Old 7th November 2011, 13:21   #121
Thanked: 131 Times
Default re: My Japanese Doll : Habanero Red Honda City S-MT
Just wanted to share the inputs regarding the 1st and 2nd gear shifts in the ANHC based on various posts earlier.
Had been for third free service and reminded the service advisor that I've been reporting the issue 3rd time that some times the 2nd gear offers some resistance to engage, especially when speeds hovering around 20kmph. If you release and clutch again then it engages smoothly, by this time the speed has reduced to 10-15kmph.
Even for 1st gear if the car is in stand still or just moving only then it engages otherwise there is resistance and you need to engage in 2nd only.
The Service advisor told me that this is with all ANHC and not particular to my car. He said that if the engine revs do not match then it does not switch.
However, when i asked him why same does not happen for other gears e.g 80kph@3rd gear he had no answer.
Request all AHNC owners to share their inputs on this observation.
P.S: When we turn right from a junction in first, as we complete the turn if you try to shift to 2nd it resists. However, on completing the turn shifting to 2 is easy. Issue here is I do not want to revv much in 1st before shifting.
Cheers.
mkpiyengar is offline   Reply With Quote
Old 7th November 2011, 15:26   #122
libranof1987's Avatar
Thanked: 2,188 Times
Difficulty in engaging the 2nd? That's very rare.
I have never faced any resistance while slotting the 2nd; I have downshifted to 2nd even while ~40 km/hr. About 1st, my City is moody. At times, 1st comes on easy (while downshifting) while at times, it waits for the speeds to be very low to engage.
libranof1987 is offline   Reply With Quote
Old 7th November 2011, 18:40   #123
Thanked: 131 Times
When i mean difficulty it is resistance to shifting, but as you rightly said if the speed reduces then it slots very smoothly. For 2nd around 10kmph and for 1st almost stop condition.
Old 8th January 2012, 20:11   #124
The car went in for scheduled servicing today.
15000 kms service update :
- Engine oil was changed (mineral): Rs. 1015
- Some washer was changed worth Rs. 82
- My disappointment with my City's horn is very well-documented. This time, I'd asked my father to lodge a complaint (the 3rd time now). The problem was acknowledged and the low-tone horn was changed under PUD Warranty.
- Go thru' my post here : http://www.team-bhp.com/forum/street...ml#post2569504 (To have a stone suddenly come in your path...). Luckily, the only damage that came out of it was a broken clip and a few scratches. The clip was replaced.
- Go thru' : http://www.team-bhp.com/forum/techni...ml#post2637969 (Varying a/c blower throw in Honda City (current gen)). The problem has been resolved.
(All you NCR fellas, please do get the a/c vents and a/c filter checked and cleaned regularly.)
- Labour : 750
- Total cost : Rs. 1847/-
Old 8th January 2012, 21:33   #125
bluevolt's Avatar
Thanked: 2,031 Times
- Labour : 750
I guess this should be the paid service. Cost seems quite reasonable for a Honda (at least when compared with VW costs). My car has also done nearly 8300 KMs and will be due for service as soon as it reach 10,000 KM mark which should happen in next two months.
I am facing the same horn issue as yours. The low pitch unit is not sounding properly and when I called them they said that a little adjustment is required. I will make sure that they replace it under warranty as the car is just over an year old, will take warranty and service booklet with me during next service (i guess only warranty booklet is required for claiming warranty and not any other document like bill etc?).
Other than this I am also facing issue of noise from driver side power window switch set when music is played over 20 due to bass.
Have you also noticed some sort of shuddering on steering wheel while switching off the engine? Is this normal? Doesn't happen in my other two cars - i10 & WagonR.
I wonder if Honda SVC will stock the Habanero red color for touch up purposes as the color is now discontinued :(. I will procure couple of cans of touch up paint.
All City owners are also requested to switch on their AC at least every 15 days to prevent any corrosion/problems etc.
bluevolt is offline   Reply With Quote
Old 9th January 2012, 00:05   #126
I complained thrice earlier and all they did was adjustment. Funnily, they replaced it this time.
But I doubt they actually did change it because -
1) they didn't take my father's signature anywhere
2) they did not ask for/check the warranty booklet
Could just be a loose speaker.
Not really. It's smooth otherwise.
Pearl Honda didn't have it in stock even earlier; wonder what happens now!
That's recommended for all cars.
Old 9th January 2012, 00:14   #127
charthom's Avatar
Thanked: 261 Times
Hey,Libran,
Nice to note your servicing was well done-esp the horn issue sorted out.
And the expenses were very reasonable too.
Good decision to stick to mineral oil.
Bluevolt- the shuddering could be slack engine foundation bolts. My i10 had it last year-sorted out.
charthom is offline   Reply With Quote
Old 19th January 2012, 16:27   #128
It surprised me that the Oil filter was not changed when the engine oil was replaced in the 15k kms. I checked the manual, it listed the replacement schedule for Oil filter as every 10k kms. Now, I couldn't find the service bill for the 10k kms service and was worried if it was changed at all.
I just had a word with Pearl Honda regarding it and thankfully, it has been.
A summary of the last 3 services :
15k kms : Oil change
10k kms : Oil change
Oil filter
5k kms : Oil change
All this along with the Paid service (which involved check up and wash).
Old 19th January 2012, 16:29   #129
bluevolt's Avatar
Can you share the labour cost of Honda A.S.S excluding the parts and consumables?
Old 27th February 2012, 09:50   #130
Found this rather fancy bumper protector strip on a City. Wonder if it helps in any way to fulfil the main purpose. Looks good though.
The one on the front is the regular type - horizontal.
My Japanese Doll : Habanero Red Honda City S-MT-wp_000106.jpg
Old 27th February 2012, 10:21   #131
Thanked: 344 Times
- Labour : 750
Every service of my City costs me about Rs.4,000 to 5,000. At 15K service interval Hallmark Honda said the A/c filter needs to be changed as per Honda service policy and the same will cost about Rs.8,000.
At 20,000 kms I sent the car to Apex Honda and they gave me the same talk about A/C filter. From what I remember the bill came to about Rs.4,500.
Except for the 20K service, all services have been done at Hallmark Honda. The first two services they conveniently put synthetic oil despite being told before the second service that we wanted mineral oil.
I would also like to add that the car is registered in corporate name and is never taken by me to the ASC. Is that the reason for these service costs?
amit is offline   Reply With Quote
Old 27th February 2012, 10:29   #132
If they have put synthetic oil, then ~4k is a realistic figure. But then, there is another problem : synthetic oil has a replacement schedule of 1 year. So, the A.S.S. is wrong in changing the oil in both the 2nd AND 3rd free service.
How much was the bill when mineral oil was filled?
The A/c filter has a replacement schedule of 20k kms so that is a legitimate expense.
The A.S.S. is indeed inflating your bill; you need to take the car to the A.S.S. yourself henceforth. Also, it would be a good idea to refer to the service/replacement schedule of consumables in the City manual. That would give you an idea of how and when the A.S.S. took advantage.
If you have the bills for all the services so far, why don't you post them here; would help us identify the points you should be careful about.
Old 27th February 2012, 10:38   #133
Thanked: 344 Times
That was exactly my argument after the first service when they put synthetic oil but all that the dealer told my colleague was that the synthetic oil is as per Honda recommendation and for services we have to stick to the schedule given!
Synthetic oil service was roughly 5.5K while the 15K & 20K service with mineral oil cost me about 4 to 4.5K from what I remember.
I don't mind the replacement of the A/c filter if it's as per manufacturer recommendation but I want to be sure of the cost as it seems the dealers are over inflating thing's with my car & I am guessing this is because it's a corporate registered car. That was precisely the reason the car was sent to Apex Honda but they quoted the same 8K figure for the filter.
Old 27th February 2012, 10:43   #134
That's the dealer's insistence rather than Honda's recommendation.
For all my services so far, my service bill hasn't been more than ~1900.
Of course, at 20k, the air filter and a/c filter will be changed so that bill will be more.
Clearly, you have been charged for unnecessary things. Do post the service bills.
My A.S.S. once changed the engine oil within 3 months; I followed it up with Honda and the A.S.S. was asked to refund me the money for the oil. So, if we find out that the A.S.S. carried out tasks more than necessary, you could pursue it with Honda.
Old 27th February 2012, 12:27   #135
Thanked: 344 Times
A/C filter has not been changed in my car yet. The 20K service cost is without the cost of A/C filter.
Dealer's have been insisting on replacement of A/C filter from the 15K service. However, your 15K service break up does not mention about he A/c Filter.
Do you know how much the filter costs? Is is really Rs.8,000?
Will try and have my accounts guy's dig out the last invoice.
