Old 4th May 2011, 14:15   #4291
Thanked: 68 Times
Default re: Review: 1st-gen Ford Figo (2010)
Originally Posted by rohing View Post
To the best of my Knowledge it is a problem with ALL Figo's. I have seen several complaints on this topic in T-BHP. I would let the other viewers/ members re-confirm it.
I will confirm this today evening.
Haven't observed this as I NEVER drive without music
figo_united is offline   Reply With Quote
Old 4th May 2011, 14:59   #4292
sumathindra's Avatar
Thanked: 192 Times
I use the BT extensively and yes this is a known issue. Wonder if this can be fixed! I did ask the SA during the service last week however as usual he stared right thru me
sumathindra is offline   Reply With Quote
Old 4th May 2011, 15:48   #4293
I have just completed 5K on my Figo. Do I need to go for tire rotation, balancing and alignment? Please let me know.
askids is offline   Reply With Quote
Old 4th May 2011, 16:17   #4294
anilisanil's Avatar
Thanked: 288 Times
Your hand book contains all the required information about the same, it gives a schedule of all the maintenance required for the vehicle.
Although it is recommended that you rotate your wheels every 5000 Kms, Ford does that only once in 10000, so it is OK if you can wait until next service.
anilisanil is offline   Reply With Quote
Old 4th May 2011, 16:52   #4295
KiloAlpha's Avatar
Thanked: 1,486 Times
Hi Mustang,
The Sequence I describe is as below -
a) Music is Off.
b) Phone rings and you pick up the call
c) Finish talking and hang up
d) Music automatically switches On
I think most Figo owners have confirmed this bug. I turn the system off manually, the next phone call comes and then the music turns on again (if you your volume higher for the phone call, then the music blasts out after the call ) . It is not a problem but a major annoyance for people who use the BT a lot. Thanks!
Happens to me all the time.
KiloAlpha is offline   Reply With Quote
Old 4th May 2011, 22:28   #4296
rohing's Avatar
Thanked: 48 Times
Mustang - I am pretty sure it a ALL Figo problem with no known fix and easily reproducible. Greatly appreciate you passing it on to Ford/Supplier. Thanks!
rohing is offline   Reply With Quote
Old 5th May 2011, 01:42   #4297
Thanked: 68 Times
I checked this today in my figo, and it does behave as rohing mentioned.
Not a problem for me though
Old 5th May 2011, 17:13   #4298
Captain Slow's Avatar
Thanked: 654 Times
Metro ford here did not rotate the tyres on my figo during the second service
When I asked the SA he told its to be done only at 20,000KM
The Annoying rear rattling sound is back again. Exactly 1000KM after the last service.
Captain Slow is offline   Reply With Quote
Old 5th May 2011, 17:37   #4299
anilisanil's Avatar
Thanked: 288 Times
Captain please pursue this with President's desk ford. I too am facing the squeaks problem for almost a year and now they are trying to tell me that it might be because of my car getting rear ended, though I would outright reject their thrash, a collective revolt should help. So please raise a request and let me know your request number. And let me know if you need mine!
Others, if you are facing the similar issues please let me know on PM, it is quite important for me to quote all these cases to them.
Just to be clear it more like chin chin squeaking noise like an insect's squeak.
anilisanil is offline   (1) Thanks Reply With Quote
Old 5th May 2011, 18:05   #4300
Sheel's Avatar
Thanked: 4,977 Times
A small irritant has cropped up.
My rear wiper is working, but not aided with the wash or water spray. I tried to clear the nozzle with a needle but to no avail. (And yes, there is water My front wash/wipe is working fine.)
Any solution guys?
Old 5th May 2011, 18:14   #4301
anilisanil's Avatar
Thanked: 288 Times
Any solution guys?
To make sure that the motor is working please let us know if it is making a humming noise of a motor, if there is some noise indeed then it is problem with the connections. If there is no sound then most probably your motor (or connections to it)has gone kaput and you may have to head to the service center in any case!
If you want to check yourself, you can remove the hatch door's panel (it has four screws and some plastic locks) and check if the connections are alright to the motor.
Old 5th May 2011, 18:21   #4302
Sheel's Avatar
I shall get that looked into.
Old 5th May 2011, 19:40   #4303
nkg77's Avatar
Thanked: 141 Times
Any solution guys?
Mostly the tube to the rear wiper nozzle would have gone loose in the engine bay. I had faced a similar issue with my Punto.
nkg77 is offline   (1) Thanks Reply With Quote
Old 6th May 2011, 10:53   #4304
Thanked: 23 Times
Sheel,
Had it been a while that, you had used your rear washer? My earlier Focus (ofcourse not here in India ), used to have the same problem, which the SA said, could be because of fluid drying out - due to vaporization / heat. Solution - hold the lever for a few seconds and the motor will pump the wiper fluid back. If this doesn't work and you dont hear the hissing noise of the motor, it could be the motor.
Electric is offline   (1) Thanks Reply With Quote
Old 6th May 2011, 12:22   #4305
I am already running 185/65 which is above the standard size and the car vibrates at 130 kmph. Also, when I had got the wheel balancing and alignment done for the old car, in the receipt it was mentioned that next one is due in 5K. Thats why I was thinking if its better to get it done.
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 884 28th December 2017 11:57
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
