Old 6th October 2009, 12:44   #61
nairrk's Avatar
Thanked: 37 Times
Infractions: 0/1 (5)
Nice seat covers
Good price - all work at Rs.15000 only - looks fantastic.
So what you did with the old (stock) seat covers?
nairrk is online now   Reply With Quote
Old 6th October 2009, 14:29   #62
yajaman99's Avatar
Thanked: 141 Times
@nairrk - Thanks, the old seat covers are just put in a plastic bag and kept in storage.
yajaman99 is offline   Reply With Quote
Old 11th October 2009, 23:34   #63
kumar7's Avatar
I thought they simply put new cover on stock seat cover. Why did they removed the original cover of your car?
Today I saw stanley seat cover kept for display at dealer showroom but strange thing I found is there was zip chain on backside of it. I thought there should not be zip as they stitch the seat cover! Correct me if its wrong.
kumar7 is offline   Reply With Quote
Old 12th October 2009, 09:44   #64
nairrk's Avatar
Thanked: 37 Times
Seat cover with zip chain - may be the one used to put on the stock cover ( instead of stitching)?
In my last 2 car's I have used the seat cover which was put on the stock cover and looked well fit and nice to see (less job, less expense?)
Old 12th October 2009, 13:50   #65
yajaman99's Avatar
Thanked: 141 Times
@kumar - The original seat covers are removed so the new ones fit perfectly, they call OEM Fit. As for the zip on the display piece you saw it could because of the type of design used or sinces its a display unit maybe they keep changing it.
Old 12th October 2009, 23:23   #66
kumar7's Avatar
I understand that Stanley do job in very nice manner but if they remove the covers then again you are at risk of having single seat cover. Due to any reason if Stanley seats damaged then again we need to go for same process?
Do they tear of the original seat covers or can we use them again? If Stanley stitches the seat covers then the only way to clean is use vacuum cleaner.
I was planning to go for Stanley classic but looking at your seat covers (provided they don't remove original seats), I am also inclined towards Stanley Stech. I am planning to use Stanley Classic only for side trims, steering & gear knob.
There is no point in going for touch stanley seats (PU + leather) so its better to for Stech (Stanley PU) seats.
Still looking for other options
Old 13th October 2009, 01:06   #67
raamki's Avatar
Thanked: 42 Times
just wondering, obviously we are'nt going to be using the stock seat covers after getting the new ones right, any chances of a buyback @ stanley?
raamki is offline   Reply With Quote
Old 13th October 2009, 09:02   #68
joecherian's Avatar
Thanked: 78 Times
Sorry for being OT but had a small query. My colleague bought a 1.6 Sxi last week. He was telling that in his car, there is no key hole on the front doors (on the outside) so that he can lock the car from outside . I was surprised that the car has no manual way of locking. Is it so ?
More over, once you get inside and start driving, how do you make the central lock make all doors locked ? Again, his complaint is, he can't find a button /switch which will lock all doors from inside. Now, what he does is, press the remote key and lock the doors.
Can any of the Fiesta owners clarify on these ?
joecherian is offline   Reply With Quote
Old 13th October 2009, 09:54   #69
nairrk's Avatar
Thanked: 37 Times
Once all doors are closed, push the driver side door latch handle. You can see the handle goes little inside alongwith a locking sound in all doors.
(Only driver side latch will work for central locking from inside)
Old 13th October 2009, 12:43   #70
yajaman99's Avatar
Thanked: 141 Times
@joecherian - nairrk is correct but both the front side locks will activate the remote locking of all the doors. There is no automatic lock after a few meters of driving it has to be done manualy. Also if kids are there in the back seat please have them enable the 'child lock' feature. there is a key hole on the driver's side only.
@kumar - i agree there is only a single set of seat covers, but it being Art leather is easier to clean than the stock fabric seats. Now if there is physical damge it would depend on the extent of the damage which might inturn also damage the orginal cover. I have been driving around with the Stech for awhile now and "i'm loving it" to quote a fav food joint of mine. It has a great comfort feel.
@raamki - when i had gone to stanley they mentioned they would be giving the stockseat covers back. As they are fabric i guess they are of no use to them.
GO Fida
Old 13th October 2009, 12:55   #71
raamki's Avatar
Thanked: 42 Times
yep, the driver side door release button has to be pushed inward to secure all the 4 doors (you normally would pull it towards you for the door to open).
am not really sure if there is a manual way of opening the doors using the key (no keyhole on the driver side door), probably because of ford's unique key design; the keys are security coded with the ignition system. the main key has the lock/unlock/boot lid open buttons embedded on it.
If it's there, it's got to be only on the door handle! i've probably never noticed it because am so used to pushing the button to lock/unlock it.
Old 13th October 2009, 13:07   #72
nairrk's Avatar
Thanked: 37 Times
There is a keyhole on the drivers side handle.
Check it please
Old 13th October 2009, 13:33   #73
yajaman99's Avatar
Thanked: 141 Times
Default driver door key
here is a pic , its crop from one of the pics i had on my harddrive.
hope this helps
Go Fida
Old 13th October 2009, 15:08   #74
rajeshvin's Avatar
hope this helps
Go Fida
+1, if by chance you lost main key with remote functions, you have to use 2nd key manually as it doesn't have remote functions, but it has chip compatible with ECU.
rajeshvin is offline   Reply With Quote
Old 28th October 2009, 19:57   #75
yajaman99's Avatar
Thanked: 141 Times
Default ODO over 2000 KM
Been a while since i update this thread.
The ODO has reached the 2000Km over the last weekend.
Also after nearly 7weeks i got RC Smart Card
Go Fida
Fiesta Zxi booked in Chennai and awaiting delivery on July 9th EDIT: Delivered aravinrd Test-Drives & Initial Ownership Reports 93 2nd October 2013 13:49
Planning Gurgaon-Manali-Leh-Srinagar in Ford Fiesta 1.6Zxi: How much Feasible? hridayjyoti Route / Travel Queries 27 10th August 2010 13:21
My paprika flying machine has arrived ( Ford Fiesta 1.6zxi ) zaxis Test-Drives & Initial Ownership Reports 19 21st August 2009 21:55
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
