Old 12th January 2013, 00:25   #7606
jayded's Avatar
Thanked: 472 Times
Default re: Review: 1st-gen Ford Figo (2010)
Originally Posted by Blow Horn Ok View Post
Another annoying niggle is the brake caliper noise from the front left. Greasing works well but the annoying rattle starts again after couple of hundred kms.Any permanent solution to this?
This is one thing that bugs me the most. I've taken my car to the A.S.S. like 5 times now for the very same issue and every time they grease/tighten something and the rattle is gone for a couple of hundred kms after which it resurfaces. The next time it comes up, I am going to email Ford.
Originally Posted by vnabhi View Post
Folks
Has anyone got a second beep reminder when the DTE is 40 kms? I do know that the low fuel lamp comes on when the DTE is 80 kms, accompanied by a beep.
Yes Venu sir,
There are 2 low fuel warning chimes in Figo, one at DTE 80 and the other at 40.
jayded is offline   (1) Thanks Reply With Quote
Old 12th January 2013, 09:58   #7607
Vid6639's Avatar
Thanked: 21,060 Times
Originally Posted by jayded View Post
Yes Venu sir,
There's also a chime at 20kms.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 12th January 2013, 10:40   #7608
vnabhi's Avatar
Thanked: 1,317 Times
Holy cow, I have not risked going that far!! But it is really nice to know about this feature.
The chimes are missing on my Fiesta.
Old 12th January 2013, 14:53   #7609
Blow Horn Ok's Avatar
Thanked: 455 Times
Originally Posted by Deep Blue View Post
However after a few trial and errors attempts spread over an year, Cauvery Ford finally localised it to the shocks and replaced them. After the right, the left began to act up and that too was replaced. Eversince I have not had that sound.
I guess it is caliper noise. I have experimented by applying light brake over bad roads and the sound disappears. I guess when the calipers are lodged and in action, there is no sound. Whereas, going over bad roads without applying brake results in rattling kind of noise. The mechanic @ the FASS told that it is indeed caliper noise and the shocks are OK. He said its a common niggle. Either to bear the noise or get it greased regularly
I guess replacing the calipers could be one of the solutions. The mechanic told that this particular problem is resolved in the newer cars, but present in earlier ones.
I have driven the car 10 kms after the DTE showed '0'. But it was an emergency and I had no choice.
Blow Horn Ok is online now   Reply With Quote
Old 12th January 2013, 22:09   #7610
Deep Blue's Avatar
Thanked: 237 Times
I had this noise within about a month after buying the car. First I was told it is the dashboard, then steering column, then caliper. The next time, SA said he put my shocks on another Figo and the sound was replicated in that car too and that is when they changed my shocks.
When the noise first appeared in my old Alto, it was diagnosed by the mechanic by giving a kick on the tyre in a stationary car and the sound appeared. I had tried the same on the Figo, the sound hadnt come.
Deep Blue is offline   (1) Thanks Reply With Quote
Old 13th January 2013, 12:47   #7611
tharian's Avatar
Thanked: 3,167 Times
Originally Posted by Sedate View Post
It happened to me today. I thought it was due to my deceleration or because I was in wrong gear (which normally never happens). I never knew the engine was off until the steering felt heavy. The chimes sounded like the low fuel chimes. But later only I realized that the engine was off. I don't run my car in the test mode.
It should be a one off . I am waiting for it to happen again after which I will think of updating the ECU software. I dont think it will re-occur though.
tharian is online now   Reply With Quote
Old 13th January 2013, 14:17   #7612
Sheel's Avatar
Thanked: 5,646 Times
Got follow up calls from Ford India as well as a mail. I am going to the dealership tomorrow, shall up-date their response.
The response from Ford India (Official) was pleasant (by the way I was explained things).
Shall update tomorrow by late evening or on Sunday.
Had gone to the dealer yesterday. As usual, the dealer wanted to cover up for their folly (coolant & that after escalation, my Car was taken up for service).
They were all over me that I should send a goody goody e-mail that all went well. The sad part is they didn't really owe up, that yes, a mistake is committed, was our fault & we shall see that this doesn't happen.
The SM while on phone with someone from Ford India agreed that yes, level was low. And he would be checking my arrival & departure time & would be sending it. He was the one with whom I escalated the issue, I really don't know what he needs to check.
The response from Ford India is exemplary & I am really happy & satisfied. I got repeat calls almost always, explaining everything in detail & attending to whatever concern I had. Had they not monitoring the ASC, I fear, I wouldn't have gone to them.
Thanks Ford @ India
Sheel is offline   (3) Thanks Reply With Quote
Old 13th January 2013, 17:23   #7613
Thanked: 455 Times
I tried to replicate the tyre kicking today and the left one clearly rattles as compared to the right one. Have captured a video. One should notice the difference between the sound of left & right tyre.
Blow Horn Ok is online now   (1) Thanks Reply With Quote
Old 14th January 2013, 12:11   #7614
Deep Blue's Avatar
Thanked: 237 Times
Though it is difficult to make out from a video, there clearly is a sound which was not there in my car. So I guess you have the caliper sound.
Deep Blue is offline   Reply With Quote
Old 14th January 2013, 15:05   #7615
Thanked: 455 Times
Yes the rattle is not clearly audible in the video, but the noise is clearly on the higher side on the left tyre. Can It be noise of axle??
Old 15th January 2013, 19:31   #7616
Deep Blue's Avatar
Thanked: 237 Times
Don't know about the axle, but remember reading somewhere here about the stabiliser bar touching IIRC the torsion beam.
Old 23rd January 2013, 12:57   #7617
Ranga's Avatar
Thanked: 43 Times
Default Friends Ford Figo PCM Fails / Standered in Shimoga
My close friend's FORD FIGO's (1.4 LTR Diesel engine ) PCM unit failed recently while he was driving back from Shimoga to bangalore . The car had to be left behind in Shimoga and local help had to be called to understand what went wrong ( The car had to be towed to the nearest service center )
The car doesn't power on , and it has been diagnosed as a PCM unit failure .
This is the main program control monitoring system of the car ( looks to be ECU control unit ) which has failed .
The car is 2 months old and has been driven for 3800Kms .
This is a serious quality issue from Ford !!!
Has any one faced similar problem on Ford Figo ?
Ranga is offline   Reply With Quote
Old 23rd January 2013, 21:17   #7618
Thanked: 69 Times
Default Re: Friends Ford Figo PCM Fails / Standered in Shimoga
This is a serious issue, Hopefully your friend can replace the part under warranty.
On a side note, We can blame this on FORD if the issue is common one. I don't think any one else has faced this issue before. Car is a big unit in which numerous Mechanical and Electrical/Electronic unit work in tandem, we can always blame the manufacturer if we have a mechanical failure because most of them can be identified by proper inspection. When it comes to electronic unit the story is totally different, properly inspected electronic units may fail, with out any notice . If the failure repeats on more than 1 car, then Ford must check this out. Else, it may be just a random failure. Unfortunately its your friend who has to suffer.
I am not vouching for Ford here, just wanted to make my point.
limited-edition is offline   (3) Thanks Reply With Quote
Old 28th January 2013, 21:41   #7619
ramharis's Avatar
Thanked: 50 Times
Has anybody tried to increase the rear seat inclination on the figo. The rod thats attached to the c-pillar has about 2 inch protruding from the mounts, what if we remove it reduce the distance so the seats will get inclined a bit more. My mom says Ikon's seat is much more comfortable than in figo.
Will try and post pics of what iam on about. If anybody has tried it, let me know the Pros and Cons on doing that.
ramharis is offline   Reply With Quote
Old 29th January 2013, 12:11   #7620
My new Figo has barely crossed 500km on the odometer and has started squeaking on undulating roads. These squeaking sounds seem to come from left side below the dashboard. Any idea what could be causing it?
b_naresh is online now   Reply With Quote
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 898 2nd July 2018 12:12
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
