Go Back   Team-BHP > Buckle Up > Travelogues
Old 6th March 2014, 18:16   #16
tsk1979's Avatar
Thanked: 15,640 Times
Default re: (Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway
Originally Posted by shipnil View Post
Beautiful log Tanveer!
Tell me one thing, how do you identify which one is road and which one is edge of the hill when you drive through such a thick layer of snow? And even in October you had starting problems with the elephant, so what did you do in such deep winter? Any special precautions?
If you see the pics you will see there are snow walls on the side due to snow cutter throwing snow. So the flat part in the middle is usually the road.
However near Rohtang, it can be tricky. The road till Marhi is tarred, which is good. So underneath you have solid base.
Beyond Marhi you can have deep craters in the middle of the road.
We once ended in such a crater as the ice broke. Had to rock back and forth.
A BRO gypsy almost overturned in the same crater. Thankfully. the workers came running, and literally lifted her out of the ditch
Regarding starting troubles, min temp here was only -2. Ladakh was -10.
Moreover, safari has trouble when you have low temparatures + high altitude. With just low temperatures even -8 is manageable, as we saw in Gangotri last winters.
tsk1979 is offline   (5) Thanks Reply With Quote
Old 6th March 2014, 20:46   #17
rawkeron's Avatar
Thanked: 7 Times
wonderful.Well written and pictures perfectly suit the narration, so much that, I felt i am there experiencing it !
Glad to know safari is really a capable car as I often hear people complaining about it more than appreciating its plus points.
I feel like buying a safari storme right away. Will they launch the Ladakh edition? I am wondering!
rawkeron is offline   (1) Thanks Reply With Quote
Old 7th March 2014, 08:53   #18
parsh's Avatar
Thanked: 956 Times
Fantastic.
Some curiosity.
Did you drive or atleast did you experiment driving in 4X2 mode with snow chains? Did you find it possible to drive on this stretch that way even for some distance? Could a Safari 4X2 or Duster have done this with similar situation, with or without chains?
parsh is offline   Reply With Quote
Old 7th March 2014, 10:54   #19
tsk1979's Avatar
Originally Posted by parsh View Post
Fantastic.
Some curiosity.
a 2WD with chains would do fine in straight line. But when doing U turns on the narrow road, 4WD was a must.
Later when we went to 3000m+ with solid ice, we had chains on rear and cables on front wheels, and I needed every bit of traction. Just chains on rear and no 4WD would have been very tricky because of the hard ice. U turn would have been impossible!
tsk1979 is offline   (3) Thanks Reply With Quote
Old 7th March 2014, 13:44   #20
Thanked: 216 Times
And how do you think Duster would have behaved provided it's FWD, with snow chains in the front. During my trip to Sikkim where I also encountered enough snow, I felt if I had Snow chains at that time I would have not stuck at any place.
gurha is offline   Reply With Quote
Old 7th March 2014, 14:22   #21
tsk1979's Avatar
Quite decent. Safari can do deeper snow due to higher average GC, but for normal snow you encounter, snow chains(or cables on FWD) would have been good enough for your trip.
For low clearance vehicles(low wheel clearance with components) snow cables are better as they do not foul brake lines etc., Thats why I used cables in front and chains in rear.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 7th March 2014, 14:38   #22
tsk1979's Avatar
Default Day 2 #7: To the pavilion
We spent some more time here
Clicking and clicking!
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_131600xl.jpg
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_131605xl.jpg
White white and all white
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_131608xl.jpg
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005844xl.jpg
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005845xl.jpg
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005847xl.jpg
Ahead down below is kothi
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005848xl.jpg
The snowfall takes a break
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005850xl.jpg
Even the sun makes a guest appearance
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005853xl.jpg
So we head down. We will venture up again
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005855xl.jpg
But for now its back to the parking... and fitting the cables on front tires
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_150459xl.jpg
The hotel staff have cleared the parking
And then this guy comes....
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_151643xl.jpg
Front tires have snow cables? Check
Rear tires have snow chains? Check
Did he just destroy one hour of snow clearing work done by the hotel staff? check
The road has snow? Nope
The snow cutter has exposed black tarmac.
Well.... lets look at the bright side. Maybe we can actually reach Gulaba...? Can we.....
tsk1979 is offline   (6) Thanks Reply With Quote
Old 7th March 2014, 16:51   #23
tsk1979's Avatar
Default Day 2 #8 : Up again... to GULABA!!!
I know what you are planning to do. I guess will just wait here, thanks but no thanks..Says the dog. I can even see the smirk on his face
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005860xl.jpg
So what are we planning to do?
Well its simple. With the snow cutter making a round, we are sure we are not going to be blocked a couple of hairpins away from the hydro plant. This time we can probably go all the way to Gulaba.
Yes Gulaba. The cliff jump point, where in season hundreds of tourists entrust their lives to totally untrained para-glider pilots. Lemme tell you the a secret. Even we have do it a couple of times. Scary stuff, I tell you.
Gulaba is also the point of the first of the major manali leh jams, due to haphazard parking. Some say, Manali Leh highway leading to Rohtang is too narrow, that is why we have jams. I saw, make it 8 lane, each side, and you will still have jams. Never underestimate the power of a haphazardly parked tourist vehicle.
In the core of a fission bomb atoms break, and then a chain reaction start. Same theory here. All you need is 1 or 2, and then its nuclear.
We start, and then stop. The RHS cable comes off. Damn. The inner fastner is not fastened properly.
The vehicle is at an odd angle getting out to the road from the parking lot. Looks like we need to reverse to the parking lot.
Krrrrrr the rear tire spins with its chains sparking on concrete of the parking lot, and the RHS front tire just spins silently on ice. Back and forth we manage to get up on the parking lot.
So what did we learn today? On hard concrete or stone, chains offer no grip. We also learn they spark. And we also learn they are very very tough.
So we park, put the cable on the ground, and drive onto it. Easier installation. After all tugs done, its time to move.
To Gulaba, where traffic jams last hours, and haphazard parking creates traffic meltdown.
But, for the first time that is not whats worrying me. Heck, that is not even in my thoughts.
What is worrying me is the god awful racket. Clack clack from the front. Clang clang clang from the rear.
Its deafening.
And its there because we are driving with snow chains and snow cables on hard black top tarmac.
The cutter has literally vacuumed the snow away.
Only the heavens can provide respite now.
Till then we decide to slowly proceed. Chains and cables can be used on hard roads at slow speed. Some say 30mph!. We are doing a measly 15mph, so it should be okay.
The weather is packed up, with clouds everywhere, but snowfall has not started yet. But altitude helps here. As we climb a few hairpins, the black tarmac gives away to hard ice. The snow cutter has removed the soft piled snow, but underneath the hard ice is unyielding, packed to solid rock by months of deep freeze
Then comes gulaba, and the black tarmac vanishes. There is a nice U turn point here, but the road ahead is doable.
With no chains, we would have been sliding and slipping on the ice, but this time, they just cut through, and we keep proceeding. We cross the hairpin, and are almost a km ahead of Gulaba, when we have to stop.
Guess what?
This is bulldozer clear zone. So there are ice blocks 3-4 feet in length lying all over the road. I get down, and kick some, but they do not budge. About 50 meters ahead I can see the snow bank which is about 4-5 feet high. Forget chains, even matt tracks are not going to help here.
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005862xl.jpg
So, we can take the U turn, and then take of chains to ride smoothly on cleared roads. But the Himalayas have other ideas, and it starts to snow. Really really heavily.
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_160537xl.jpg
Yay!
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-20140301_160541xl.jpg
But there is a problem.
You guessed it?
U turn.
Where to take a U turn. As you can see the road is barely wide enough for the safari.
So starts our long 300m reverse gear to find a spot, and we do find a spot. Deep snow.
After a 7 point turn. Yes, 7 times we had to go back and forth, we have the white elephant pointing downwards.
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005865xl.jpg
(Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway-d70005864xl.jpg
Its taken us 20 minutes for this entire circus. But we are pointing downwards.
Snowfall is getting heavy, so no more pesky black tarmac folks.
I decide to make a snow cable review video
Do I sound breathless? Oh yea. 3000m+, ice cold winds, and every breath saps you of energy. Manali Leh highway has never looked this beautiful.
The Himalayas are full of surprises, but I doubt we have gotten one so pleasant!
tsk1979 is offline   (18) Thanks Reply With Quote
Old 7th March 2014, 21:18   #24
HillyThar's Avatar
Thanked: 103 Times
Default Re: (Un)Chained Melody - 36 Hours of Snow, and the Manali Leh Highway
Very nice video and a greta trip, hope to see more soon as I have the same snow chains for my Thar (ordered from Amazon US), and used it to climb uphill 6kms in 2-3 ft of fresh snow.
HillyThar is offline   (1) Thanks Reply With Quote
Old 7th March 2014, 23:56   #25
Thanked: 32 Times
Very beautiful pictures and a great log. Truly inspiring. When i get a bit older and have my own car i'll definitely try this.
nigel92 is offline   Reply With Quote
Old 8th March 2014, 01:20   #26
blackbeast's Avatar
Thanked: 75 Times
Dude, Mr. Tsk, I wonder what'll happen to the travelogues forum on team-bhp if you quit writing here. You are the KING of Himalayan hills. If Sam Kapasi was covered by certain media for his Yeti blog, It is unfair you have gone unoticed unless you preferred it. There are two kinds of Tata safari in the country. First is yours and the second is what Tata makes for the rest of us.
Staying glued for the updates. Thank you for the joy you bring here.
blackbeast is offline   (1) Thanks Reply With Quote
Old 8th March 2014, 03:19   #27
Thanked: 15 Times
Default Maybe this could be the way to go for offroad extremists like us....food for thought!
Found out that some Crazy Yanks went and built this. But after I watched the Video of how this system works, gotta say...they're our kinda' crazy!!
They call it
'Track N Go'
Still think all that snow could stop us once we get our 4X4's kitted out with this?
saviouravenger is offline   (2) Thanks Reply With Quote
Old 8th March 2014, 19:15   #28
Thanked: 945 Times
Default Re: Maybe this could be the way to go for offroad extremists like us....food for thou
They call it
'Track N Go'
From what I know, vehicles with caterpillar tracks cant be driven on public roads.
And out of curiosity, how do you steer when you have these contraptions on?
Shreyans_Jain is offline   Reply With Quote
Old 8th March 2014, 20:42   #29
Thanked: 15 Times
That's the beauty of this concept. You lug these around in your boot or rooftop carrier whilst going to places with heavy snow fall or for OTR's. When you need them, simply place them in front of the tires & climb on using the two supplied loading ramps and lock the tires into place. Presto! You are now ready to decimate most types of terrain. No need to wait for the BRO snow cutters.
As per the manufacturer's website, they claim that on hard surfaces the vehicle can reach up to 60 kmph, while on snow speed varies from 15 to 40 kmph.
As for steering, they turn when you turn the tires. If you check the 'Track N Go' video on you tube, you will agree that they pose no problems unless you are trying to turn the tires whilst the vehicle is stationary - and most of us would agree that its best not turn the tires whilst the vehicle is stationary anyway.
Now if only I could get my hands on a Mercedes-Benz G63 AMG 6X6 & kit it out with this system......THAT would make one hell of a travelogue!
saviouravenger is offline   (4) Thanks Reply With Quote
Old 8th March 2014, 22:23   #30
tsk1979's Avatar
Uncleared sections of Rohtang entail about 40 feet high snow walls. Nothing can scale those. Forget track and go, even hard core matt tracks won't work there.
Infact, even snow cutters do not know where to cut. A very old veteran leads the way and tells the engineers how to cut.
Otherwise they can start cutting at a point where there is no road.
tsk1979 is offline   (2) Thanks Reply With Quote
Solo-Leh-Tude: Delhi – Manali – Leh – Srinagar in my Alto K10 spiritofmars Travelogues 45 17th December 2014 14:53
Review: Glacier PLC 1144 Snow chains and SCC ZT729 Snow cables tsk1979 4x4 Technical 5 6th March 2014 10:45
Finally Leh(ed) June 2011 : Delhi - Srinagar - Leh - Manali - Delhi v&v Travelogues 72 4th November 2013 16:06
Horsepower, resistance, melody and space dgupta Introduce yourself 5 20th July 2012 17:45
TIPS on ride to Manali - Leh Highway + Marsimek La from 60 KPH Red Bull Route / Travel Queries 1 5th December 2008 15:35
