Go Back   Team-BHP > Buckle Up > Travelogues
Old 23rd August 2010, 16:07   #76
MohsinRoadster's Avatar
Thanked: 28 Times
Nice Pics!!! keep them coming
MohsinRoadster is offline   Reply With Quote
Old 23rd August 2010, 16:11   #77
tsk1979's Avatar
Thanked: 16,420 Times
Its a very old travelogue, there are no new pics.
Old 24th August 2010, 18:30   #78
hridayjyoti's Avatar
Thanked: 56 Times
Climb from Narkanda side is easier, but when it rains, the pass gets very slushy. you will be doing it downhill, so not much issue. Be careful and very slow, and you won't scrape underbelly anywhere. I have almost gone till the top in the indica, and seen swift etc., do this pass.
Its currently raining very heavily in himachal, so if conditions dry out some, you can definitely attempt it, but remember, when its raining the area is landslide prone, and very dangerous, esp near Khanag etc.,
thanks, I will try to do it in mid sept, hope situation will be dry up by then. will keep a close look into the weather. I read your adventure with indica and the driving on reverse gear for 5kms.. salute you! I won't dare to do that.
hridayjyoti is offline   Reply With Quote
Old 25th August 2010, 10:55   #79
tsk1979's Avatar
I did not reverse for 5kms, only a hundred meters or so I think, before I found the turnout point.
Tirthan Valley A slice of divinity predatorwheelz Travelogues 20 22nd February 2017 22:18
Unforgettable Himachal: Shimla - Tirthan - Manali arindamray Travelogues 14 6th August 2013 09:12
Sojha (Shoja) & angling in the Tirthan river valley - Photologue abk Travelogues 15 11th June 2011 01:23
Truly Tranquil! Tirthan valley. lordofgondor Travelogues 16 16th February 2011 12:41
i20 Overheats | Engine Knocks | Coolant Boils and Flows Out tsk13 Technical Stuff 18 2nd February 2010 10:25
