Old 15th October 2013, 21:17   #8641
Thanked: 298 Times
Default re: Review: 1st-gen Ford Figo (2010)
Thanks ramzsys, I'll try to get the old one repaired.
BTW the rear parcel tray of Maruthi Alto was Rs. 1500/-
wildsdi5530 is offline   Reply With Quote
Old 16th October 2013, 07:02   #8642
tharian's Avatar
Thanked: 2,790 Times
Anyone who has replaced the tail lamp cluster knows how much they cost and if it is available as single or a set?
My car is going through a bad time. First the wheel bearing, now one side tail lamp has a hole in it thanks a ignorant fool on a two wheeler .
Also thinking of using this as an excuse and check if the new tail lamp cluster can be installed on the old Figo. The wiring needs to be swapped which I am sure the Service Center will make a scene of.
tharian is offline   Reply With Quote
Old 16th October 2013, 10:11   #8643
Captain Slow's Avatar
Thanked: 654 Times
I don't know about the current prices, But 2-3 years back When some moron biker broke my tail lamp assembly I had replaced it with a new one from the A.S.S for > 1,000 and 100 as fitting charges.
They sell them individually.
Why would you want to replace the both the tail lamps when only 1 is broken?
Originally Posted by Warwithwheels View Post
34 psi is just perfect for the Figo. I have managed not to bottom out even on the most unscientific speed breaker after the bump up in the tyre pressure.
Any Punctures maintaining at this PSI?
Captain Slow is offline   (1) Thanks Reply With Quote
Old 16th October 2013, 10:16   #8644
tharian's Avatar
I wasn't sure if Ford sold them as a single unit since most of their parts are sold in pairs or sets , like the mudflaps.
In this case I can go for the single piece and forget the new type tail lamp design.
Old 16th October 2013, 10:38   #8645
sameerg001's Avatar
Thanked: 424 Times
No, ford or any other car manufacturing company for that matter, do sell headlights and tail lamps in single units.
sameerg001 is offline   Reply With Quote
Old 16th October 2013, 10:47   #8646
kpzen's Avatar
Thanked: 1,613 Times
Tail lamps, Left & Right are available separately.
Mud flaps is an accessory not a BOM part.
kpzen is offline   (1) Thanks Reply With Quote
Old 16th October 2013, 11:07   #8647
supertinu's Avatar
Thanked: 457 Times
Originally Posted by myavu View Post
We are maintaining 34 psi. (a stiff setup is an add-on for the already renowned handler) Mostly solo drive and using for 95% inside City. No more belly scrape.
Cheers!
Vinu
Stiffness is there. But I like that much stiffness for cornering and braking. By the way we are riding inside city which have more or less well carpeted roads.
And less rolling resistance means less fuel burned/km.
Cheers!
For a city like Bangalore with less than carpet smooth roads, 34psi is rather on the higher side in terms of stiffness. Ride does get bone jarring at times at lower speeds. I usually keep 32 but tempted to reduce to 30 at cost of fuel efficiency. Another factor in play is the apollo acceleres on my car. They are definitely on the harder side. Upgrade to Michelins or any other softer rubber would certainly mitigate the stiffness.
supertinu is offline   Reply With Quote
Old 16th October 2013, 18:50   #8648
Thanked: 298 Times
@sameerg001, @kpzen: Ford fusion headlamps cannot be bought individually. I learnt this when the housing of the right headlamp had cracked and I had to replace both as they are provided only as a set. Maybe things are different with the Figo.
Old 17th October 2013, 00:05   #8649
powerband_rider's Avatar
Booked a petrol zxi today! Yipee.
Primary concern was the low-slung nature for my folks. But all is well, as they tried it out and found it alright.
My heart was always set on the diesel, as I got a chance to drive one quite a bit in the recent past and loved it.
The petrol does not really set pulses racing, taking its own sweet time to get moving! But this car will be used occasionally + within city (no scope for speeding in Pune traffic anyway).
The overall package is brilliant - Compact yet spacious/solid build/balanced ride/decent features.
Will be inspecting the immediately available car in a day or two at the dealer's yard. Anything I should particularly look out for apart from the VIN and regular inspection?
Fingers crossed.
Cheers!
powerband_rider is offline   Reply With Quote
Old 17th October 2013, 07:43   #8650
Thanked: 69 Times
Originally Posted by powerband_rider View Post
Booked a petrol zxi today!...Anything I should particularly look out for apart from the VIN and regular inspection?
Fingers crossed.
Cheers!
Congrats on your new ride :-). Figo's dynamics is brilliant!!. Regarding PDI, go through this link, http://www.team-bhp.com/advice/pre-d...pdi-check-list. It covers everything :-).
limited-edition is offline   Reply With Quote
Old 17th October 2013, 09:10   #8651
Catalyst_delhi's Avatar
Thanked: 148 Times
I went to Ford yesterday with my Boss's Figo for a wheel cap. 800 Rupees for a 2010 Wheel cover. They sell single not sure on the rates but.
Catalyst_delhi is offline   Reply With Quote
Old 17th October 2013, 22:45   #8652
Thanks mate! The PDI checklist is such a help. Jai Ho Tbhp
Will be visiting the stock yard tomorrow. Its 35-40 Kms away from my place! Will be a road-trip in itself.
Old 18th October 2013, 09:46   #8653
sumathindra's Avatar
Thanked: 192 Times
This is the second time the fuse is blown which powers the clock/display on the system when the car is started.
Has anyone faced a similar issue?
sumathindra is offline   Reply With Quote
Old 18th October 2013, 13:32   #8654
vnabhi's Avatar
Thanked: 1,240 Times
Not in the last one year of ownership. Yes, my car completed a year today, and has clicked 13200 kms so far.
The only issue I had was of a rear wheel bearing, that was replaced under warranty.
Old 18th October 2013, 22:32   #8655
sameerg001's Avatar
Thanked: 424 Times
So, the engine check light flashed again and this time, it didn't went away easily. Earlier the issue used to happen every 500-600 kms and after 3000 kms, it never came. I thought could have been due to the rain, But as soon as i crossed 6000 mark on odo, day before yesterday.
It again came and this time even after restarting the car, It used to come again in 1-2 kms and when the light flashes, the car won't rev over 2.8k . So, finally after getting irritated, took it to service center early morning today, left the car at 11 and they diagnosed it as issue with one sensor associated with accelerator pedal, They said they'll replace it in 2-3 days, as they didn't had it in stock.
I took the car back at 3 PM drove around for 8-10 kms, The light came once but didn't showed up again. Now, waiting for the ordered part to be changed. Otherwise, car is working beautifully, the average consumption so far is 15.6, majority of delhi peak hour driving, with full AC. I am quite happy with the car and thanks to soild built, no rattles so far
I'll update once again, the said part is replaced.
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 884 28th December 2017 11:57
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
