Old 3rd June 2010, 18:36   #61
aman9393's Avatar
Thanked: 27 Times
Congrats on your Civic.
Originally Posted by smartcat View Post
If I am "Tom", the rats are like "Jerry" - those darned critters are way smarter than me.
All I know is that the previous owner is a businessman - that logo on the number probably is his company's logo.
Will do. What is HSRP? Google says HSRP stands for Hot Standby Router Protocol - a Cisco proprietory redudancy protocol.
HSRP stands for High Security Number Plates.
There is a thread here on that topic. You can get more info there.
Here is a pic of theMAG's Swift with HSRP
aman9393 is offline   Reply With Quote
Old 3rd June 2010, 19:00   #62
ranjith.rajaram's Avatar
Thanked: 9 Times
Attachment 360818
Those number plates looks too cool . Can you tell me how much does these cost ? I heard its around 1500 rs ?
ranjith.rajaram is offline   Reply With Quote
Old 4th June 2010, 03:26   #63
khoj's Avatar
Thanked: 1,258 Times
I think the following signature suits me the best -
"How am I driving? Call 100"
Almost immediately after I took the delivery of the car, I drove to my favorite tyre shop and replaced all 4 tyres (the stock tyres had lost 3/4th of its tread) with 205/65 R15 Yokohama A-drives. Good enough, or should I have gone for 215 or a diffrent brand?
Hi smartcat,
Congratulations on the Civic.
"Call 100", do I sense a change in your driving habits, no more steady 80~90 kmph!!
As for the tires please go back to your dealer and change the A drives for something better like the AVS dB 550 also from Yoko. With your kind of driving(sustained long drives even at 80 kmph) that is the tire to go for, I use the same on my Cedia. As for the size stick to stock size. That generally works out to be the best decision unless you are up sizing the wheel diameter too.
BTW can you be a little more elaborate regarding the model/make and source of that air comp. you have. I would like to contact the shop and maybe order one to be shipped out.
@ranjith,
You can get these made in Pune itself thru a tbpian Satyajeet @ 9921845845.
He got a set made for me and had it sent to Delhi.
Old 4th June 2010, 11:14   #64
vasoo's Avatar
Thanked: 207 Times
I got HSRP done from the dealer itself for my car. He charged me 1500 for that.
vasoo is offline   Reply With Quote
Old 4th June 2010, 11:26   #65
smartcat's Avatar
Thanked: 14,867 Times
HSRP's not made by Cisco are quite cool! I definitely need that in my car.
I'm still a 90 kmph cruiser. Although I might get to that speed from zero rather rapidly in my "new-old" Civic
Can I see those Yokos on your Cedia? My requirements are -
- Minimum life of 40,000 kms
- Low tyre noise
- Excellent ride quality
I'm not quite sure what contributes to tyre noise - the tread pattern? The A-drives have deep grooves, fat rubber and a rather simple tread pattern. Although, every user might not pick up or hear the slightly intrusive tyre noise on the A-drive, I can make out the difference because I was using Michelins before. You can make out the difference only when the stereo is switched off - so the tyre noise is not all that bad on the A-drives.
The size I picked for the Civic is almost stock - it is just a wee bit wider than stock tyres.
I don't think any brand name is written on the air pump, but let me check.
smartcat is online now   Reply With Quote
Old 4th June 2010, 13:11   #66
shuvc's Avatar
Thanked: 287 Times
- Low tyre noise
You can see those same tyres on my Civic. I believe they would fulfill all the above mentioned criteria, in addition to being quite grippy.
http://www.team-bhp.com/forum/test-d...hite-vm-t.html (ShuvCivic - Tafeta White VM/T)
Old 4th June 2010, 14:42   #67
khoj's Avatar
- Low tyre noise
I am yet to snap any pics of my car, I will do so shortly. It is however a very comfortable and quiet tire to have. On a recent trip to Haridwar with 4 adults on board we encountered all sorts of driving surfaces and the tires kept the ride very supple and planted. As for the life, well I will have to revert back in sometime. I am attaching a brochure for you to make up for the snaps. The A drive is also a quiet tire but the AVS is more suitable to sustained long runs, unless the A drive in the size that you have is also V rated in which case it is par for the course.
EDIT link to the tire specific post from shuvc's thread.
http://www.team-bhp.com/forum/test-d...ml#post1907274 (ShuvCivic - Tafeta White VM/T)
File Type: pdf Yokohama_dB_decibel_A500_V550.5579.pdf (730.2 KB, 272 views)
Old 4th June 2010, 15:12   #68
smartcat's Avatar
Hmm. OK. Next time, I'll ask here before I jump the gun and go run to the tyre shop.
Meanwhile, I've just started having a minor issue with the Civic. Whenever I depress the clutch, I hear a creaking sound. I first heard this sound 2 days back, but sound was not there yesterday. But now again, I hear a creaking sound when the clutch is depressed. Does this warrant a visit to the dealer?
The car has already been serviced by the previous owner at 35,000 km, and I even have the bill with me.
Old 4th June 2010, 15:29   #69
Thanked: 138 Times
Congrats on a great acquisition!!
Regarding the issue, I am no expert but just hazarding a guess coz my VTEC is also having the same issue. I think it's the clutch cable which has lost lubrication. I am still running the original though (2003), which apart from the creaking sound, is absolutely fine.
avinash_m is offline   Reply With Quote
Old 5th June 2010, 11:51   #70
prguru's Avatar
Thanked: 19 Times
Congrats on the buy Smartcat, great choice and neat car.
A dog bite? I think the previous owner had a big bad Doberman in the passenger seat.
I thought dogs liked leather more than plastic, if that is right you should consider yourself lucky
That is the logo of Classic Automobiles, you can find that logo on every car sold by CA. Drive Safe
OT : I stay very near to your house and just passed by your house and instantly knew it was your car.
prguru is offline   Reply With Quote
Old 6th June 2010, 00:51   #71
smartcat's Avatar
I just became a "Platinum Member" of the VTEC club - I hit 7000 RPM (in the 2nd gear) today on an empty stretch of road near my house!!
Your clutch is making a creaking sound and you are running it like that without problems since 2003?
Maybe its a Honda feature, not a bug!
Anyway, I can't stand "sounds" inside my car - so I'm off to a Honda dealership this Tuesday. I might as well get everything checked up - I will feel a lot better when I take the car on highways.
Now that I know what that logo is, I have to get it rid of the number plate right away.
What?!? Man, you should have just opened the gate, walked in, rang the bell and flashed your team-bhp username
anantu2001 is also somewhere in Nagarbavi - time to have a Nagarbavi team-bhp meet at the BDA complex?
Old 6th June 2010, 00:59   #72
Thanked: 152 Times
Transmission tunnel does not intrude into rear middle passenger space
Transmission Tunnel?? There is no Transmission Tunnel. The Car is a FWD!! I seriously hope you were kidding!!
Cyrus43 is offline   Reply With Quote
Old 6th June 2010, 01:14   #73
shuvc's Avatar
Thanked: 287 Times
Eh ! Am yet to try this, but I thought 7K would be a nono since it's into the 'red' zone. There's no revv limiter?
Old 6th June 2010, 01:39   #74
smartcat's Avatar
What's that bump in a FWD car in the middle of the backseat called?
Civic redlines at 6800 RPM, but in the few micro seconds I had to take a look at the rev counter, I thought I saw the needle swing to 7000 RPM mark. Is the redline the cut off point (rev limiter) or does it swing past the red line too?
The speed was 93 kmph on a slight incline in the 2nd gear, before I shifted to the third gear.
Old 6th June 2010, 02:45   #75
khoj's Avatar
It's called The Bump!
You have a Honda Vtec under the hood, this engine is built to be revved otherwise it will protest and then strike under the "work per rules" agenda. Don't be bothered with rev limiters, I never did with my OHC's "hyper engine" and enjoyed it for 10 years. The guy who bought it 2 years back was made to promise that he will touch the other end of the tacho at least once a month. The insect went and installed a CNG kit. Sorry that is on a different tangent.
On a serious note I don't think the rev limiter even if it is there is going to bounce you off on the dot. In my OHC it would go to whatever the limit was and just not rev any further. Also your car's engine has been run in while shuvc is still running in his new engine. Just rev hard and enjoy the engine while we are still able to afford the fuel.
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 4 31st October 2010 18:07
Pre-owned Optra / Pre-owned Accent CRDi / New Tata Indigo ashthedivx Sedans 15 24th February 2007 14:03
pre-owned Baleno vs pre-owned Accent vs ikon flair rohantn Sedans 36 16th February 2007 20:27
pre-owned Wagon R or pre-owned Bolero - pls advice rohantn Hatchbacks 26 7th February 2007 17:02
Pre-owned Ford mondeo vs Pre-owned Skoda octavia azifali Sedans 6 24th July 2006 13:46
