Old 26th May 2015, 10:29   #151
neon_daytona's Avatar
Thanked: 7 Times
Default Re: Maruti A-Star Automatic : Ownership Review
How many of you still have the A-Star AT ?
I still have my A-Star AT.
Purchased Dec 2012, Around 37000 kms covered till date.
Mostly highway driving and not much used in city during weekdays.
I get about 13kmpl in city and 18kmpl on good highway roads. Typically AC on all the time, except early mornings.
Stock tires may run for another 5K kms.
Only issue is vibrations in idle and slow speeds, increases especially when AC is on.
Love the comfort of AT, safety of ABS, Good music system, Driver Seat height adjustment and also good suspension for occasional bad roads. Nothing much to complain about.
neon_daytona is offline   (1) Thanks Reply With Quote
Old 26th May 2015, 13:55   #152
rr_zen's Avatar
Thanked: 268 Times
I bought mine in May 2013 and have clocked 8K kms till date. The car is mainly used by my wife to ferry my children back from school and daily running is an average 5-10 kms. The car has been returning FE figures in single digits thanks to the limited running everyday. Overall ownership experience has not been bad so far but for the below niggles:
1. Vibrations at low speeds (as pointed out in the earlier post)
2. The AT is not a great one and the ratios at which the gear shifts happen are not optimal.
3. The stock battery went kaput in 18 months flat. Quite a surprise, rather a shock to me.
rr_zen is offline   Reply With Quote
Old 26th May 2015, 14:16   #153
condor's Avatar
Thanked: 4,896 Times
neon_daytona : Only issue is vibrations in idle and slow speeds, increases especially when AC is on.
rr_zen : 1. Vibrations at low speeds (as pointed out in the earlier post)
Can you pls tell more about this vibration ? During two TD's, I have not noticed this.
Old 26th May 2015, 14:45   #154
Mr_Bean's Avatar
Thanked: 139 Times
I have an AT since august 2013, the vibrations are typical of the 3-pot engine, it is hardly noticeable once the car pick up speeds beyond 15-20.
Generally there is no need to use the accelerator in crawling traffic, but at times in stop and go traffic with AC on, the vibrations are felt hard on inclines (flyovers, underpass), I feel this more when the tyre pressure is low (27-28 psi) and the engine does feel the resistance from the tires and struggle to keep the vehicle moving, I give it a gentle tap on the accelerator to get moving. If the pressure is maintained at 33 psi, then it should not be a problem.
The vibrations are certainly bearable on brand new or 2/3 years old vehicle, but once the engine mount tend to wear out, things may get bad, ofcourse the car would need a lot of running to reach such a situation.
Are you looking at a pre-owned one? Good examples will be available for 3-3.5 lakhs or even further. I drive on the ORR (Koramangala - bellandhur) during peak hours, my worst mileage figures have been 10 kmpl, best being 13-13.5 kmpl, the occasional short trip on hosur & NICE road does help.
Mr_Bean is offline   (1) Thanks Reply With Quote
Old 26th May 2015, 14:50   #155
condor's Avatar
Mr_Bean : Are you looking at a pre-owned one? Good examples will be available for 3-3.5 lakhs or even further.
Thanks ! I have found a sparingly used 2011 model, and waiting to pick it up. Would be driven by wife.
Old 26th May 2015, 14:52   #156
rr_zen's Avatar
Thanked: 268 Times
+1 to it. Exactly the feedback I wanted to share as well. The challenge is more when you drive it esp in bumper to bumper city traffic.
rr_zen is offline   (2) Thanks Reply With Quote
Old 26th May 2015, 15:03   #157
Thanked: 1,415 Times
I still have mine. Due to compact dimensions, fantastic for in-city drives. Even on highways it will keep up with big boys, with bit of a struggle. I found absolutely no vibrations any time of the day. Pick up is not exciting though. Takes looong time to reach 120 on highway. Crawls up to 140 and that is it.
pgsagar is offline   Reply With Quote
Old 26th May 2015, 18:03   #158
supremeBaleno's Avatar
Thanked: 1,705 Times
We have ours too - 4.5 years and 20K odd kms.
Old 26th May 2015, 18:39   #159
condor's Avatar
Thanks, Guys !
Our planned acquisition is as a city drive, & mainly for wife. The default choice for the highways would be the Storme.
One question:
Need the volume knob of the HU. Help, please ! Where can I get one ?
Old 26th May 2015, 18:42   #160
Thanked: 14,600 Times
One question:
Congrats Condor.
Shall enquire at MASS and MGP stockist here in Hyderabad. In case they do have, shall inform you.
a4anurag is offline   (1) Thanks Reply With Quote
Old 27th May 2015, 09:33   #161
NPV
NPV's Avatar
Thanked: 5,292 Times
One question:
Congrats on the new acquisition
If the HU is a Nippon/Kenwood you can try at this place:
Hi Tech Service Point
No. 277, 5th Cross, Koramangala 6th Block, Bangalore - 560095 Land Mark: Behind Bethany High School
Phone/Mobile: 080 - 41105959, 080 - 41105050, 9845006909
NPV is offline   Reply With Quote
Old 27th May 2015, 10:59   #162
Rajeevraj's Avatar
Thanked: 8,846 Times
Congrats. A good choice as compared to a new Nano or K10 AMT. Coincidentally, I had mentioned the same in one of the threads on Nano vs Alto.
Just curious. Did you find this online and is it a car in HSR Layout?
Rajeevraj is offline   Reply With Quote
Old 27th May 2015, 15:47   #163
condor's Avatar
Thanks, NPV & Rajeev.
NPV : If the HU is a Nippon/Kenwood you can try at this place:
it's the stock unit. Let me check once I get the car.
rajeevraj : Just curious. Did you find this online and is it a car in HSR Layout?
Online, yes. But not the HSR one.
Old 29th May 2015, 15:36   #164
Thanked: 260 Times
Wink Re: Maruti A-Star Automatic : Ownership Review
Thanks, Guys !
One question:
If you have the old one with you you can fix it by pouring some glue like Feviqwik or epoxy around the central tube. I used some hot-melt glue that is quite soft even when solid, and works nicely to keep it snug on the shaft; but I've learnt not to smack the volume button now!
mvadg is offline   Reply With Quote
Old 29th May 2015, 16:05   #165
condor's Avatar
@mvadg, no .. the old one is broken beyond repair. Fevikwik was the first thing to try.
Btw, what's hot-melt glue ?
A-star Automatic: Features review, EDIT: Mileage Updated jinojohnt Test-Drives & Initial Ownership Reports 52 6th May 2018 22:39
Pictorial review of our pre-owned Maruti A-Star Automatic smartcat Test-Drives & Initial Ownership Reports 75 8th December 2016 11:17
Automatic: Used Maruti A-Star or new Honda Brio? EDIT: It's a Brio! ashwin489 Hatchbacks 54 10th September 2014 15:25
Our 2012 Spiced Up Maruti A-Star Automatic! simonkayar Test-Drives & Initial Ownership Reports 40 9th October 2013 17:38
Is A-star not a Safe star? sidindica Road Safety 55 11th July 2010 11:40
