Old 3rd October 2009, 09:26   #31
Originally Posted by headers View Post
I think RD's is a piggyback ECU whereas Pete's is not.
Guru's to comment on that.
Now,
@RDK: Can i Procure this EM400 and keep switching it between my cars?
I have 3 diesel cars!
What is the difference? Can you elaborate?
ShyamSCrdi is offline   Reply With Quote
Old 4th October 2009, 12:28   #32
rajathv8's Avatar
Thanked: 245 Times
Default Query
can these boxes be used with petrol engines? is it wise (& worth) to use them with a 1.1 engine?
rajathv8 is offline   Reply With Quote
Old 4th October 2009, 13:42   #33
ssjr0498's Avatar
Thanked: 120 Times
Racedynamics has separate ECM's for petrol's. The XM's are specifically for deisel's. It's worth even for a FI 149cc bike, let alone your 1.1L engine.
ssjr0498 is offline   Reply With Quote
Old 4th October 2009, 16:46   #34
headers's Avatar
Thanked: 464 Times
A Standalone ECU replaces the existing stock ECU of the car whereas a Piggyback ECU sits alongwith the stock ECU and does magic!
Old 4th October 2009, 16:55   #35
In that case the EM400 is a piggyback ecu which does nothing but increase the rail pressure. It is similar to the petes box. RD has standalone ecus too but i dont think they are applicable for gen 2 crdis.
Old 4th October 2009, 17:15   #36
EssYouWe's Avatar
Thanked: 16 Times
Piggy back ECUs basically take over the engine works from the stock ECU leaving it with other non essential tasks. They are usually a cheaper alternative to standalone performance ECUs.
They are easier to install and manufacture as compared to replacement ECUs.
RD does manufacture standalone ECUs.
EssYouWe is offline   Reply With Quote
Old 4th October 2009, 17:45   #37
nitrous's Avatar
Thanked: 285 Times
Pete's is a piggyback too.
PS: I've lost count of the number of times you mention 'piggyback'. You enjoy the term,heh?
Old 4th October 2009, 19:04   #38
Thanked: 63 Times
One question regarding this performance enhancers, (i might appear stupid), will this not put more stress / load on the engine and reduce the engine life, and moreover, the sudden surge in the power will have a considerable wear on the tyres, obviously the manufacturer is not going to test these sudden power surges on the tyre, this leaves a question to all those who put these boxes, what would be the right / proper tyre choice for these kind on mods.
No wonder, the manufacturer voids the warranty if this box is installed. The ripple of effect of the sudden power surge on the tyres, suspension and what not, will certainly have a big impact.
I may be wrong and I would like to correct myself wherever I am wrong.
balajird is offline   Reply With Quote
Old 4th October 2009, 20:11   #39
You are very right. But then when you are taken over by thirst for power you really dont worry about all these things
Old 4th October 2009, 22:59   #40
Thanked: 63 Times
I feel better now, good to know that my understanding is right . Though, now i understand that the "thirst for power", i would also like to know How do you arrive at the right set of tyres and is there any suspension setting changed?
Old 5th October 2009, 00:40   #41
ph03n!x's Avatar
Thanked: 120 Times
Tire choices for high speed and handling applications are Advan & S.Drives from Yokohama, and PP2 from Michelin (tire gurus, please correct/ add-on to this).
The right tire width and dia again is based on the application and user preference- why dont you try the tire bible? (Car Bibles : The Wheel and Tyre Bible Page 1 of 2)
ph03n!x is offline   Reply With Quote
Old 5th October 2009, 12:15   #42
Hmmm! You could add Conti's CPC2. It is good.
Old 5th October 2009, 12:39   #43
Ramsagar's Avatar
Thanked: 62 Times
Congrats on the car & RD unit.Pls post some pics.
Upgrade your tires ASAP.
Ramsagar is offline   Reply With Quote
Old 5th October 2009, 22:26   #44
Hi!
Based on this thread I wrote to the guys at RD for my swift petrol. Are there any workhops in mumbai ? Till date Viper has responded (postive).I am in mumbai. Any leads? Thanks
Cheers!
ash_sen is offline   Reply With Quote
Old 6th October 2009, 21:45   #45
kailashnj's Avatar
Thanked: 281 Times
HI Ash,
There is one N1 Engineering in Worli which is a distributor for them. You can try contacting them. These guys are bang opp Auto Hanger in Worli after the siddhivinayak temple one way. Hope this helps.
Kailash
kailashnj is offline   Reply With Quote
Race Dynamics : The tech review Psycho Technical Stuff 123 3rd October 2013 00:29
Guderian...A Scorpio CRDe. EDIT : Updated to 100,000 kms. Full costing on pg 6 Guderian Long-Term Ownership Reviews 95 4th March 2011 22:19
Pete's or Race Dynamics for Getz CRDI Ravenblood Modifications & Accessories 3 18th March 2010 22:29
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
