Closed Thread
Old 2nd June 2010, 20:47   #841
shajufx's Avatar
Thanked: 490 Times
The latest mileage calculation has dramatically dropped to 10 kmpl (previous tank full at Krishnagiri to today's tank full at Bangalore city). Either I am cheated at Krishnagiri fuel station (which offcourse serves to highway commuters) or something has changed in the engine's drinking pattern. Another thing I noticed is the tire pressure on all tires were around 28 PSI which I always maintain at 30. May be that would be the reason. Fingers crossed until another tank full next week only for mileage checking
shajufx is offline
Old 3rd June 2010, 09:06   #842
Thanked: 7 Times
Could it be cocktail of BS III/IV? Have noticed in some Figo threads that with BSIV FE is higher (figo engine is tuned to BSIV I guess) whereas Fiesta is BS III.
28PSI is way too low for highway driving. How many passengers?
sanjayc is offline
Old 3rd June 2010, 09:44   #843
nairrk's Avatar
Thanked: 36 Times
Infractions: 0/1 (5)
28psi seems low against company's recommended pressure of 30psi in front and 35psi (?) for rear tyres when on normal load. for full load it goes to 39 and 44 (seems very high??). Should one follow this recommendation of maintain 30 for all tyres when on single driving?
nairrk is offline
Old 3rd June 2010, 11:15   #844
Gilead's Avatar
Thanked: 21 Times
I think after your prior claim of 12-14 kmpl, other owners got J and cast evil eyes at your car.
Krishnagiri must be on BS2 fuel I guess. That could be one of the reasons.
Gilead is offline
Old 3rd June 2010, 12:23   #845
shajufx's Avatar
Thanked: 490 Times
Originally Posted by sanjayc View Post
Could it be cocktail of BS III/IV? ......
I doubted the same too. The tire pressure is always maintained at 30, not more not less, because its been tested over a month varying the pressure between 28 to 32 and found to be the best at 30. Remember mine is not stock tires. Somehow we missed checking the tire pressure before our drive to Pondy. ( 3 of us, Unni, Veeresh and myself)
Originally Posted by nairrk View Post
.....for full load it goes to 39 and 44 (seems very high??).
Ha ha, 39 and 44 will be hell of a drive feeling every pothole on the road straight on our spine. I am not sure how high a mileage that can provide but the tires might become vulnerable to damages on a long drive. Whatever it is, according to my limited knowledge, anything above 32 will be a rough ride.
I will sort that out when we drive down to Chennai soon ! Be ready !
shajufx is offline
Old 3rd June 2010, 12:29   #846
nairrk's Avatar
Thanked: 36 Times
Oho., there was a typing mistake, it should have been 30 instead of 39.
i.e in Full load the recommended tyre pressure is 30 (front) and 44 (rear),
but still 44 psi seems bit high?
nairrk is offline
Old 3rd June 2010, 12:41   #847
shajufx's Avatar
Thanked: 490 Times
Is that mentioned in the ford manual ? I dont remember reading such a thing. But somehow, 30 and 44 is a huge difference to maintain from the front and back. I would prefer 30 on all 4 than trying 30-44. If there are 3 passengers on the back seat and boot is full of heavy things, then a higher PSI for the back tires is understandable, but how high ?
shajufx is offline
Old 3rd June 2010, 12:56   #848
vnabhi's Avatar
Thanked: 1,309 Times
As far as I remember (but rarely practise), for full loads it is 35 in the front and 44 at the rear. For normal loads, it is 30 all around.
Only once did I use the full load setting, and it really helped in avoiding bottoming out on huge speed breakers.
vnabhi is offline
Old 3rd June 2010, 13:12   #849
shajufx's Avatar
Thanked: 490 Times
I am curious to know the effect of single driving with that 35-44 combination. Suppose we fill that figure for a long drive with full load and drive around single after reaching the destination or after coming back to our town. Do we switch back to 30 all around ?
Another doubt is about the heat build up that happen on a long drive. A 35 psi could go as high as 40 or closer on a few hours highway drive, so I have seen people letting the air go to adjust the levels midway. Now how is that handled ?
Hope I am not going OT here, we are still sticking to Fiesta specific tire pressure.
shajufx is offline
Old 3rd June 2010, 13:15   #850
ghodlur's Avatar
Thanked: 2,431 Times
Question
I have been maintaining 32 in front and 30 at the rear. I had this setting confirmed by Ford, Thane dealer. In fact whenever I go to my usual petrol pump the attendant by default fills in 32 in the front (his logic - engine in front) and 30 at the rear tyres. Even my spare is filled with 30 psi only.
I am confused as to why the front tyre pressure is less than the rear as reported by some.
Till date I have not encountered the full load, can't comment on the same.
ghodlur is offline
Old 3rd June 2010, 15:11   #851
nairrk's Avatar
Thanked: 36 Times
Shaju, I just checked the Owners manuel - see page no.128, tyre pressure level is explained.
As per your anticipation, if one has to reduce the psi midway, then you definitely need tyre pressure gauge carrying with you all the time to check the correct pressure on all tyres??
nairrk is offline
Old 3rd June 2010, 15:43   #852
vnabhi's Avatar
Yes, you would need to scale down all 4 wheels to 30 in such cases. Else the ride will he hard. Not sure about the heat build up though.
vnabhi is offline
Old 3rd June 2010, 15:47   #853
shajufx's Avatar
Thanked: 490 Times
Ideally maintain 30 on all 4 tires, the safest bet. Back tire pressure more than front comes to picture only when its full load, which I never tried till date. I assume 3 passengers on the backseat and the boot with heavy load combined with the back body weight will definitely double up the front weight. Open to correction.
....see page no.128, tyre pressure level is explained.
......then you definitely need tyre pressure gauge carrying with you all the time to check the correct pressure on all tyres??
I dont follow the manual just because mine is a Michelin XM1+ tire thats advised to be maintained at 30 PSI by the installer, which is also tested and proved to be the best compromise between comfort and mileage. Tire pressure gauge is one of the 'must have' accessories in the car. I got mine as a compliment from the tire guy. Its cheap.
Heat build up is not limited to any tire or car, its a common thing I have heard and seen from different people. In our last trip to coorg, my in-law had let out some air from all tires (Innova) to balance the required PSI. May be its not applicable to latest technology tires. I am not yet sure about it.
shajufx is offline
Old 7th July 2010, 10:43   #854
unni.ak's Avatar
Thanked: 80 Times
Irregular me just saw all the discussion happening here! Let me add to the confusion
Like others here, I too have tried different combinations of tire pressure. When on single driving or even 2-3 up, you can safely maintain at 30psi. This will ensure that you dont have a jarring ride (feeling every crack on the road)
Well, except for Shaju, the other 2 were heavy set!!!
Saar, keep me in the loop.
Heat build up usually happens due to tire flex. When having low pressure, the side walls of the tire flex way more than when filled right. This leads to heat generation. From what I've read on the internet and otherwise, the heat build up and resultant rise in PSI is not something we need to be overly worried about, as long as the tires are filled up properly.
Do not adjust air mid way. Check when tire is cold (that is it has run the minimum amount of kms when starting for a trip), at the nearest petrol pump etc.
Heat build up happens in all tyres. Unless maybe you are using nitrogen! But, like I mentioned, its not something to be overly worried about. Just maintain the right PSI.
unni.ak is offline
Old 7th July 2010, 10:50   #855
nairrk's Avatar
Thanked: 36 Times
Unni - good you back in action !
I hope nowadays you are not driving your fiesta to your native place since you got your family in Bangalore? And no more driving to the 'border' and your fiesta may be feeling sorry (and sleepy all the time except for the bangalore traffic run?)
How much kms on the ODO now?
nairrk is offline
Closed Thread
Ford Fiesta 1.4 TDCi ZXi 60,000 kms. review / Still fida over the fiesta Sugeeta Long-Term Ownership Reviews 60 29th September 2015 12:18
Ford Fiesta 1.4D ZXi Ownership Woes. EDIT : REPLACEMENT FIESTA. Pics on Pg. 5 Mad Monkey Long-Term Ownership Reviews 105 3rd March 2010 15:26
Upgraded - New Alloys and Tires on my i10! NFS2024 Tyre & Alloy wheel Section 23 30th January 2010 15:29
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Query : Tubeless tires / Normal Tires nicejits Tyre & Alloy wheel Section 12 10th June 2009 09:59
