Old 10th October 2009, 23:14   #46
Default 0-60, 0-100
Hello friends,
Sorry for writing late. Was very busy in work, didn't get time to check posts. It is 3 weeks now since the box is installed and the car is performing excellently. After sales service of RD is really great. They call me every week and take feedback about the car's performance Engine now likes to be revved. In P1/P2 setting in second/third gear the engine makes a nice humming sound after 3000 RPM.
Today i met Karthik and tested 0-60 and 0-100. Car is still running on 175/65 R14. We did 3 speed runs. The first run was with AC on which we considered invalid. We then did 2nd and 3rd run with AC off. Here is the data:
2nd run data:
0-60 in stock is 5.20sec.
0-60 in P2 is 4.49sec.
Difference is 0.71sec
0-100 in stock is 12.31sec
0-100 in P2 is 10.33sec
Difference is 1.98sec
3rd run data (see graph):
0-100 in stock is 12.39sec
0-100 in P2 is 10.40sec
There was a lot of wheelspin in 1st and 2nd gear Traction was available only in 3rd gear. This is evident from the graph. Till 20kmph the RD graph is actually lower than the stock graph and after that it picks up. Karthik said we could have achieved 0-100 in 9.5sec if the tires had been better.
I've decided to go for 195/60 R14 Continental CPC2. Any better options?
My Getz CRDI with Race Dynamics XM400 Edit: updated with 0-60, 0-100 figures-getz_stock.jpg
My Getz CRDI with Race Dynamics XM400 Edit: updated with 0-60, 0-100 figures-getz_rd.jpg
My Getz CRDI with Race Dynamics XM400 Edit: updated with 0-60, 0-100 figures-getz_graph.jpg
Furman is offline   Reply With Quote
Old 11th October 2009, 01:40   #47
aZa
aZa's Avatar
Thanked: 17 Times
0-100 in 9.5 secs !!! Now dats something.
Old 11th October 2009, 11:44   #48
Good choice. I have the same tyres and recommend it to you. One small thing is that i had BF Goodrich G Sport of the same tyre size before this it had better grip at speeds above 170kmph but did not corner well enough but then again had good lateral grip i mean we could skid and slid without any problems. The BFs where very very hard and made for uncomfortable ride. As for the CPC 2 it is quiet comfortable but then make your mind for a little harder ride.
Shyam
ShyamSCrdi is offline   Reply With Quote
Old 11th October 2009, 11:58   #49
rjstyles69's Avatar
Thanked: 789 Times
That's some good numbers there, a straight cut of 1.98 secs off the stock ECU's timings. However the million dollar question, what have you done to improve your braking ?
At what rpm is the difference really felt ?
Old 11th October 2009, 12:14   #50
extreme_torque's Avatar
Thanked: 1,317 Times
Today I tested it on NH7. I filled 40 liter normal diesel and went for 225 kms drive with E mode being selected 90% of the drive. Noticeable drop in power but car cruises happily at 80-100 with 1500-1800 RPM on Tachometer.
Tuning box wont ever change the rpm where a particular speed is achieved because that is dependent on the gearing.
Are you sure its 100 kph @ 1800 rpm? I can bet my life on it that it can't be low. It cant possibly be geared so high in 5th
extreme_torque is online now   Reply With Quote
Old 11th October 2009, 12:17   #51
Actually getz 100kmph in the 5th gear is at around 1800~1900 rpm. The turbo kicks in at around 1800~1900 so it is quiet possible . At about 3000 rpm in 5th gear you get to 150kmph .
Old 11th October 2009, 13:07   #52
kpzen's Avatar
Thanked: 1,598 Times
But, the speedo can show different speeds depending upon the tire size.
Old 11th October 2009, 13:14   #53
aZa
aZa's Avatar
Thanked: 17 Times
Better tyres here would mean better timing right, due to more traction? So sub 9sec possible ?
Now we need a comparo between petes and RD
Old 11th October 2009, 13:21   #54
Nikhilb2008's Avatar
Thanked: 4,785 Times
You may as well get Advan Neovas! It might slow down your 0-100 times, but you will have astonishing grip at the corners.
And if you take care of it well, it might last you upto 30k kms.
Old 11th October 2009, 13:48   #55
Turbo kicking has no relation what so ever with the speed car is doing. Its a function of gearing.
If Getz does 150 kmph @ 3000 rpm then we are looking at 2000 rpm for 100 kph and not 1800
Here are the calculations
150/3000 = .05
.05 X 200 = 100 kph
Old 11th October 2009, 14:28   #56
headers's Avatar
Thanked: 454 Times
150/3000 = .05
.05 X 200 = 100 kph
if its a downslope then 100kph at 1800 is possible. afterall the error is only 200 rpm which is insignificant in these engines.
Old 11th October 2009, 14:32   #57
kpzen's Avatar
150/3000 = .05
.05 X 200 = 100 kph
Which gear ? What is the factor 200 ?
In 5th Gear
100kph - 2000rpm
120kph - 2500rpm
140kph - 3000rpm
160kph - 3500rpm
180kph - 4000rpm
200kph - Couldn't see anything !!
Old 11th October 2009, 15:35   #58
Nice hehe you where so involved with driving at that speed eh!! . Me thinks max speed we can do would be 215kmph what say?
Old 11th October 2009, 20:31   #59
@headers... No even if its a downward slope. The speed == revolution of the gears which would remains constant, downward or upwards. The only case in which this ratio would differ is in case the clutch is slipping and not working properly.
@kpzen... Lemme explain in a more layman way. The speeds are all in 5th gear so the gearing remains constant.
150 kph and 3000 revs would mean 150/3000 kph per rpm == 0.05
Now speed at 2000 rpm would be 2000 X 0.05 == 100 kph
Old 11th October 2009, 20:45   #60
Thanked: 23 Times
Smile
Thanks for sharing a review of this very interesting car with us; as if the Getz CRDi wasn't a stonker enough, you now have a Race Dynamics box giving it some more steroid!
Guys from Bangalore have inherent advantages WRT RD's products. The man is just a phone call away. Good to hear that you are satisfied with the sales / install experience.
I wasn't even aware that the box had an economy mode. Good stuff, different settings for different driving conditions.
Tell us more about P II Mode
If an overpowered car like the Getz CRDi struggles to climb, that setting must be running real lean.
Do share the price here itself, we insist. Posts with price included can only increase the value offered by your review.
Congrats on the car + powerbox, and drive safe. Top priorities for you ought to be a stiffer suspension & wider tyres.
who idea is this i mean the economy mode also option give to the user
who provide component samples from china to RD
narry
narry is offline   Reply With Quote
Race Dynamics : The tech review Psycho Technical Stuff 123 3rd October 2013 00:29
Guderian...A Scorpio CRDe. EDIT : Updated to 100,000 kms. Full costing on pg 6 Guderian Long-Term Ownership Reviews 95 4th March 2011 22:19
Pete's or Race Dynamics for Getz CRDI Ravenblood Modifications & Accessories 3 18th March 2010 22:29
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
