reports 54 12th February 2010 21:30
Punto MJD Emotion Regular v/s Emotion Pack psmith Hatchbacks 15 20th October 2009 09:33
Punto MJD Emotion Pack or Linea MJD Dynamic Pack atilla Hatchbacks 1 4th August 2009 14:16
