Old 28th July 2011, 01:51   #76
whitelion's Avatar
Thanked: 15 Times
Default Re: My City warrior! Figo TDCI with a custom heads-up-display
Originally Posted by Digital Vampire View Post
More Elegant and permanent solution: I've hacked my OBD scanner (USB) to work from the 12V ACC line instead of the direct 12v line (always ON) available on the OBD port. This way the OBD scanner is ON only when the key is turned to ACC/ON position.
Can You post the hack you did ? If possible pictures too.
whitelion is offline   Reply With Quote
Old 28th July 2011, 12:10   #77
Thanked: 84 Times
I'm sorry I don't have any pictures since this was done many years back...
Its an easy job if your OBD Scanner connects to the OBD port via an OBD cable. Even otherwise it is easy but you'll have to open up the scanner or isolate the wire at the vehicle connector (not recommended)
Look for 12V line on the OBD connector/cable. Cut the corresponding line and connect the end of the wire going to the scanner to the ACC line of the car. Its as simple as that.
Digital Vampire is offline   Reply With Quote
The Last Warrior...My Outtie - Mitsubishi Outlander rishi_kapoor Long-Term Ownership Reviews 88 1st April 2017 21:40
Hello diesel-heads & petrol-heads! v_safari Introduce yourself 5 7th March 2015 13:13
Weekend Warrior! Pre-owned Indigo CS Lx 2009 MudMover Long-Term Ownership Reviews 29 5th August 2014 23:03
My Silent Warrior Black Fiat Linea MJD! vikram999 Test-Drives & Initial Ownership Reports 26 18th May 2014 00:00
