Go Back   Team-BHP > Buckle Up > Travelogues
Old 23rd January 2012, 10:13   #16
Thanked: 1,172 Times
Default Re: Trip Log - Pune - Indore - Mandsaur - Bhopal - Pune
Originally Posted by root View Post
The only trouble is in the routes I took between Nashik and Pune (and I took two different routes, one using the Chakan Sangamner route which I believe is avoidable for vehicles with low ground clearance, and while returning via Mumbai and taking the Mumbai-Pune expressway which is a better option except while bypassing Mumbai and for some section of the Agra Highway before Nashik where 4 laning is still happening). Beyond Nashik this is a great road to Dhule, and beyond Dhule, till the MP border, the 4 laning is still happening in patches and you will need to slow down. Once you are across into MP, it is good all the way to Indore. Work is still on in the Indore bypass till almost Dewas. The Dewas bypass is 2 laned. Beyond this, the Dewas-Bhopal 4 laned highway is superb and is lovely to drive on.
Thank you.
Similar vehicles, similar concerns.
Yes, Pune Nasik is horrible these days and I once tried Kalamboli and it was even worse!
BTW, where did you stay overnight?
I am looking for decent hotel in Indore and Bhopal. You know any?
Thank you!
Originally Posted by hvkumar View Post
Pune-Nashik-Malegaon-Dhule-Sendhwa-Damnod-Indore-Dewas-Bhopal is the route to take.
If you are worried about heavy traffic n NH50 from Pune to Nashik, then take the route via Ahmednagar & Aurangabad to Dhule.
Petrol pumps - nothing specific to recommend.
HVK sir, thank you.
OK, so all clear beyond Nasik? That's good to know.
How is the road from Aurangabad to Dhule? Can I pass safely without scraping the ground?
And again, from your vast experience, any decent, clean not so expesive places to stay (Indore and Bhopal)?
Thank you once again.
anandpadhye is offline   Reply With Quote
Old 23rd January 2012, 10:28   #17
hvkumar's Avatar
Thanked: 3,365 Times
Originally Posted by anandpadhye View Post
HVK sir, thank you.
Yes, the roads are all fine including Aurangabad-Dhule-Indore.
Staying in Indore - lots of options, depending on your budget. Hotel Sreemaya is considered one of the better hotels.
hvkumar is offline   Reply With Quote
Old 23rd January 2012, 11:19   #18
mm403's Avatar
Thanked: 73 Times
I would suggest taking Pune - Nagar - Shirdi - Manmad - Malegaon -Dhule route.
Last week cousin of mine took this route took 12 hrs to reach Indore(in Wagon R) with around an hour lunch break. Bhopal would take another 3 hours from Indore.
Hotels in Bhopal -- Check in new bhopal area - Maharana Pratap Nagar has some decent ones.
mm403 is offline   Reply With Quote
Old 23rd January 2012, 12:31   #19
Thanked: 18 Times
Hi Anand
Not sure of the hotels in Bhopal as I have folks there. We stayed at the Radisson in Indore
Vijay
root is offline   Reply With Quote
Old 23rd January 2012, 17:42   #20
Thank you so much.
Will check out.
Delhi - Indore- Bhopal-Pachmarhi-Bandhavgarh-Orchha-Delhi manjir Route / Travel Queries 12 23rd May 2016 13:44
Bhopal-Ajanta-Ellora-Mahabaleshwar-Konkan-Shirdi-Bhopal columbus Route / Travel Queries 28 6th October 2015 17:30
Bhopal to Ajanta (via Indore/Dhule) route query vaibhav_a_a Route / Travel Queries 29 4th January 2014 14:08
