Old 21st October 2016, 11:56   #10426
Thanked: 255 Times
Default Re: Review: 1st-gen Ford Figo (2010)
I wanted to share an experience I had a couple of days ago with my Figo (2012 Exi Petrol, 30,000km).
My wife and I were driving back home at about 830pm when my Figo's transmission went lifeless. I tried moving from third to fourth but the gear lever just kept 'floating' longitudinally in the box. There was no lateral movement at all.
Luckily for us, we were on a quiet street with not much traffic and next to a police station. We parked the car on the side and cabbed it home. I searched online for any similar cases and I found a post on team-bhp by @deepblue about the same issue he had had.
But what puzzled me was that most of these failures were reported between the 70 to 80k range and mine had only done 30k. But at least I knew what the problem was.
The next morning, I got back to the car, removed the plastic cover and found the bush had literally disintegrated and was almost powder inside! This caused the gear cable to pop out of the lever.
Review: 1st-gen Ford Figo (2010)-img_20161018_102929011.jpg
Review: 1st-gen Ford Figo (2010)-img_20161018_103017757.jpg
Review: 1st-gen Ford Figo (2010)-img_20161018_103041264.jpg
But what I had also noticed was that there was a hole at the top of this plastic cover, caused by battery acid leaking onto it. I assumed that the bush got eaten so early in car's running because of the acid too.
Review: 1st-gen Ford Figo (2010)-img_20161018_171124938.jpg
This bush, which is about half a thumb size costs 515rps. When I asked the Ford parts shop why it was so expensive, he said that it originally costed 1100 but because many customers complained about it, they reduced the price! Great job Ford at ripping customers off. I guess they didn't find the need to issue a recall.
Review: 1st-gen Ford Figo (2010)-img20161018wa0001.jpg
I drove the car to the service centre about 5km away in 2nd gear, having stuck the cable to the lever with surgical tape. The service centre fixed it for free and took less than a minute.
I would highly recommend all figo/fiesta classic owners to have this bush checked during their routine services. It's so much of an inconvenience and even dangerous if this bush just pops out during highway or ghat driving.
Take care and drive safe!
qr20de is offline   (5) Thanks Reply With Quote
Old 21st October 2016, 12:15   #10427
tharian's Avatar
Thanked: 2,881 Times
Thanks for posting the pictures. I will check the bush on my car since it is over 6 years old and from the posts on this thread , I assumed the issue was affecting only diesel Figo's.
tharian is offline   Reply With Quote
Old 21st October 2016, 14:50   #10428
KiloAlpha's Avatar
Thanked: 1,499 Times
No, both petrol and diesel Figo's are affected. It is a rubber part prone to failure, so I guess it is a good idea to just proactively replace it if your car is over 5 years old?
KiloAlpha is offline   Reply With Quote
Old 21st October 2016, 15:19   #10429
Thanked: 255 Times
Yeah def. I also forgot to mention that, I noticed a 2 or 3 inch longitudinal play in the shifter in every gear. I knew that that wasn't normal considering the Ford gearbox is quite tight and crisp.
I guess this was a sign of the bush failing.
qr20de is offline   Reply With Quote
Old 21st October 2016, 17:51   #10430
tharian's Avatar
Yes, that was the sign. I check occasionally for play in gear, on the lever. It is fine as of now.
But I guess I will buy and keep the bush just in case.
Old 22nd October 2016, 21:55   #10431
r_devakumar's Avatar
Thanked: 99 Times
For the last one moth, the cooling fan was running with high speed / noise. Last week the fan stopped working. I have taken to the nearby garage and replaced the blown fuse.
Now the cooling fan high speed and noise problem continues. Also, if the a/c is not switched on, the cooling fan never works. It results increase in engine temperature when the engine is running idle. What could be the problem? I am planning to take to ford service next month and check.
r_devakumar is offline   Reply With Quote
Old 24th October 2016, 18:16   #10432
Thanked: 99 Times
Default Re: Ford Figo : Official Review
Originally Posted by petrolhead_chn View Post
MPL is going to be taken over by TVS after which after the service standards are expected to heighten up, at least till the internal transition excitement lasts
Any update on how MPL is doing now? Is the Pallikaranai and OMR service centers are with them or taken over by some one? How good is the service level now? I want to take my Figo this week for the cooling fan issue. Want to check if they are doing better now or should I take it to any other local garage.
Old 24th October 2016, 18:18   #10433
Thanked: 42 Times
Hi where did you get the V-belt from? In my 40k done ford I am also getting a recommendation to replace the belt and pulleys for 12k. I would rather replace the belt for 1k and get some peace of mind. Is there a standard size or brand of belt to go for?
Originally Posted by Ragavsr View Post
Changing the entire pulley assembly...11 years old when we sold it.
Last edited by FlyingSpur : 27th October 2016 at 06:06. Reason: Please avoid quoting entire large posts. It inconveniences our small screen and mobile users.
joshiviv is offline   Reply With Quote
Old 25th October 2016, 09:35   #10434
Thanked: 111 Times
Can you please share more details (steps with photos if possible) on how to access & remove this plastic cover to check the bush status?
I have come across multiple posts on this topic, but assumed that we need to get underneath the car to access it (which apparently is not the case). I have not opened the bonnet of my Figo for last one+ year now and its time to inspect once myself (for my satisfaction).
null is offline   Reply With Quote
Old 25th October 2016, 10:24   #10435
batterylow's Avatar
Thanked: 694 Times
Another view of the same part taken when I got the selector seal replaced.
Review: 1st-gen Ford Figo (2010)-img_20160926_091321.jpg
batterylow is offline   Reply With Quote
Old 25th October 2016, 10:50   #10436
Thanked: 255 Times
@batterylow: seems like the bush on yours is quite different to the one I have. Did you get a special fitting? Also, I observed the oil in the plastic case. Are you leaking transmission fluid by any chance?
Old 25th October 2016, 11:05   #10437
Thanked: 255 Times
I'll be glad to help, although I don't have pictures of the fitting process, but it should be fairly straightforward. But before get under the car, I would recommend you evaluate the play in the longitudinal movement of your shifter in each gear. If the shifter moves about 2-3 inches in every gear, the bush might be wearing out.
1. I recommend that you jack up the left side of the vehicle behind the front wheel. It just makes things much easier to work with but its not necessarily required (will be quite a squeeze under the car)
2. Just in-front of the left front wheel to the right you will see a black plastic box. It's an extension of the transmission housing. Just to get an idea of the location, please do have a look at the fourth picture in my initial post. You can see it right below the battery and protruding from the aluminium transmission housing.
3. Its very simple to remove the cover on this plastic box, because it's only grooves with embedded clips. There are approximately 2 on each side. You will have to reach around the box to access the clips on the right side and also over to reach them at the top.
4. Once you have detached the cover from the plastic housing, it will be a little tricky to remove it completely because of the cables coming into the box from the shifter. Just wiggle it out considering it's a little flexible.
5. Once you are directly under the plastic box, you will send the cables and shifter mechanism similar to the pictures I posted. @batterylow's pic is the front view whereas mine are the bottom view
6. You can easily access/check the bush from here.
Hope this helps.
qr20de is offline   (1) Thanks Reply With Quote
Old 25th October 2016, 13:05   #10438
batterylow's Avatar
Thanked: 694 Times
I don't know about the special fitting but I was leaking oil and that was what lead me to visit the service center and notice the damaged seal. After the change of seal there is no subsequent leakage.
Old 25th October 2016, 14:18   #10439
Thanked: 99 Times
I am having cooling fan issue with my Figo. When I called MPL Pallikaranai, they said they are not taking vehicle for servicing. They gave me number for Eureka Ford in Perungudi (taken over from MPL perungudi). Anyone done their servicing from Eureka Ford please share your experience.
Also, please suggest any local garage around Tambaram/OMR which is doing good work on servicing Figo. Since my Figo is out of warranty now, I am open to do the servicing outside Ford authorized service stations.
Devakumar
Old 26th October 2016, 18:39   #10440
Thanked: 134 Times
Cool Re: Review: 1st-gen Ford Figo (2010)
I had a gear shifter problem recently on my Figo while on a trip out of station and to my luck, some jugaad solved the problem. Came back to Bangalore and started looking for solutions as the very simple part to replace is Rs 3,600 + labour according to Ford service.
While searching on the net found this which might be helpful to quite of few of us who have suffered from a stranded vehicle due to the gear bush problem.
Musa is offline   (4) Thanks Reply With Quote
1st-gen Hyundai i20 (2008 - 2014) : Review GTO Test-Drives & Initial Ownership Reports 884 28th December 2017 11:57
6 month old Ford Figo DCT: Battery dead 7 times! An ordeal with Bhagat Ford & Ford India Night Raven Technical Stuff 27 20th September 2016 16:25
The next-gen 2015 Ford Figo. EDIT: Now launched RavenAvi The Indian Car Scene 719 9th November 2015 03:04
Supposed spyshots of next gen Ford Figo surface JayPrashanth The Indian Car Scene 73 13th February 2015 14:43
My 1st diesel: Diamond white Ford Figo ZXI. Interior Pics on Pg 3 sameerg001 Test-Drives & Initial Ownership Reports 78 9th June 2014 02:37
