Old 3rd November 2014, 16:04   #16
DRIVE_ADDICT's Avatar
Thanked: 181 Times
Default Re: Swift VDI ABS - Photos and Initial Ownership
Originally Posted by malq View Post
We have two Maruti Swift diesel VDi ABS cars.
I have tried everything - changing tyres from JK to MRF , changing front bearing, changing air pressure, changing number of passengers from 1 to 2 to 3 to 4, but no joy. The resonance is so loud when rolling at 75-90 kmph in any gear (4th or 5th or neutral coasting) that we feel like we are inside a woofer.
Before I head to Maruti with this, anybody here got any ideas on what this is about? This is not an engine sound, that's for sure, because I've coasted to 120kmph and let the speed drop.
Sounds very much related to bearing. You mentioned you have changed front. check the rear too.
DRIVE_ADDICT is offline   Reply With Quote
Old 3rd November 2014, 17:11   #17
Harsha89's Avatar
Hello Sir, I too own a Swift VDI 2009 model which has run 1,15000 km as of now..I experienced similar issues at 92k and 110K km respectively..When checked, I was informed of worn wheel Bearings on the front RT and the Rear LT wheels..I would suggest you to check the rear bearings as they are prone for wear around your Odo KM mark. Mine wore out late because I use it more on traffic free roads and highways.
Harsha89 is offline   Reply With Quote
Long Term Ownership Report: Swift VdI- 2 lakh kms, Cost of ownership on Pg 3 epicenter.rulez Long-Term Ownership Reviews 150 30th May 2017 20:35
Desire Again! Maruti Swift Dzire VDi Initial Ownership Review Turbokick Test-Drives & Initial Ownership Reports 25 25th April 2013 10:46
Ritz VDi - Initial Ownership Report - 2 months SLK Test-Drives & Initial Ownership Reports 45 7th October 2011 10:30
