Old 27th July 2009, 12:01   #91
bblost's Avatar
Thanked: 6,663 Times
Originally Posted by sidcruise79 View Post
Now the lens dont move and i guess will have to buy a new one soon as no one repairs these Sony digicams here in Bhubaneswar.
I don't know about Bhubaneswar but here in Hyderabad, when my digicam's lens got stuck. I got a quote of 5k from an authorised service center. A small shop did the same for 1,500.
The small shop had a lot of similar phone that were completely out. He simply took the lens control mechanism from a camera with busted electronics.
Old 27th July 2009, 17:55   #92
sidcruise79's Avatar
You're lucky. Vendors here in Bhubaneswar are not so cued up and would not take the effort of doing things like that.
sidcruise79 is offline   Reply With Quote
Old 28th July 2009, 15:56   #93
sid, those wheels looks great and makes this beast feel its presence more now.If any trips planned to kol or any other city nearer to bhuwneshwar get your digi cam repaired which can be for sure without need to buy a new one, please post some pictures of beast too.
vijaythacker is offline   Reply With Quote
Old 29th July 2009, 16:45   #94
Default Help required
Originally Posted by dadu View Post
It's done, i have posted the refined version of it here (TechSpec® : TATA SAFARI DICOR 2.2l HEADLAMP Level Adjustment), taking out the unnecessary details. Sorry for the delay as was quite busy with work yesterday.
Dear Dadu,
My lights are adjusted now. I tried to get it done the way you said, but the TASS did not have space for that especially as it was in the daytime.
I'm having a problem with the radio when I reverse and the reverse cam comes on. The radio starts giving out a hissing noise and like as if there is poor radio signal. Also is there any special care I need to take for the reverse cam.
I want to change the front fog lamp bulbs and the front parking light bulbs to the white/blue types. Osram sells these, but I'm not sure about the specs. I have a pictre of the bulbs ofered by Osram. Hope someone can help me out here.
Old 3rd August 2009, 11:26   #95
Got my first service done at 1000 kms and 24 days last Saturday. Safari technicians from Pune were there for a Safari Retro have posted full details at https://www.team-bhp.com/forum/techn...ml#post1413389
Still posting info here also regarding retros done:
1. ECU Flashing;
2. ECU rubber cover installed;
3. Timing belt cover changed;
4. Some power window metal link that looks exactly like " [ " and is about 5 inches long for both the front power windows;
5. Some rubber sticky paddings put on both front doors to reduce vibration and noise; and
6. A/c condensor fuse changed to 30Amps.
Had the engine oil topped by 1ltr. Found out about Castrol synthetic oil, which will cost Rs.8,000/- for a full change. Decided against it.
After the ECU flashing the vehicle feels much smoother.
Now I'm closer to going on a long trip and putting up my travelogue.
Old 6th August 2009, 19:17   #96
Thanked: 128 Times
Sid,
How is the HID's now? Your review please.
(And some "good" photos of the same! )
HappyWheels is offline   Reply With Quote
Old 6th August 2009, 20:16   #97
jkdas's Avatar
Thanked: 1,389 Times
1. ECU Flashing;
The smooth news is making me wonder. Mine's smooth even now.
And I guess they are promoting Wurth damping stuff
Originally Posted by HappyWheels View Post
Sid,
Best bet is 4000K ones. Phillips one is 6000K.
Old 7th August 2009, 09:57   #98
Sid,
Thanks for your post.
Thought this thread was dying........ I have taken a few good shots from my camcorder, and will post it tonight or latest by tomorrow. The HID's are really good, the best part is that because they are white anything in the distance pops up into clear sight as soon as the beams fall on it.
But the HID's in dipper are the best. There is a really significant difference between Halogens and HID's.
I Promise, will post the pics ASAP.
Believe u me..... the engine is much smoother after the ECU flashing. The difference is more noticeable when the beast is in 4th gear. your RPM can drop down to even 1200-1300 and still the shuddering noise isn't prominent. I remember before the retro if the RPM fell below 1500 the whole vehicle would make a noise as if it is going to fall apart.
BTW why do you say 4000K are better than 6000K (Philips).
Old 7th August 2009, 12:42   #99
Thanked: 130 Times
SidCruise,
Looking at the photos, looks like you are begging for some trouble. You have cut the cap for inserting your new bulb. The next time you service it, water is going to get in and your warranty will be void.
I did the same mistake on my safari and had to revert to the old 65/55 bulbs. Hope you are aware of that issue or prepared for water in the headlamp always
power ranger is offline   Reply With Quote
Old 7th August 2009, 13:25   #100
Thanked: 128 Times
... Thought this thread was dying........
No need to let that happen.
... I have taken a few good shots from my camcorder, and will post it tonight or latest by tomorrow. The HID's are really good, the best part is that because they are white anything in the distance pops up into clear sight as soon as the beams fall on it... I Promise, will post the pics ASAP...
Thanks. Looking forward to it.
... BTW why do you say 4000K are better than 6000K (Philips).
Same question - why?
Originally Posted by power ranger View Post
... Hope you are aware of that issue or prepared for water in the headlamp always
PR, I reckon Sid has taken care of this issue. The person who did the install seems to be a experienced person on this conversion on Safari's and he has done some DIY which will negate this possibility.
Old 7th August 2009, 14:50   #101
jkdas's Avatar
Default Xenon 4000K 6000K difference.
the e shadow.net - - carmod: HID Alternatives
The bigger the value lesser the penetration. I have seen Philips 6000K, awesome it is. It was fixed on Sankar's bike and it was far better than my both 90/100 !
Old 7th August 2009, 15:26   #102
Lightbulb Washing
SidCruise,
I have managed to seal it with a combination of rubber, m seal, thermocole.
BTW I make it a point not to allow the service guys to spray water inside the engine compartment. I keep it clean myself (2-3 hrs every Sunday on cleaning). I was also shocked to see the guys spray water on the door sils of other vehicles and warned them not to even open the doors till all the washing is completed.
Thanks JK. very informative post.
Last edited by sidcruise79 : 7th August 2009 at 15:27. Reason: Forgot to add comment for JK's post
Old 10th August 2009, 21:37   #103
Default A few more pics
A Few more pics......
Old 11th August 2009, 09:12   #104
n.devdath's Avatar
Thanked: 1,714 Times
Superb improvement with the HID I must say...and the Yokos look good as well..
n.devdath is online now   Reply With Quote
Old 11th August 2009, 12:41   #105
the yokos looks cool mate, and with those HID, one can surely see the improvent withthose pictures.
My new Pearl White Safari VX 4x4 DukeSan27 Test-Drives & Initial Ownership Reports 26 29th September 2008 00:47
Booked Safari 2.2 VTT EX,Pearl White sun Test-Drives & Initial Ownership Reports 25 20th December 2007 12:20
Safari EX- 4*4 - Pearl White- Readily Available shatrughna Shifting gears 0 25th October 2007 17:31
