Old 22nd October 2010, 17:19   #3346
sumathindra's Avatar
Thanked: 219 Times
Only front windows have power windows, one of them illuminated on driver side.
the passenger side power window switch is also illuminated!
sumathindra is offline   Reply With Quote
Old 23rd October 2010, 15:54   #3347
Thanked: 103,333 Times
Originally Posted by Deep Blue View Post
Ford recommends raising the rpm to 3000 for 30secs once every week. What does this do?
Forget Ford, I recommend it . What does it do? Bring a wide grin to your face!
Jokes apart, engines that have had their legs stretched ever so often feel much "sharper" & revv happier. You should have seen the way my OHC Vtec used to bounce off the revv limiter. Or even the Civic : When I bought the car (used), it really wasn't that revv-happy, as the previous owner probably never went over 3,000 rpms. The last 7,000 kms under my heavy right foot have changed it all. The 1.8 feels way smoother (and quicker) when working up the revv limiter.
Ford probably wants you to do it to clear up carbon buildup.
Originally Posted by kiku007 View Post
Can you explain what features the Autocop provides that you miss in the OE Immobilser+Key Less Entry apart from the 'Keen..keen' beeper? Even I miss it at times.
However from a anti-theft point of view, an immobiliser is definetly more effective than the Burglar Alarm equipped autocop. Do you think anyone cares to even give a glance to car that screams, 'keen...keeen' when someone's trying to steal it?
My suggestion is not to replace the OE equipment with Autocop.
I wouldn't completely agree with that, Kiku. I got an Autocop for my Civic, despite a Honda security system being standard equipment. Here's why:
- The new age Autocops integrate, and work along with, your factory system. Effectively, you have double the security.
- That means, your factory immobiliser (and other functions) work as intended. In addition, I have the Autocop's motion sensors (any movement inside will trigger it), glass protection , impact sensors (which I have turned off by the way) and an extra siren (when the alarm goes off, the horn + autocop siren both start blaring)
- The Autocop is so well integrated that a separate remote control isn't required either. It works off the Honda key itself!
Old 23rd October 2010, 16:21   #3348
Thanked: 158 Times
Driver side has two buttons in Figo. One for driver side window and other for passenger side window (In fiesta its four). On driver side only dirver side window's button illuminated. However at other door's respective buttons are illuminated (In Figo, Front passenger side window, Fiesta will have respective button illuminated.). Hope this is clear.
RaguHolla is offline   Reply With Quote
Old 23rd October 2010, 17:49   #3349
Should this be done during run-in period(first 1500km) as well?
It seems to be the recommendation for every car as per your post. Quite a useful tip.
Your Civic has better security system as compared to the Indian Parliament.
Can you please share the model number of this Z+ category security system from Autocop with us?
I think its specifically designed for installation in cars with OEM security system as you have mentioned that we don't even need an extra remote.
PaddleShifter is offline   Reply With Quote
Old 23rd October 2010, 19:12   #3350
NO!!! Please read our advice article on safely running in your car. I wouldn't high-revv any car until she has completed atleast 3,000 kms.
XS-PLIP-80 (RCI/2)
Old 23rd October 2010, 22:42   #3351
Sheel's Avatar
Thanked: 5,638 Times
I have a question now that red-lining is being discussed.
I regularly red-line whatever Car or Motorcycle I am driving/riding, but I am a virgin with diesel engines, almost, and diesel engines do not like revs much is what I think after my brief driving stints with them.
What should their red-line limit be? Should we stick to the rpm where the Car makes it max power? As torque is generated at a lower rpm compared to power. Is there some criterion with diesels?
Is it true that carbon build up is least if it is red-lined in first gear compared to the rest?(you may ignore this question, but if the answer is in affirmative, then please say so)
^^I recently red-lined and shifted my friend's Swift 1.3G for ~20 kms and never went above the 3rd cog and the Car felt freer.
Old 23rd October 2010, 22:54   #3352
kiku007's Avatar
Thanked: 1,482 Times
XS-PLIP-80 (RCI/2)
GTO, if the existing system is not tampered with then it's brilliant! When I enquired here in Chennai none suggested this option.
BTW this motion sensors is what the VW Vento has right?
kiku007 is offline   Reply With Quote
Old 24th October 2010, 08:08   #3353
headers's Avatar
Thanked: 464 Times
Thats a psychological feel we go through after redlining any vehicle. But the vehicle does not get any better because of that!!
Old 24th October 2010, 08:49   #3354
Sheel's Avatar
Don't the valve seat/piston top get rid of their carbon deposits?
Have a look at the pic I am posting, its of a screaming I-4 which makes 180ps+ power and redlines at 13,000rpm, limited at 299kmph
Old 24th October 2010, 21:14   #3355
Abes's Avatar
Thanked: 57 Times
@GTO: Why is redlining good for the car? & I used to think that redlining is bad for the engine!!
Abes is offline   Reply With Quote
Old 25th October 2010, 17:00   #3356
Except for the occasional high-revving sprint, its best to "work the torque" with diesels. Translated = Upshift early in regular driving.
No alteration to the existing system. They merely patched the Autocop onto the factory-fit system, much like a piggyback ECU works over the standard.
Not sure what the Vento has. The motion sensors I spoke about are infrared devices mounted on the top of each A Pillar (on the inside). Once I lock the car, the alarm will sound off if there is any movement inside (say, a thief breaks a glass and accesses the car).
Let me know if you want to see pictures of the infrared cameras.
The higher the revvs, the more the wear & tear. However, modern engines (petrols especially) will easily last 2.0 lakh kms (with the right oil changes), if not 3.0 lakhs. Why we high-revv?
- Because we love to
- I've always felt that a car which has been high-revved ever so often has a sharper throttle, and a free'er engine, than one which has never gone "the right side" of 3,000 rpm.
Old 25th October 2010, 22:23   #3357
Deep Blue's Avatar
Thanked: 237 Times
You bet!
I had not done the 3000rpm ritual for 2weeks. I could do it only on Sunday. Eversince I am grinning ear to ear. The engine has become so much more free indulging you to push it more. The grin disappears only when you look at the DTE
I had not felt the free feeling so much, earlier when I had done the ritual.
Thank you Gemithomas and GTO for the explanation.
Deep Blue is offline   Reply With Quote
Old 25th October 2010, 22:52   #3358
Abes's Avatar
Thanked: 57 Times
That means:
- redlining is still bad for the engine.
- it just gives a good feeling. May be, after a redlining the ECU keeps the engine/transmission/other systems on the edge to keep up with your style of driving. (I am just speculating)
My car redlines at 6500rpm (if i go by the red marking on the RPM meter). I have never got to that. Though it gets to around 5K on kickdowns, while cruising at around 100kmph, the rpm is a bit above 2.5K. So I guess I am a sedate driver.
Old 26th October 2010, 08:47   #3359
Sheel's Avatar
That means:
Yes, if you keep the rpm pinned near the red-line for extended periods.
No. It frees the Car (or in a wider spectrum, the engine) of its carbon deposits.
Just yesterday I took out my Motorcycle after a long time, after warming it up for 10+kms, I red-lined it in first 3 gears or better put it till the limiter cut in. You WILL know that it is revving freely/smoothly and is so eager to hit the ceiling.
What smell is emitted post hard driving/riding? (hell, seems we need to start a new thread on this topic)
Yes, everyone should be a sedate driver on roads.
But you can always red-line it in first two or three gears, say every 1000kms(at-least).
Old 26th October 2010, 15:19   #3360
Thanked: 7 Times
Got an ugly dent and scratch this morning on my way to office. It was partially my mistake as I misjudged the gap between a stationary truck parked in the wrong side of the road and an incoming bike.
Below is the shot of the scratch. I took the Figo to Lathangi's body shop (which is miles away from the city) during the lunch time and they quoted a price of 7k!
I told them that I need time to decide and took the car back. On the way I asked a local garage and they quoted 4k after some bargaining.
Now I'm in a kind of dilemma about where to take it. I can claim insurance and take it to the dealer or cough up 4k at the local garage.
Review: 1st-gen Ford Figo (2010)-img_0250.jpg
atrisarkar is offline   Reply With Quote
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 898 2nd July 2018 12:12
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
