Old 1st July 2010, 11:23   #2821
longhorn's Avatar
Thanked: 335 Times
Originally Posted by kage9091 View Post
I was climbing a basement parking slope (must be like 55 degrees) with just me in the car with AC off. I had to brake midway on a slope due to a car ahead of me. I could not get the car to pull itself from the middle of the slope.
Luckily, there was no vehicle behind me and I could roll down to the plain surface and zoom to climb the slope.
I am alarmed/ This could be a disaster on hill driving.
Is this normal or should I visit the dealer workshop?
Are you positive that you were in first gear and not in third ? If not, try it once more. Stop on a slope and pull the hand brake. Now slot it to neutral and then to first. Now release the handbrake as the car tries to move forward in first gear. This should work, else Ford should replace your car.
longhorn is offline   Reply With Quote
Old 1st July 2010, 12:27   #2822
Thanked: 91 Times
You all can go through this link and check:
The-new-Mitsubishi-Evo-X-First-Drive,Buy New Cars, Used Cars, Auto News and Reviews India - Zigwheels.com
it has a beautiful illustration of hatchback Diesel and FORD FIGO WINS.
ruchirtnt is offline   Reply With Quote
Old 1st July 2010, 13:09   #2823
coldice4u's Avatar
Thanked: 95 Times
coldice4u, does the power loss happen when trying to pull in 1st gear from a stationary position on an incline? This is what I faced today.
I have also experienced power loss while downshifting from 3rd to 2nd gear which forces me to further downshift to 1st gear. 2nd gear seems useless at speed bumps and start-stop traffic conditions.
kage, i have never faced any problems when trying to pull in 1st gear from a stationary position on an incline. Also no pwer loss was ever felt when downshifting from 3rd to 2nd. The incline where i had faced problems was a 2nd gear incline. But in case i had to slow down while going up and have to downshift to 1st , i felt an uncomfortable loss of momentum. You have to mash the throttle before the car picks up momentum again.
Originally Posted by .anshuman View Post
Most diesel cars can climb the steepest inclines seen in the basements of buildings and malls in second gear without accelerator pedal touched.
Just for the reference my cousin owns two cars, the TDCI Figo and a 98 carb Zen. On the inclines coming out of the basements of her apartment, the Zen could easily make it in 2nd gear, but i always used 1st gear on the Figo.
coldice4u is offline   Reply With Quote
Old 1st July 2010, 13:33   #2824
Awaiting Email Confirmation
Thats awesome!! thanks for this link... was looking for such comparative discussions since long time..things are more clear now..
Adrenalin is offline   Reply With Quote
Old 1st July 2010, 13:46   #2825
RGK
RGK's Avatar
Thanked: 221 Times
In a slope, shift to 1st and leave it and start moving (it should and will move up with 4 pax. If the vehicle does not climb then the engine is absolutely useless, only to be thrown out) Even the old Matadors on Ambassdors have easily climbed all slopes
Modern engines are extremely capable of pulling over a slope with ease
Last weekend I drove my B-i-l Ikon 1.8D (a known sluggish engine) to Kodai from Palani, I did not have any problem in climbing with 4 people inside. I think Figo should not have any problem in climbing infact should zip the slope.
Points to be noted: - never do a half clutch business - will decrease the power of the engine and clutch plate life and also will not climb(so we rev up the engine which is also useless).
-By instinct we keep the left leg on the clutch and think to avoid jumping forward. No need, release the clutch slowly and easily it should move up in 1st with its full torque.
-Please do not try in 2nd gear.
-Even if there are vehicles at the front and back - need not rev up, should easily move up in 1st. If need to be stationed in a slope precise use of hand brake is best for a longer period and Half clutch can be used without rev up of the engine for a very shorter period of 1 to 2 min.
My apartment has a 45 degree slope for 2 metres and no problem with my figo, but need to test in a hill drive.
RGK is offline   Reply With Quote
Old 1st July 2010, 14:02   #2826
It should not be a problem for new machine like Figo. My 5 yr old ford ikon does the fair job of climbing any slope without any hassle. Best way i always follow and recommend is when on slope and you are stopped(as in your case), put the gear in neutral, pull the parking brakes, slot to 1st gear and start releasing the clutch(also gentle press on accelerator) and parking brake gradually(in sync) and when the car start moving a bit you can release the parking brake completely. You should be able to negotiate.
If this does not happen, you need to get FIGO engine check thoroughly from authorized service station.
Old 1st July 2010, 15:58   #2827
Thanked: 36 Times
Infractions: 0/1 (5)
Originally Posted by Diesel lover View Post
Hi
Got my car serviced on Saturday and after a few kms down the road (after service) I heard squeaking sound from the left rear suspension area. It appears when i hit a pothole or uneven road at around 40+ speeds. I think this squeak thing happened after the workshop guys gave the car a through wash to the underbody.
Wanted to know what the service guys did to control that squeak? Did they use some kind of oil or grease and where did they used it? On which part?
Apologies for late reply. I was told they have tightened the suspension bolting and greased. So its not just lubrication. Its 100+ kms and squaks have not returned.
ownerofazkaban is offline   Reply With Quote
Old 1st July 2010, 16:20   #2828
Thanked: 7 Times
What is the big fuss about shifting down to first before bumps/slopes? Is it too inconvenient or the left hand is not free?
sanjayc is offline   Reply With Quote
Old 1st July 2010, 17:04   #2829
anilisanil's Avatar
Thanked: 288 Times
Does anyone has any idea about the Total Maintainence plan for Figo? I booked my Figo and expecting the delivery day after, would like to understand the implications of having/not having this plan. I did spoke to the SP but he tells me that he has just got the details of TMP and would give me the details tomorrow. Though he is a good person I am not sure what he is "working". If anyone has any idea please let me know.
Also please tell me if opting for this would be redundant/extra cost if I already opted for the third year extended warranty!
anilisanil is offline   Reply With Quote
Old 1st July 2010, 17:36   #2830
MutantX's Avatar
Thanked: 89 Times
down shifting for extra thrust is common. I park my i10 in the 1st floor at office, i always downshift to 1st gear. It is always safe to climb up the ramp on the 1st gear, gives you more control. *atleast according to me*. I havent driven figo to comment, but let me TD it this weekend
MutantX is offline   Reply With Quote
Old 1st July 2010, 17:49   #2831
Brix's Avatar
Thanked: 23 Times
The transition from Petrol to Figo diesel causes this. One needs to make a note of it. For me its automatic now.
Brix is offline   Reply With Quote
Old 1st July 2010, 17:53   #2832
anilisanil's Avatar
Thanked: 288 Times
But isn't it imperative to slot to 1st if the vehicle came to stand still, that too on a slope?
Old 1st July 2010, 18:15   #2833
Thanked: 768 Times
Scary indeed. I'm seriously contemplating buying a Figo Diesel, and this episode scares me. Would'nt want to be the one experiencing a sudden loss of power on an incline. I'm really surprised that it could not pull up in 1st gear. I'm going to check this for sure before I buy it. In the meanwhile, will be watching this thread really closely to see if any one else has experienced similar problems.
Lalvaz is offline   Reply With Quote
Old 1st July 2010, 18:35   #2834
kage9091's Avatar
Originally Posted by jayded View Post
Boy, now this is scary. So you guys are saying this vehicle once stopped on a moderately sharp incline, fails to climb it even on first gear??? Now I have not driven diesel cars extensively but would assume here that it's not a common trait of all diesel engines, please correct me if I'm wrong here.
The engine should be delivering sufficient power even before the turbo kicks in right? I'm really confused and dazed by this behavior and it's a nightmare since the landscape of major part of the state where I am is pretty much sinusoidal to say the least.
jayded, I went to my dealer's workshop today and got a mechanic to check the problem.
We tested it at the same basement parking where I had faced the issue of engine stalling in first gear while climbing the slope. I was at the wheel and the mechanic told me to use the half clutch technique. This time the car pulled with good power. Earlier when the car had stalled, I was releasing the clutch and pushing the accelerator pedal simultaneously like I do in my petrol cars.
I think there is no issue with the Figo diesel. I was missing the half clutch trick because in petrol cars, I did not need it and it's my first experience with a diesel car. I will still want to test the Figo in hill driving.
I hope this helps.
Most diesel cars can climb the steepest inclines seen in the basements of buildings and malls in second gear without accelerator pedal touched. This is with the rpm close to idle, i am sure Figo can do this too, i have tested Elantra, Swift, Verna, Scorpio, Punto and Fortuner.
.anshuman, I doubt that Figo can climb any slope in second gear especially from low rpm without pushing the pedal. Sad but true.
Originally Posted by raju2512 View Post
I have not faced any problem with the petrol version. With higher torque, diesels should perform better. It could be a manufacturing related issue and not a generic issue with Figo
raju2512, I could overcome the issue by using half clutch trick. Thankfully my Figo is not a lemon.
Does it have something to do with the fact that most Figo owners are new to diesel, and hence missing any trick initially on how to work it out?
Getting stuck in such a situation is not only extremely embarrassing but also gives you "heart in you mouth" moments very often. I believe that's not what one deserves after buying a car for around 5.5L.
Whatever is the case, most Figo TDCi owners have complained about stalling on an incline on one or more occasions, and I've failed to see such incidents reported by other car users, or may be I've not searched hard enough.
jayded, you just echoed what I feel. Shifting from petrol to diesel is a bit of a learning curve. I am new to diesel Figo and would like to drive other diesels with the same displacements and figure out if the Figo has any issues with power on inclines.
longhorn, I was in the first gear for sure. Also the hand brake was not engaged. I will try what you mentioned above on inclines. The half clutch technique did work out for me today on the same slope. I doubt if the car would pull on it's own in first gear. I will find a suitable practice spot and post back.
It's heartening to know that Figo can be expected to behave like normal diesel cars. I need some more practice to figure out the trick to drive on inclines. Surprisingly, petrol cars which I drove could climb without the half clutch technique. I will find out soon about my Figo and post back.
I agree that petrol cars can easily negotiate slopes in 2nd gear too. The Figo diesel feels odd in this respect. Must be the technical differences.
Thanks RGK for this information. I try what you said and hopefully get confident about driving my Figo uphill without the need to jump or stall the car. Practice is on the cards for me.
Thanks Adrenalin, I will definitely practice the clutch, accelerator, hand brake routine to overcome this issue. BTW, I went to the workshop today and with the mechanic's guidance (he suggested half clutch technique) I made it up the same slope. This time there three people in the car opposed to one last time with Ac on too.
sanjayc, there is fuss in using the left hand for downshifting, its just that I am gradually getting used to the new diesel vehicle.
Mutantx, thanks for the feedback. I wish you a good TD of Figo.
kage9091 is offline   Reply With Quote
Old 1st July 2010, 19:50   #2835
Brix's Avatar
Thanked: 23 Times
Half clutch is unavoidable in certain conditions. Wonder how you hadnt used it all these days.
My Scenario : There is a steep slope before I enter my building. There is a gate so I need to climb and wait for the watchman to open it. Then I need to go slowly up because some kids might run about. Half clutch is the only way out.
My wife on the other hand just rushes inside - I suddenly realize that she may not know this technique too.
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 887 18th March 2018 14:33
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
