Old 31st January 2010, 05:38   #121
Thanked: 28 Times
Originally Posted by kenpachigamer View Post
hey sparkguy, how to disengage childlock? I have also experienced the same thing sometimes.
There is usually a lever or other mechanism for changing the status of the child lock on the side of the edge of the door near the striker bolt. Open the back door from the outside and look for the lever.
erohit is offline   Reply With Quote
Old 3rd March 2010, 13:46   #122
Originally Posted by SPARKled View Post
Originally Posted by Sawyer
It should not pull - I suggest you get the wheel alignment seen to, that is covered under the cashless thing.
Yes I will have it checked in the first service which is due any time soon. BTW I am getting any where between 12.5-14 in Pune city and 16-17 on the expressway at speeds greater than 100.
Is it sorted out yet? i am also feeling same in my spark. However odo is just 5000, not sure if its alignment issue.
idea1979 is offline   Reply With Quote
Old 3rd March 2010, 14:06   #123
Technocrat's Avatar
Thanked: 2,589 Times
one needs to get alignment checked & corrected every 5K Kms
Old 9th March 2010, 09:07   #124
Thanked: 1,498 Times
Default Body noise
Recently, I find a noise in the body of the car. Don't know the word for it, its not a rattle. Nor a squeak. More like some plastic panel is moving just a tad and creaking when the body flexes over a hump. Any one else has noticed and more importantly, gotten this fixed? If so, where and what was tightened? I am not in the mood to go to the station just for this.....
Sawyer is offline   Reply With Quote
Old 9th March 2010, 11:14   #125
Thanked: 21 Times
Originally Posted by Sawyer View Post
Recently, I find a noise in the body of the car.....
Even I noticed a strange sound near the driver's door end. After self investigation it seems that the spring latch holding the door is culprit. Two drops of oil there and voila the cockpit is again soundproof.
sparkguy is offline   Reply With Quote
Old 9th March 2010, 12:51   #126
I am not sure that the latch is causing the sound in my case, but I will try the remedy and see what happens....will update in a day or two, thanks!
Old 9th March 2010, 15:26   #127
SPARKled's Avatar
Thanked: 407 Times
I can hear quite a few rattles near under the dash board for the past 1 month. Have to get it sorted in the service which is way over due now.
SPARKled is online now   Reply With Quote
Old 9th March 2010, 15:31   #128
Latheesh's Avatar
Thanked: 3,309 Times
My Sparky crossed 6.2K in ODO and me too hear some rattling noise from front speaker area. Its probably from tweeter mounting, planning to get it checked this weekend.
Latheesh is online now   Reply With Quote
Old 13th March 2010, 11:46   #129
I did just this, and the creaking has gone. I am still not sure how there is connection, but if it works...!
Another thing I have noticed is a hint of fuel smell in the cabin after topping up the tank. It goes away in a little while, so this is just one for the list in the next service in four months.
No other rattles of any kind anywhere, but I have to say the car stays inside Pune city, where most of the roads are very decent now.
A-star or Spark? EDIT - Finalized Spark ritz830 Hatchbacks 67 18th July 2009 09:17
i10 or spark - EDIT: Bought Spark LT splitsecond Hatchbacks 135 28th May 2009 22:30
spark or palio for 3.3 lakhs? Edit - Finalized Spark ritz830 Hatchbacks 37 13th December 2008 16:12
Little Spark of Happiness has arrived - Chevrolet Spark LT JRD Test-Drives & Initial Ownership Reports 27 15th November 2008 13:44
