Old 6th March 2012, 01:44   #6226
recshenoy's Avatar
Thanked: 104 Times
Default re: Review: 1st-gen Ford Figo (2010)
btw any idea what is the cancellation charges for Figo booking?
I saw this big AD of FORD on last page Time Of India Bangalore Edition today. It says Free Insurance! I just booked figo last month and yet to make payment other than 25K booking amount.I will be getting car anyways this month. So I guess i will call dealership tomorrow, cancel the booking and rebook the car if they are giving free insurance for March bookings! I mean why lose 16K, that is lot of money. Can get me neat alloys for car. Here is the link
http://epaper.timesofindia.com/Repos.../Img/Pg022.png
recshenoy is offline   Reply With Quote
Old 6th March 2012, 01:45   #6227
kingofmyworld's Avatar
Thanked: 249 Times
A question to all Figo owners, does ur ac stink when u turn it on after a long break? Like you start in the morning? My ac stinks for say some 20 seconds as soon as I turn it on in the morning or after prolonged pause. It smells bad with the blower on, but when I turn the ac, the stink is gone. Any sollution?
kingofmyworld is offline   Reply With Quote
Old 6th March 2012, 07:03   #6228
autocrat's Avatar
Thanked: 538 Times
This problem is not specific to Figo. Smells like damp dust and mold. You can get the ac vents and ducts cleaned, at a 3M facility. The solution holds for a few months and smell returns after 3~4 months.
autocrat is offline   Reply With Quote
Old 6th March 2012, 08:53   #6229
Blow Horn Ok's Avatar
Thanked: 455 Times
The OEM bulbs in my car are from DELA. The same set of bulbs were there in our 2003 Indica too.
Blow Horn Ok is offline   Reply With Quote
Old 6th March 2012, 09:44   #6230
supertinu's Avatar
Thanked: 481 Times
Did you book a petrol or diesel Figo? Even I had booked my Figo few days before the ad came in the new paper and called my dealer. He confirmed that the offer is only for petrol variants.
supertinu is offline   Reply With Quote
Old 6th March 2012, 10:03   #6231
Thanked: 16 Times
Clean the cabin AC Filter and avoid using the Fresh air mode while driving. Try to always set the airflow to recirculate mode and let fresh air in only through the windows when needed. This worked for me.
Prass is offline   Reply With Quote
Old 6th March 2012, 10:32   #6232
Thanked: 455 Times
Any car AC even a household AC smells a bit when running in blower mode. This is due to dust and fungi i believe. The solution is AC filter and duct cleaning. Since your car is too new, you need not require to carry on such type of cleaning. I suggest to bear with it and get it cleaned next year.
Old 6th March 2012, 10:54   #6233
DevilsCry's Avatar
Thanked: 503 Times
Originally Posted by Deep Blue View Post
Is the whole cluster the problem? How does cluster design improve illumination?
When I was considering to buy my Figo, I followed Figo Facebook fan page for 4 months and kept reading what hundreds of owners had posted regarding headlamp issues. I saw that no matter what bulb they fitted, they were never satisfied with visibility and kept complaining that there headlamp cluster was not correctly designed. I also noticed that newer Figo owners (after Sept'11) never complained about headlamp issues. Decide yourself what could have been wrong.
I had cancelled my petrol Figo booking in Sept'11 from a dealer to buy it from another dealer. Cancellation charge = zero.
Like others advised, please keep AC in circulation mode only. Now you'll have to clean the AC filter. You can read the following thread on how to do it - http://www.team-bhp.com/forum/techni...ford-figo.html
DevilsCry is offline   Reply With Quote
Old 6th March 2012, 11:46   #6234
Thanked: 249 Times
I never keep the blower in fresh air mode in any of my cars. Right from day 1 it was only in recirculation mode.
I checked with some other cars and found the same issue. Checked it even on my friend's new gen A6 and surprisingly even that has the same issue with the smell.
@devilscry : Shall try out the DIY you listed. I like DIYs
Old 6th March 2012, 12:09   #6235
Thanked: 16 Times
Also check the water drain pipe from the evoporator coil for any block. A little water trapped may be the cause of this smell.
Old 6th March 2012, 13:32   #6236
blackfire_9's Avatar
Thanked: 187 Times
There is something that I would like to share & I believe this could help you since the issue is pretty recent.
Start your car & switch on the heater unit on max temperature, with blower on some medium speed with the vents closed. Roll up the windows & let the heater/car run for about 10 mins & then switch it off. I think you would need to have your spare key with you just in case the car locks itself.
We have been doing this with all our cars at least once a year, especially during monsoons & we have never required any sort of duct cleaning.
Try it out, there is no harm in it. I hope it would help you out.
blackfire_9 is offline   (1) Thanks Reply With Quote
Old 6th March 2012, 13:53   #6237
recshenoy's Avatar
Thanked: 104 Times
Angry re: Review: 1st-gen Ford Figo (2010)
Thanks supertinu. yeah i called dealer today morning eagerly to find that discount is only for Petrol Figo. Full night i was browsing to check which alloy to go for with extra 15K which i might get due to free insurance
Btw, any one has fitted Chrome exhaust tip for Figo? Looks like rear bumber is to be cut little bit to get exhaust tip fitted.
Old 6th March 2012, 14:23   #6238
Thanked: 187 Times
I was planning to get it installed but decided to keep this upgrade for later. In case, you decide to go ahead with it, please do share the details on what special was done to accommodate this thing.
Old 6th March 2012, 15:41   #6239
Deep Blue's Avatar
Thanked: 237 Times
The OEM bulbs in my car were HALONIX. After " the high illumination upgrade", it was changed to PHILLIPS. The spare bulbs provided are from DELA.
Deep Blue is offline   Reply With Quote
Old 6th March 2012, 15:43   #6240
Thanked: 455 Times
So the Installed bulbs are different from the pair of spare bulbs? Didn't notice that!
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 898 2nd July 2018 12:12
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
