Old 7th February 2010, 20:10   #106
sivadas's Avatar
Thanked: 171 Times
Originally Posted by anandpadhye View Post
How much did you pay for exchanging stock allys for 16" ones?
It was part of the deal.
And what's the top speed you have tried so far?
And topspeed is 140 on NICE road.
sivadas is offline   Reply With Quote
Old 7th February 2010, 20:19   #107
sivadas's Avatar
Thanked: 171 Times
Default Fuel Efficiency Details
So far I have filled the tank 3 times (capacity is 57ltrs).
First time it was Speed and got an FE of 8.6.
Second time filled Xtra Premium and FE has gone up to 9.7.
Both are with 50%AC and some amount of aggressive driving.
Currently running on Speed again. I am going to try more sedate driving this time.
Old 13th February 2010, 02:03   #108
Nikhilb2008's Avatar
Thanked: 6,591 Times
Hey Siva, a small query. I know this car has all 4 power windows... The spec sheet says "One touch". Is it one touch for all 4 windows or only for the driver's side?
Old 13th February 2010, 04:11   #109
Berj79's Avatar
all windows one nice feature..
Berj79 is offline   Reply With Quote
Old 13th February 2010, 22:39   #110
sivadas's Avatar
Thanked: 171 Times
Even better feature is that you can close or open windows (all together) any time from remote key. If you keep pressing the 'open' button, windows come down and pressing the 'colse' button continuously make windows go up.
Old 13th February 2010, 23:01   #111
Awaiting Email Confirmation
Thanked: 66 Times
And you can change this setting to Automatic windows (using Vag-Com). With that activated, you need to press the Lock (unlock) button for a second after which the window rolls up (down) and you can release the button.
The current setting will require you to hold the lock (unlock) button until the window rolls up (down) completely.
Akki_5 is offline   Reply With Quote
Old 15th February 2010, 14:59   #112
sivadas's Avatar
Thanked: 171 Times
I saw your other post on vag-Com. Have you tried it out?
Can you please give more details?
Old 15th February 2010, 17:31   #113
Thanked: 66 Times
You can find more details here:
(1) Ross-Tech VCDS
(2) Vag-Com on a Laura
Just google Vag-Com and you'll find tons of info.
Old 16th February 2010, 11:23   #114
sivadas's Avatar
Thanked: 171 Times
(1) Ross-Tech VCDS
Thanks Akki.
Wanted to check again whether you could try it out.
Old 16th February 2010, 20:36   #115
Thanked: 66 Times
I haven't found time to try this on my car though i have researched sufficiently to use this on my car.
Old 16th February 2010, 21:21   #116
Berj79's Avatar
i think we need help from a team-bhpian in mumbai who has a vagcom, anyone can help us???
Old 16th February 2010, 22:57   #117
sivadas's Avatar
Thanked: 171 Times
Default Warning sound
I am some times getting this warning Bell sound from my car . As advised by dealer, checked all possible causes (seat belt, doors not closed etc) but everything seems to bel just fine. Again there is no warning lights/symbols displayed.
Any suggestions from fellow Laura owners would be appreciated.
Old 17th February 2010, 00:44   #118
Berj79's Avatar
thats ur speed limit settings, must be happening when u go above 100kmh?
thats the default settings, u can change it through the multifuction display,
check the manual, 101% its that
Old 17th February 2010, 01:57   #119
Thanked: 66 Times
The new Laura does not have seat belt warning. So no chance of that. As Berj said, it could well be the speed limit warning. You may have accidentally set speed limiter to a small value like 30 kmph. But AFAIK it displays speed limit value on the MFD with the acoustic signal.
You can check this by bringing the car to a halt or a speed less than 30 kmph whenever you hear the warning sound. The sound should stop when speed falls below 30 kmph.
Old 17th February 2010, 10:08   #120
sivadas's Avatar
Thanked: 171 Times
Thanks to both of you. Let me check it out.
How and when did you learn to drive? camry93 Street Experiences 470 24th July 2015 14:13
Never say never amitsatpathy Introduce yourself 7 3rd July 2015 10:59
Skoda Laura Ambiente-cheaper Laura deuce-deuce The Indian Car Scene 94 11th July 2008 06:53
Facelifted Octy, Cheaper Laura EDIT : Laura Elegance ajmat The Indian Car Scene 139 27th August 2007 10:47
