Old 14th June 2014, 10:31   #9391
tharian's Avatar
Thanked: 3,174 Times
Default re: Review: 1st-gen Ford Figo (2010)
Originally Posted by Warwithwheels View Post
My Figo D's air con is making all sorts of weird noises on the move.
Cooling is perfect. There's nothing to complain about the cooling part.
But I could here the sound of a broken toilet pipe choking out while the AC is on.
Has anybody faced this issue?
Is the choking sound from the blower? I had the same issue a while back after the end of a long trip. The blower, even without the air con turned on, used to break up. It becomes quite clear when the blower is in max speed. I had to turn off the AC for a while and then turn it on for it work.
But, that is the issue many owners have faced and I got it fixed at a independent AC repair shop. Topped up the gas and cleaned the evaporator and condensor.
tharian is offline   Reply With Quote
Old 14th June 2014, 15:39   #9392
Thanked: 83 Times
Folks,
Gave my car for the 30k service today. No major issues, the SA called up & informed me that there is a noise from the engine & upon inspection found out that there is a problem with an injector. SA confirmed that the replacement is covered under warranty, I gave a go ahead to change it.
Wanted to check if this can happen on a car driven for 30k & have I done the right thing by asking them to replace it.
Venkat_Figo is offline   Reply With Quote
Old 16th June 2014, 15:54   #9393
ramharis's Avatar
Thanked: 50 Times
Originally Posted by supertinu View Post
I have something similar happening in my car. When i turn the ignition on, all the dash board lights turn on and gradually they turn off except for few along with the 6-7 beeps. After that when I crank the engine, the ABS light turns on for a fraction of a second along with a short beep. It goes away once the engine is on. Not sure what causes it. Showed it to A.S.S and he said it was no issue. Did you get any root cause for this, how is it linked to battery?
A.S.S say its because of the battery, while cranking the car uses a lot of power. Took the car to a Amaron Battery shop guys, they checked the battery volts while cranking, the volts went down to 8 whereas it should have been 12. The reason A.S.S provided was when the engine is cranked, the ABS system is checked and due to less power, the ECM think the ABS system is faulty. Its time for me to replace the battery anyway, so iam going to change it this week. Will keep posted if it resolves the issue.
Ram
ramharis is offline   (2) Thanks Reply With Quote
Old 18th June 2014, 11:14   #9394
RGK
RGK's Avatar
Thanked: 221 Times
It is good to see your SA notified this.
My car's injector was changed around 7k and another one was replaced around 36k due to uneven diesel inflow to the chamber. Both were done under warranty.
Do check your service bill to see the part replaced with zero charges.
RGK is offline   Reply With Quote
Old 18th June 2014, 14:27   #9395
supertinu's Avatar
Thanked: 481 Times
Folks,
Injector change happened on my car as well at around 20K km. I felt there was knocking kind of sound during idling and low rpm and pointed it out to A.S.S. Upon checking they said one of the injectors isn't working well and changed under warranty. Costed ~24K for the 1 injector. I though injector failure should be a rare item but looks like it is happening more often.
supertinu is offline   Reply With Quote
Old 18th June 2014, 14:37   #9396
mayankk's Avatar
Thanked: 3,559 Times
24k??
Made out of carbotanium or what?
mayankk is offline   Reply With Quote
Old 22nd June 2014, 16:47   #9397
Thanked: 83 Times
They changed a total of 4 injectors, I was shocked but nevertheless was done under warranty, hence nothing paid from my pocket.
I was gonna install a race chip in July, I believe the race chip is programmed to make the injectors inject more fuel. If this is the case then maybe I may have to get the injectors changed more frequently.
Old 22nd June 2014, 17:07   #9398
auto_enthusiast's Avatar
Thanked: 363 Times
At what kms were the injectors replaced. Even though it was covered under warranty, what was the cost of the injectors?
auto_enthusiast is offline   Reply With Quote
Old 22nd June 2014, 22:32   #9399
Thanked: 83 Times
They were changed at 30k. I asked the SA about the price of the injectors, she said they are covered under warranty, did not bother to check much. Will call them up & check.
Really bothers me, as I have a feeling they may cost a bomb. Post the warranty expires, they could drill a huge hole in my wallet. Or I may have to sell it once the warranty expires (I'd hate to do it, as I love the car).
Old 24th June 2014, 11:27   #9400
KiloAlpha's Avatar
Thanked: 1,605 Times
Ram
The ABS Light coming on and beeping just after cranking the engine has started in my car as well. It happened last week a couple of times, when I started the car first thing in the morning, but not otherwise.
My car is a May 2010 model, so I guess the battery is now due for replacement?
KiloAlpha is offline   Reply With Quote
Old 24th June 2014, 16:58   #9401
ramharis's Avatar
Thanked: 50 Times
I had the Battery replaced with Amaron Flo (with 2 years gaurentee then additional 2 year warranty), total of 4 years. Costs Rs.4100 (with exchange of old battery). And yes it has fixed the issue, I dont have those beeping and ABS lights while cranking.
It does not happen when the car has run for sometime, since the battery would have been charged completely. It did start once a day then became twice, the last 2 days, it happened everytime I start the car. Please check the battery condition before you have it replaced.
Ram
Last edited by ramharis : 24th June 2014 at 17:02. Reason: Addition of information
ramharis is offline   (1) Thanks Reply With Quote
Old 25th June 2014, 01:41   #9402
kingofmyworld's Avatar
Thanked: 249 Times
Sorry for the OT guys. Does anybody from here have a broken tail lamp of a figo? Need one for experimental purpose. All i need is the housing. Lens doesn't matter at all.
I'm in the process of making the tail lamps look far better and cannot afford to mess with the stock ones. So looking for a spare/broken one.
Any help would be much appreciated. thank you.
kingofmyworld is offline   Reply With Quote
Old 25th June 2014, 05:50   #9403
TheARUN's Avatar
Thanked: 498 Times
OT Again!
I have a pair of tail lamps for the Santro, would they be of any help? You can take them free but I stay in Bangalore
TheARUN is offline   Reply With Quote
Old 28th June 2014, 13:44   #9404
Came for regular service of my Figo 1.4 - all done smoothly, but then my SA informs me that there is some noise coming from the power steering pump. Also the power steering fluid seems to have some debris. According to him the PS pump needs to be changed Its just 46k on odo and 3 yrs plus one month of ownership. Cost of pump is approx 8.5k. Can ps pump fail so soon? Is changing the pump my only option. Since the car is anyways out of warranty and am informed that i would be charged in full for this, should i look to get this done outside ASS?
Sameer_Gupta is offline   Reply With Quote
Old 28th June 2014, 23:45   #9405
Thanked: 360 Times
Where are you going to get a genuine PS pump? My steering column had squeaking at 70k service. The column has been changed. Once we buy a car we are at their mercy. Get it changed at the ASS itself.
And hope the next service doesn't serve up any more surprises. One should be thankful that services are at 10k intervals.
wildsdi5530 is offline   (1) Thanks Reply With Quote
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 898 2nd July 2018 12:12
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
