Old 25th May 2012, 23:27   #6676
DRIVE_ADDICT's Avatar
Thanked: 181 Times
Default re: Review: 1st-gen Ford Figo (2010)
Originally Posted by Warwithwheels View Post
When I turn the Headlight switch ON, I am able to feel something from the engine cabin which gives you an illusion that the lamps put on an extra load on some mechanical part.
Same thing happens when you use the high beam flasher on the indicator stalk. Anybody experiencing the same?
Is that normal?
Can you be specific, what exactly you feel inside engine cabin? I haven't experience anything of this kind. but it sounds like some loose connection which might sooner ends with burned fuse. Get it to SC.
DRIVE_ADDICT is offline   Reply With Quote
Old 26th May 2012, 00:11   #6677
dhanushs's Avatar
Thanked: 4,472 Times
Is that normal?
Hi Warwithwheels,
Its quite normal. The extra load is put on the alternator, and it is the same for every car. You can feel it only when you observe closely, like while idling quietly.
Same thing happens when you flash, both dim and bright filaments glow, putting additional load on the alternator. This is normal for all cars, but in some, its pronounced.
Old 26th May 2012, 11:10   #6678
Warwithwheels's Avatar
Thanked: 1,026 Times
Hi Warwithwheels,
Exactly dhanushs, I can feel it only when the car is idling, not when it is being driven. I've got 100/90 on the figo, do you think its quite too much for the car's alternator to handle? Apart from the headlamp, everything else remains stock.
Sorry for not being very specific. Dhanushs has explained the phenomenon pretty well. I don't think it could be a case of loose connection.
Warwithwheels is offline   Reply With Quote
Old 26th May 2012, 13:03   #6679
dhanushs's Avatar
Warwithwheels, 100/90 should be just fine. Infact, even in stock bulbs you can feel this phenomenon.
When the current through the circuit increases, it automatically increases the magnetic field in the alternator, which inturn puts additional load on the pulleys, which loads up the engine, and hence the feeling. The ECU compensates for this loss and maintains idle rpm.
I know a Figo which runs two lightforce fogs, a massive sub-woofer and some cool interior lighting, with absolutely no issues.. So, your 100/90 upgrade should be just fine.
Old 28th May 2012, 20:12   #6680
PrideRed's Avatar
Thanked: 1,961 Times
Originally Posted by kart19 View Post
What degree of rattle is acceptable rattle?
Thanks in advance!
Mine is at level 0. There had been squeaks after around two months of purchase. Had taken it to Metro Ford B'lore and the mechanic was spot on. He took few minutes and gone are the squeaks.Two years now and i must say its been a rattle free ride
PrideRed is offline   Reply With Quote
Old 29th May 2012, 18:16   #6681
blackfire_9's Avatar
Thanked: 187 Times
Guys, any idea on what make is the Figo's OE oil filter & where in Delhi can I find it?
Old 30th May 2012, 14:46   #6682
Thanked: 12 Times
With the current hike in petrol prices i am looking to change over to a diesel and am confused between fiesta (classic) and figo. Not sure which thread to post on.
Request the experts to provide their opinion
macbeth is offline   Reply With Quote
Old 30th May 2012, 18:22   #6683
M5_fan's Avatar
Thanked: 18 Times
The fiesta classic is the better overall car but is pricey. So it all depends on your budget. The fiesta is more refined, has better ride, better handling, better effective ground clearance, better headlamps and also has a boot for your travel needs. Service costs for figo and fiesta classic are more or less the same.
M5_fan is offline   Reply With Quote
Old 30th May 2012, 20:38   #6684
Thanked: 187 Times
Guys, any help with this query please. The authorized SC does not have a provision of counter sale.
Old 1st June 2012, 13:38   #6685
CARDEEP's Avatar
Thanked: 1,542 Times
Infractions: 0/1 (5)
The Ford Figo facelift has been spotted testing in Chennai. Link to ACI report:
Ford Figo facelift spy pics - News - Autocar India
The Figo will get updated tail-lamps and front-end styling. It could resemble the Fiesta hatch that is sold in South America. The new Figo will get new paint-shades (speculated), & probably, there could be some changes in the interiors as well, with no changes in the engines.
I wish they install the 1.5L Fiesta engine in the same or offer VGT in the higher spec variants.
CARDEEP is offline   Reply With Quote
Old 1st June 2012, 15:52   #6686
AltoHoncho's Avatar
Thanked: 13 Times
Originally Posted by M5_fan View Post
The fiesta classic is the better overall car but is pricey. So it all depends on your budget. The fiesta is more refined, has better ride, better handling, better effective ground clearance, better headlamps and also has a boot for your travel needs..
I have doubts on this one on a long-term basis. I recon, that Fiesta would end up being more expensive than the Figo. I own a Figo but not the Fiesta, maybe a comparative analysis would help here.
AltoHoncho is offline   Reply With Quote
Old 1st June 2012, 18:44   #6687
figo_mba's Avatar
Thanked: 208 Times
Both fiesta classic and figo are based in the dame platform.. The fiesta is more refined.but dynamics wise I think figo is better. you van call the current fiesta classic a figo with a boot.
figo_mba is offline   Reply With Quote
Old 1st June 2012, 18:53   #6688
Thanked: 195 Times
I sent my new figo for her first service (2.5k). Talked to the service advisor about the single horn being inadequate. He says there is a Ford authorized accessory dual horn kit with relay , wiring and Roots vibrosonic horns for Rs . 2500/- labour + taxes = 3200/-. The car, however needs to stay back overnight. Will know tomorrow if the horns make a difference to hundreds of goats in my locality.
sunsetorange is online now   Reply With Quote
Old 1st June 2012, 23:52   #6689
recshenoy's Avatar
Thanked: 104 Times
2.5K? sounds little expensive rite. How much would it cost if you fit after market horn, I guess horn is not so expensive.
I am also going for first service tomorrow. Any thing to be taken care or a normal service? Have you requested for oil change, what was Service Advisers opinion after checking current oil.
recshenoy is offline   Reply With Quote
Old 2nd June 2012, 00:01   #6690
tharian's Avatar
Thanked: 3,094 Times
Roots Vibrasonic is quite a loud set of horns.
Its actually worth for the highways and good when fixed on the outside like the Jeeps and Amby's.
Obviosuly on a Figo, you cant. Hopefully it does not sound like the horn is fixed inside the car when used.
I guess he meant it was actually working out of 3.2k, which is expnesive since it is a A.S.S doing it
tharian is online now   Reply With Quote
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 887 18th March 2018 14:33
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
