Old 8th February 2011, 11:50   #61
mdsaab's Avatar
Thanked: 446 Times
Default Re: Honda City I-VTEC V AT (2011) - review after 400 KMs
Hey do you know my dad? He definately does like sitting in the front passenger seat. And he is tall. You got that spot on! I agree with you 100% on the altis, hope mom agrees. There will be one downside though, wont be able to start a thread discussing this issue.
Originally Posted by echo77 View Post
Mash, if it is driver driven, blindly go for the altis manual top end. It has luxury feel and better comfort at the rear than the ANHC.
Also, if your dad likes to sit in the front passenger seat, entry and exit from the ANHC can be an issue if he's tall.
mdsaab is offline   Reply With Quote
Old 10th February 2011, 13:55   #62
Thanked: 15 Times
Till the car is brought back to parking mode, the ignition key cannot be taken out of the ignition point!
rkap01 is offline   Reply With Quote
Old 10th February 2011, 13:58   #63
echo77's Avatar
Thanked: 33 Times
mash: I am the soothsayer
rkap: It ensures that you don't leave the car in N or D. Also, note that the ignition cranks only if the brakes are on in P mode. If brakes are not on, it won't crank. I guess these are safety features.
echo77 is offline   Reply With Quote
Old 10th February 2011, 14:09   #64
vasoo's Avatar
Thanked: 207 Times
I dont think we need to depress brake in P mode to start. I do it every morning and I dont think I apply brake while starting, though I am not sure! Things happen pretty automatically once you get used to the car and then you may not be able to tell the exact sequence of operations.
Yes. You cannot take out the keys in any other mode than P. Also the windows can be wound up or down for a few minutes even after switching off the engine, but before you take out the key.
vasoo is offline   Reply With Quote
Old 10th February 2011, 14:54   #65
sgiitk's Avatar
Thanked: 3,881 Times
In my Civic you have to press the brake pedal and also have the car in P or N before you can turn the key.
Old 11th February 2011, 09:41   #66
mdsaab's Avatar
Thanked: 446 Times
You definately are mate.
Well our 2008 civic does require you to be in park to crank. But one does not need to have the brakes depressed. I am absolutely certain, cause i sometimes crank the car in the morning without getting in to let the engine warm up before we start for the day. What i do is crank the engine then arrange all the bags and nick nacks in the car. By then the car is warmed up and we drive off.
[/b]
Old 15th February 2011, 15:16   #67
Thanked: 15 Times
The car has done 1200 kms. I called the dealer for the first service.
Will post some photos after the service as the car has been consistently on the roads in wet conditions and thus unable to click photos!
One observation:
Titanium colour looks lighter in sunlight!
Old 15th February 2011, 21:35   #68
vasoo's Avatar
Thanked: 207 Times
I suggest you try it once again. I checked today and found that for starting I dont have to press the brake pedal. I can straight enter the car, put the key in the slot and turn to start. Nothing need to be done as long as the gear position is in P. I have a 2010 Civic.
Old 16th February 2011, 11:29   #69
Thanked: 15 Times
[/b]
Thanks!
My observations:
  1. The ignition key cannot be taken out, till the AT lever is in P mode!
  2. Once the ignition key is taken out, the AT lever gets locked in P position. You cannot move it to N or R or any other position, till, the ignition key is inserted and turned.
  3. There is no need to put a foot on the brake to start the car.
  4. The car will only start (crank) in P position
Old 16th February 2011, 13:18   #70
mdsaab's Avatar
Thanked: 446 Times
@rkap01 i am not in pune right now and therefore not with my beloved civic.
But i can confirm points 1 & 3 as i clearly remember these.
Old 16th February 2011, 13:22   #71
vasoo's Avatar
Thanked: 207 Times
Originally Posted by rkap01 View Post
Thanks!
My observations:
I agree on 1,2 &3 above. Regarding starting, you can start the car in N position as well. I normally switch off my car in long traffic blocks or signals and start it again in N.
Old 16th February 2011, 13:32   #72
echo77's Avatar
Thanked: 33 Times
I remembered to try this stuff today. There is no need to press the brakes in P mode to crank. I can also start the car in N mode, but I was holding the brakes (was on a slope). Will have to try N without brakes.
I think it was a psychological fear of attempting to crank without holding brakes - i was not turning the key far enough
Key removal:
- Only possible in Park. After key is removed, the "clutch button" gets locked and you can't move the gearshift.
Crank:
- Park (with or without brakes) - works
- Neutral with brakes - works
- Neutral without brakes - not attempted
Old 16th February 2011, 13:38   #73
vasoo's Avatar
Thanked: 207 Times
Try using hand brakes with N mode. I do that on signals.
Old 16th February 2011, 15:04   #74
Thanked: 164 Times
For short signal, i use brakes with N mode, No need to press button when changing from N to D and vice versa.
For long signal, i put in P mode with out any brake, switch off ignition and relax, car behaves like in 1st gear and wont move. When the signal comes near, around 20 seconds, i put it into N mode with leg brake and crank when signal turns green.
Normally i don't depend on hand brake unless its for parking.
shamanth is offline   Reply With Quote
Old 16th February 2011, 15:07   #75
echo77's Avatar
Thanked: 33 Times
Was able to try again
Appendix to my earlier post
Crank:
- Neutral without brakes - works
So the car will crank in P and N regardless of brakes.
Noticed this feature:
If you are in Park mode and you put in the key and turn it to on position (before cranking), then the "clutch button" on the gear cannot be pressed unless you press the brakes.
Thanks everyone for the tips and kind guidance!
My New Honda City ZX Vtec - Report at 15000 Kms abhinav.gupta88 Long-Term Ownership Reviews 34 23rd April 2014 11:28
Honda again (PreLOVED) - 2007 City ZX vtec - 50,000 kms. Update: Car Sold. Mr.Boss Test-Drives & Initial Ownership Reports 45 4th July 2012 18:15
New Ford Figo : Odometer reads 110 kms. Trip meter says 7,400 kms!! How? vij4all Technical Stuff 21 23rd January 2011 18:14
