Old 22nd April 2010, 10:08   #46
shubhodeepdas@g's Avatar
Thanked: 250 Times
Originally Posted by sanjayc View Post
Mustang, why this bottom scraping issue is there in Figo? Is'nt Figo's GC 170mm compared to Fiesta 165mm..AFAIK, have'nt seen any complaints regarding this from couple of Fiesta owners in Bangalore like Shajufx & Unni. Is it something to do with suspension?
Bottom Scraping happens even on a Fusion with 198mm GC, Figo is 168mm and Fiesta 165mm. It completely depends how and when you brake when crossing a speed-breaker and it's size.
If one brakes after the front wheels have crossed over, chances are that the suspension will dip and the GC will come down resulting in scraping.
The other reason is the gigantic wheelbase of the Figo, longer than the Fusion and I think Fiesta as well. 2489mm over 2486mm, though marginal but one is a hatch and the other one a sedan. Compared to Swift at 2390mm it's way longer, which would give a great drive but also increases the Un-Spring distance between the wheels. As a result, when taken over similar ramps and humps, the Swift and others would fair better.
shubhodeepdas@g is offline   Reply With Quote
Old 22nd April 2010, 10:17   #47
Yamaha100's Avatar
Figo having a longer wheel base than the swift will cause more bottom scraping issue, but this will have a significant impact on the buyer's decision. So i hope that Ford will look into this issue and solve this problem. Just want to know how is VW Polo performing on the ground clearance front on bangalore roads. I think VW head was talking about this issue being handled just for the indian version of the polo in a TV show.
Yamaha100 is offline   Reply With Quote
Old 22nd April 2010, 10:34   #48
Thanked: 250 Times
Having driven the Polo for multiple test drives back to back with Figo, I felt that the German has much harder suspensions giving it a little harsher ride quality as compared to Figo. Polo wheelbase at 2456mm is also marginally shorter.
Old 22nd April 2010, 10:39   #49
Yamaha100's Avatar
This means that Polo should be better when it comes to ground clearance. Assuming all the cars are driven by the same driver under similar conditions and people on board with the soft/hard suspensions factored in we need to know the 'ground clearance'. I think thats how we can do some real comparison between different cars. I wonder if some one has done this analysis if so sharing that information would be helpful. Especially i am interested this information about figo,polo,swift,i20
Old 22nd April 2010, 10:45   #50
Thanked: 112 Times
Shouldn't this rod coming from the steering, I think, be properly covered ?.
I always keep hitting it while pressing the clutch. Is it one of those cost cutting measures ?
silverknight is offline   Reply With Quote
Old 22nd April 2010, 10:47   #51
sarmarishi's Avatar
Thanked: 80 Times
My my.. Its definitely raining Figos!
Congrats. Enjoy your new ride.
And yes, that should be definitely covered with a rubber bush kind of a thing (which fits all around the hole). Please check if the other Figos also do not have it. Plus the rubber should be acting as a plug so that water doesnot come in when driven through water and more importantly keep rats and roachs out!
sarmarishi is offline   Reply With Quote
Old 22nd April 2010, 11:08   #52
gemithomas's Avatar
Thanked: 138 Times
I think it is like that on all cars. At least it was the same on my earlier Fiat.
Old 22nd April 2010, 11:52   #53
Thanked: 7 Times
In my Fiesta too it is not covered!
sanjayc is offline   Reply With Quote
Old 22nd April 2010, 12:18   #54
mikon's Avatar
Thanked: 375 Times
Excellent Choice bro!
I too made that choice. Congrats.
Here are some of my car's pictures
Added:
1 - Garware sunfilm
2 - Helix Dark Blue Bass Tube
3 - Sony 2 way amp.
Sorry, Seeing your car, couldn't resist to post mine
mikon is offline   Reply With Quote
Old 22nd April 2010, 12:55   #55
Thanked: 112 Times
Thanks all.
@Mikon: Nice pics. You have high security number plate. How much did it cost you ?
@Gemi, @sanjayc: Does it bother you when the clutch is pressed ? Or you just got used to it.
Old 22nd April 2010, 13:11   #56
mikon's Avatar
Thanked: 375 Times
Its 1200 INR.
I know its too high. But I wanted it anyhow
Old 22nd April 2010, 14:12   #57
gemithomas's Avatar
Thanked: 138 Times
@mikon: Excellent Pics mikon. How did you connect the bass tube? Does the stereo have a provision?
@silverknight: I just got used to it.
Old 22nd April 2010, 14:36   #58
Thanked: 7 Times
I just noticed it a few days back only while cleaning the sports pedal...it never bothered me. I am used to keeping my foot more on the clutch tip than on the bar. Maybe you can push the seat slightly backwards and check. Cover or not, if you are hitting the steering column, you may need to adjust you driving position.
Old 22nd April 2010, 14:39   #59
Gilead's Avatar
Thanked: 21 Times
For everyone complaining about scraping, complete all the braking before the front bumper crosses the speed breaker. Do not brake while in the middle. This should help to some extent.
Gilead is offline   Reply With Quote
Old 22nd April 2010, 14:54   #60
mikon's Avatar
Thanked: 375 Times
Thank you sir.
No, I don't think the stereo had a provision, thats why the technician used an extra connector behind the stereo for the woofer.
Sorry, I donot know much about the wiring kits
I am using a cable for the ipod.. but the music ourput is not as good as compared to the output by a CD
Another weekend, yet another Hill Station - Yelagiri Mr.Boss Travelogues 7 2nd August 2014 23:02
(Yet another) Swift VDI(2009) ownership report debugged Long-Term Ownership Reviews 12 16th December 2009 17:45
Yet Another RX135 Thread ! NoMan47 Motorbikes 31 15th March 2009 18:16
Yet another i10 ICE thread d.kiran In-Car Entertainment 36 24th January 2009 23:18
Yet another MJD vs VDi vs ZXi thread phamilyman Test-Drives & Initial Ownership Reports 59 21st August 2008 17:14
