Old 9th June 2011, 11:55   #4501
Thanked: 33 Times
Originally Posted by sumathindra
Thanks for the pictorial description. Will try and revert. I really do not understand why the Lathangi SA told that they have to loosen screws and then once done the seats will not fit snuggly as earlier?
Here is how I do it (with vinyl seat covers). You might need to move the front seats forward a little and for me the seat belt buckles remain under the seat as nobody uses those seats
gharika is offline   (1) Thanks Reply With Quote
Old 9th June 2011, 11:58   #4502
sumathindra's Avatar
Thanked: 192 Times
Default re: Review: 1st-gen Ford Figo (2010)
THANKS for the pics. Tell me is there some hook or holders for the seat? I tried it again y'day however it just did not budge :-(. Do you have to hold the seats near the center and just yank it towards you? Something is holding the seat and just not able to get it
picture of the rear seat of my ride.
http://www.team-bhp.com/forum/attach...t-dsc00589.jpg
sumathindra is offline   Reply With Quote
Old 9th June 2011, 12:17   #4503
Thanked: 33 Times
1. Push the seatbelt buckles under the seat between the gap of rear and base
2. Put your hand between this same gap and push up.
There are no latches for the base, only the two buttons for the back at each end, you need to press both to release it RTFM . You might need to open both the rear doors as well as the knobs for windows up down are a hinderance
Old 9th June 2011, 12:23   #4504
anilisanil's Avatar
Thanked: 288 Times
You seatbelt buckles may be obstructing. Open all the doors, push all the seat buckles and pull up. Use some force it should not be a problem! And have a close look at the gharika's pic the direction in which the seat flipped, if you try to pull it horizontally then it may not work, it should be at an angle.
anilisanil is offline   (1) Thanks Reply With Quote
Old 10th June 2011, 11:02   #4505
Thanked: 23 Times
Folks,
Does anyone have trouble streaming music from iPod via Bluetooth to the HU? My iPod is updated to the latest iOS version, and everytime I try to stream audio via bluetooth, the audio levels vary every few seconds / skips within the same track. Has anyone faced this problem? I am not sure if this has got anything to do with the iPod, as I am yet to check the audio streaming capability with another one, to rule out the possibility of iPod issue.
Electric is offline   Reply With Quote
Old 10th June 2011, 11:16   #4506
anilisanil's Avatar
Thanked: 288 Times
Originally Posted by Electric View Post
Folks,
Though not completely flawless, ipod streamed worked fine for me. A bit of variations in sound levels occasionally and nothing else. Will check again and let you know.
anilisanil is offline   Reply With Quote
Old 10th June 2011, 14:20   #4507
Thanked: 33 Times
Folks,
I have similar issues with iPad though it works fine with my HTC TD2 phone.
Old 10th June 2011, 18:28   #4508
Skyline GT-R's Avatar
Thanked: 202 Times
My Figo has developed an irritating sound.
While taking a left turn, there is a "khatt" sound coming from front end. Could not identify if it is suspension or steering box. The sound sometimes dissappears and then comes back. Drove the car in potholed roads, but there is no sound. Only in turnings & during lane changes.
Took the car to Kairali Ford. SA says it is because of Non OEM alloys & bigger tyres. Got an appointment for next Friday to open up the steering & suspension. No warranty so I may have to pay up for the spares if anything is replaced.
Anybody had similar issues?
Skyline GT-R is offline   Reply With Quote
Old 11th June 2011, 15:14   #4509
vinboy's Avatar
Thanked: 11 Times
After my Figo spent 3 days in the Metro Ford service station!, I was hoping that those irritating rear noise, dashboard noise, etc would not resurface! Sad but all the issues have resurfaced!! I do not know what to do!!
vinboy is offline   Reply With Quote
Old 11th June 2011, 17:14   #4510
Deep Blue's Avatar
Thanked: 231 Times
@vinboy-Get a good music collection, turn up the volume and enjoy the music
Deep Blue is offline   Reply With Quote
Old 11th June 2011, 17:31   #4511
jayded's Avatar
Thanked: 461 Times
Hey Skyline, I don't exactly remember your tire upsize, but have you checked if the tires foul with the wheel well on full rotation?
Few other things you could check if you've not done it yet, but I assume you would have done that already, however,
1) Loose mudflaps
2) Loose plastic panel covering the wheel well
3) It could also be the mudflaps touching the tires on rotation
Pray it's not something more complicated since your suspension/steering warranty is void.
jayded is offline   Reply With Quote
Old 11th June 2011, 18:25   #4512
Thanked: 86 Times
A few days back my car's bonnet hood release rod (the black stick which helps in releasing the latch) broke. Cheap quality plastics !
Went today to the dealership and got the hood release rod (black plastic thing to open the bonnet) replaced.
Hood release rod: Rs. 28.05 + 3.51 Tax (Acceptable price and I really appreciate that such small but useful parts are available and the company doesn't want us to change the whole unit and charge exorbitant price)
But what nullified the whole pleasant experience was -->
Labor (Just to screw up one nut): Rs 54.60 + 5.62 Tax Now that's called LOOT !
Total: Rs 92/-
When I asked the General Manager about the astonishing labor charge, he smiled and said: Sir, dealership hai. Itna to minimum lagta hi hai.
According to me, the labor should have been nil or at max Rs 5 + 1 Tax.
Then total would have been Rs 38/- only.
What I believe is that the American company didn't want the bill to be in cents. Dollars is what they love.
Diesel lover is offline   Reply With Quote
Old 11th June 2011, 19:07   #4513
Thanked: 202 Times
Tyre size is 185/65R14.
The sound is from a mechanical part. I called up the SA today on feeling a small vibration with the sound & he told it will be from steering rack.
Some noise is coming from the rear suspension as well. Could it be because of driving in the rain? I had driven through some muddy roads for past 2-3 days.
Old 11th June 2011, 19:25   #4514
aravind.anand's Avatar
Thanked: 1,818 Times
I think dealerships are to be blamed here, not Ford. Ford had introduced child spares with the Figo to lower the cost of ownership significantly, but looks like the dealerships are using this to gain profits now!
aravind.anand is offline   Reply With Quote
Old 11th June 2011, 19:45   #4515
Thanked: 86 Times
Aren't the labor prices same all over India? Or they wary from dealer to dealer? If they wary, then the dealer is to be blamed for such exorbitant pricing. If the prices are same, then the company is at fault since similar prices can only be there if the company sets the pricing.
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 884 28th December 2017 11:57
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
