Closed Thread
Old 6th November 2009, 16:51   #181
Thanked: 515 Times
Originally Posted by wind_rider View Post
Hi Anshuman ,
I know that the button is on that stalk , but it is not showing Instant consumption after the " Low Fuel " warning . is this normal .?
Yes, this should be normal. Have experienced similar behavior on relative's Linea.
sukiwa is offline
Old 6th November 2009, 17:03   #182
it kinda acts mad once it drops below into reserve man.. top it up if the fuel reserve lite glows. it showed 54km for me too when i got the car. but the dealer said the tank was empty.. so dont take a chance keep it above reserve whenever possible.
BenedictPentony is offline
Old 6th November 2009, 18:49   #183
.anshuman's Avatar
Thanked: 8,929 Times
Rush to the nearest petrol station as soon as display goes blank as running out of fuel may severely damage Diesel injection system including Pump and injectors.
Another bit about the fuel needle which has already been discussed earlier in a lot of threads is the fuel indicator in Punto/Linea does not instantly recognise refuelling so it takes its own time to wake up, the solution is to switch off the engine and start it again.
.anshuman is offline
Old 6th November 2009, 22:03   #184
Harry1983's Avatar
Great Snaps, Punto in Red looks amazing.
Harry1983 is offline
Old 7th November 2009, 01:35   #185
nkapoor777's Avatar
Thanked: 87 Times
+1 to that.
One question here: I have noticed in my Punto MJD E-pack that the fuel level indicator never reaches the "F" mark completely before the fuel nozzle cuts off on auto mode. The indicator remains slightly lower than the "F" mark. I always ask the attendant to leave the nozzle on auto mode and stop filling when it cuts off. Now, I have had 12 visits to the pump so far and the same behaviour continues despite changing pumps a couple of times. Is it the same with your car?
nkapoor777 is offline
Old 7th November 2009, 16:03   #186
.anshuman's Avatar
I never use the autocut, i get my car filled to the brim whenever i get a tank ful.
Why dont you get the fuel filled up till the cap just to check out if this works for the needle?
Old 8th November 2009, 11:33   #187
I always do a tank full and always seen that the Fuel indicator is at the last white indicator mark at the top. While fueling in, the autocut stops at 38 ltrs. Sometimes I ask them to around it to 40Ltr. Which just comes to the brim.
7 liters is in reserver. I just do the tank full as soon as the 'Low fuel warning' sign come up.
@nkapoor777: You should try a different fueling station, the previous stations seems to have there fueling guage calibrated wrongly (cheating Boss).
divx is offline
Old 8th November 2009, 18:49   #188
arishi1's Avatar
Thanked: 12 Times
Just refilled the car with Auto-cut at 38.05 lt. The Fuel Indicator Needle is at the Last White mark F. I think thats the max it should go. I always go with Auto-cut. I am not expert but have heard from people that its not advisable to fill to brim as there is no space left for Fuel Vapors to build up and this can have adverse impact on the engine. I am not sure how true this is, anyone know if its a myth or is it true?
arishi1 is offline
Old 8th November 2009, 21:32   #189
NutsNBolts's Avatar
Thanked: 20 Times
Similar to Linea, I guess Punto fuel gauge is is also calibrated with 7l per marking, for a total of six markings. Tank capacity of Punto too is 42 liters?
NutsNBolts is offline
Old 8th November 2009, 21:48   #190
trrk's Avatar
Thanked: 12 Times
I have been filling to the brim in each and every vehicle that I have owned / used / refilled for more than 25 years.
trrk is offline
Old 9th November 2009, 01:47   #191
Thanked: 216 Times
What is the Punto's official fuel tank capacity? Isn't it 45 litres?
coolkurt is offline
Old 9th November 2009, 12:32   #192
yup its 45 as per the manual atleast.
Old 10th November 2009, 18:00   #193
wind_rider's Avatar
Yup , just wanted to ensure very little fuel was there , so that i can get an accurate count .
But did rush to the nearest bunk .
Hmm , noted will do this from now on .
Okay , then its fine i suppose .
wind_rider is offline
Old 16th November 2009, 14:20   #194
Regarding when to fill the fuel, There are 3 indicators,
1. As soon as the fuel level indicator reaches the read mark.
2. As soon as the light (under the fuel guage) starts glowing or
3. As soon as the "Low Fuel Warning" start showing on the
display panel.
The "Low fuel warning" will start displaying only when the range value is less then 50Km. But this calculation is based on the last average speed you car has run. So be careful, think and take chances.
In Punto, the Fuel guage has only 4 marks and not 6 marks as said by Nuts_bolts
I just took a change last time when I need to get to Hp bunk some 15Km away from my home, the low fuel warning display and light indicator was up. The fuel level indicator was just very close to the Empty mark, but still the range showed 54Km.
divx is offline
Old 16th November 2009, 14:38   #195
clevermax's Avatar
Thanked: 402 Times
Recently on a road trip in the Punto, I exhausted almost all the fuel and the rang started showing "----" sign. The last value I saw in that was 50 Kms and from 50 it immediately went blank. I though it will gradually reduce to a lower value but this got me surprised and immediately filled diesel.
Running constantly with very less fuel can prematurely damage the fuel pump.
clevermax is offline
Closed Thread
My blue teutonic beauty - VW Vento TDI HL - 15000 KMs update nileshch Test-Drives & Initial Ownership Reports 323 19th January 2016 16:26
Grenzenlose Freiheit with my Grande Punto: 3400 KMS Update vidyasagar Test-Drives & Initial Ownership Reports 34 13th December 2012 20:16
Grande Punto Facelift: From baby Maserati to Punto Evo EDIT: Punto 'My Life' on pg.7 sushanthr77 The International Automotive Scene 167 25th November 2011 12:02
Iceberg is home (Fiat Grande Punto) Update: 9000 kms in 4 months kailashnj Test-Drives & Initial Ownership Reports 50 29th May 2010 12:33
Hyundai Verna CRDi SX/ABS update.. 15000 kms Sep 2008 amitwadhwa Long-Term Ownership Reviews 5 27th July 2009 15:39
