Old 24th April 2013, 16:14   #8101
Arch-Angel's Avatar
Thanked: 277 Times
Thumbs up re: Review: 1st-gen Ford Figo (2010)
Originally Posted by DRIVE_ADDICT View Post
Guys, Is it possible to get the handbrake console (the one which comes in Titanium version) outside FORD ASC, (i.e) from any accessory shops? I have seen them in ASC but it was pricey ~3k.
I was actually planning to add Arm rest, to fix the arm rest this handbrake console is necessary it seems.
Hi Drive addict,
I have a titanium variant and i am unable to comprehend what this handbrake console is. Could you post a picture of the section without the handbrake console so that i can comprehend it better? If its available outside, it should be there on Gp road. Afaik, some people usually drill holes and attach the armrest directly. It should come close to 1/3rd the A.S.C's quoted cost but i would try finding it on G.P road since i have heard from my cousin that the people there literally have everything.
Arch-Angel is offline   Reply With Quote
Old 24th April 2013, 16:35   #8102
DRIVE_ADDICT's Avatar
Thanked: 181 Times
Default re: Review: 1st-gen Ford Figo (2010)
Originally Posted by Arch-Angel View Post
Hi Drive addict,
you will get an idea from the following pictures
DRIVE_ADDICT is offline   Reply With Quote
Old 24th April 2013, 16:50   #8103
Arch-Angel's Avatar
Thanked: 277 Times
Ah thanks for the pics DriveAddict! I think you mean the handbrake shroud. I think it should be available in G.P road.
Note: I will definitely take a look at my car and confirm. I haven't paid that much attention to it.
Arch-Angel is offline   (1) Thanks Reply With Quote
Old 24th April 2013, 21:19   #8104
venkyhere's Avatar
Thanked: 515 Times
i know mfer-s cut corners to save cost, but i think ford went too far with this. I have never seen such a 'visible' botch-up. Its just a piece of hard plastic, why not chuck it in all variants - too bad !
venkyhere is offline   Reply With Quote
Old 24th April 2013, 23:13   #8105
Flying Djinn's Avatar
Is it possible to add adjustable head rests to the Figo rear seats? I'm considering the car but the lack of adjustable rear head rests bugs me more than the lack of power windows. :(
Flying Djinn is offline   Reply With Quote
Old 25th April 2013, 10:56   #8106
Thanked: 181 Times
If thats the ONLY concern, you can add it. It is possible and Koyas coimbatore had showcased it on their website. You can see they also add extra thigh support on seats.
Looks too good.
http://www.koyas.net/UpholsteryModels.aspx?modelid=77
Old 25th April 2013, 13:43   #8107
Looks too good.
Thanks! That does look very good. Has anyone else got it done?
Old 26th April 2013, 13:03   #8108
Sheel's Avatar
Thanked: 5,586 Times
I see my brake-fluid close to the low mark level. Can I add Motul's DOT 4 brake oil as top-up?
Old 26th April 2013, 13:56   #8109
A350XWB's Avatar
Thanked: 620 Times
I think it should be OK to top-up with DOT-4 oil of any reputed brand. The specification says that it should be DOT-4, that's all. I had topped up mine with DOT-4 from Castrol. [DOT-4]
A350XWB is offline   Reply With Quote
Old 27th April 2013, 17:53   #8110
Sheel's Avatar
What power steering oil does the Figo use? What specifications & which company manufactures oil close to these specs & grade?
Old 27th April 2013, 22:27   #8111
Blow Horn Ok's Avatar
Thanked: 445 Times
Changed the stock headlight bulbs with Osram Night breaker 60/55W. Haven't tested it while driving (throw & spread) but the light is surely 10-15% brighter and whiter. I am sure it would illuminate the road better than the stock bulbs. Also, the night breakers were tad smaller (the filament side) than the stock Halonix bulbs.
Will take the car tomorrow to a local mechanic to get the brake caliper rattling noise solved. He is expert in Maruti Cars but has assured that its a common problem in alto and swift etc and he would rectify the rattle easily in around 1 hour and it would not return back.
Blow Horn Ok is offline   Reply With Quote
Old 27th April 2013, 23:15   #8112
rajeev k's Avatar
Thanked: 1,749 Times
Originally Posted by Blow Horn Ok View Post
...to a local mechanic to get the brake caliper rattling noise solved. He has assured that its a common problem in alto and swift etc and he would rectify the rattle easily in around 1 hour and it would not return back.
Thisis quite a common problem and is generally solved by placing shims.
rajeev k is offline   Reply With Quote
Old 28th April 2013, 14:43   #8113
Thanked: 445 Times
I was tied up in some other work and will get it repaired tomorrow. Placing the shims won't create any problem in movement of caliper pins or any other braking problem?
Old 30th April 2013, 13:45   #8114
RGK
RGK's Avatar
Thanked: 221 Times
My car has done 27k in the 3 year period and did my 4th service (Earlier batch cars had 1st service at 2500kms).
I see a better mileage after that. I am able to hit ~17kmpl in the city. One of my friend who completed 4th service is able to clock 22kmpl on the highway at 100kmph.
Planning to do a long drive next month. Is this due to the Fuel Filter replacement?
RGK is offline   Reply With Quote
Old 30th April 2013, 15:40   #8115
Thanked: 181 Times
MRF zv2k on my figo TDCI ran ~14800 km got a little damage. Will this create any issue for a highway run? I'am planning to take it out for this weekend.
Is this damage affect the tire in long run?
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 887 18th March 2018 14:33
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
