Old 2nd December 2010, 08:44   #16
blackasta's Avatar
Thanked: 1,225 Times
Congrats on the new i10!
Enjoy your drive - and please calculate FE after you have driven around 2000 kms. Before that, keep varying the speed and rpm to run-in the engine.
I guess you should be able to adjust the brake pedal soon.
Drive safe!
blackasta is online now   Reply With Quote
Old 2nd December 2010, 09:07   #17
gshanky's Avatar
Thanked: 13 Times
Congratulations on the Car.
Originally Posted by agbenny View Post
Any one knows exactly when to use L2, 2 and OD. It was not a surprise when the sales people were not sure about them.
In my car OD (overdrive) is always on. In my first car whenever I release the button, I used to see "Overdrive OFF" warning light. I have a basic understanding that OD helps improve fuel economy by reducing the RPM.
You can find better explanation here - http://en.wikipedia.org/wiki/Overdrive_(mechanics)
gshanky is offline   Reply With Quote
Old 2nd December 2010, 11:44   #18
Thanked: 120 Times
Infractions: 0/1 (5)
Originally Posted by thedreamcatcher View Post
Congrats. I really like the look of the new i10, as compared to the other version
I am assuming the auto runs on four gears right?
Yes, you are right. Its not very much visible too in the gear rod.
Originally Posted by prince_pervez View Post
Congrats on the new purchase. Drive safe!
Thanks prince. Its for my wife, actually, she is still learning.
Drive safe!
You are right, calculating FE within few hundred KMs will not show the correct figure. But people were discussion hot about the i10 AT's FE (a separate thread is going on), so I was keen to see what my car actually gives from the day one. LOL!
I never even tried to switch on that button. Need to try it. Will OD affect FE?
agbenny is offline   Reply With Quote
Old 2nd December 2010, 14:00   #19
khoj's Avatar
Thanked: 1,258 Times
On the gear selector 2 and L refer to the first two and the first gear respectively. These can be used when you are going uphill with a full or almost full load and the car is straining to climb in the higher gears. The two positions will help by holding the engine in the first two or the first gear and thereby reduce the strain on the same. This is especially use full in stop and go traffic when going up a ghat section etc. L would be used in extreme situation where it is a straight incline and the car is not able to pull even in 2nd gear.
The OD button will restrict the car's gearbox by not allowing it to engage the overdrive gear which is the fourth gear in i10 Auto. This feature should be used when going down hill. By holding the car in maximum 3rd gear the system is making use of engine braking, thereby allowing a safer descent and also preserving the brakes from burn out/ fade out by reducing the load on the braking system if that alone were used to control the run away speed. To engage you have to press the OD button. To disengage press the button again. The system also cuts off automatically if the ignition is switched off. There is an indication on your driver console which will show when the system is switched on or off.
Old 2nd December 2010, 15:30   #20
tanwaramit's Avatar
Thanked: 387 Times
congrats on the car, AT is a must for todays traffic conditions.
For brake pedal, how about something like this ? Japanese Inventor Combines The Accelerator And Brake Pedal Into One
On Serious note, get the pedal changed to one which is a little longer. It will help, as the knee wont need to lift that much high OR use a pillow to sit.
tanwaramit is offline   Reply With Quote
The Cute Little Blue-bee: Hyundai Eon Sportz! gm_arun Test-Drives & Initial Ownership Reports 20 5th January 2018 14:16
Cute little beauty comes home..., Yes its the pre-owned i10 1.2 kappa rki2007 Test-Drives & Initial Ownership Reports 11 4th January 2011 11:54
My Cute little white Eye ten AT (Hyundai i10 AT Sportz) muke31 Test-Drives & Initial Ownership Reports 46 20th February 2010 18:46
Cute little new VW Beetle and Red Yamaha R1(pics) heavy_foot Super-Cars & Imports in India 17 28th May 2009 13:42
