Go Back   Team-BHP > Buckle Up > Travelogues
Old 9th August 2010, 17:31   #286
tsk1979's Avatar
Thanked: 16,422 Times
Originally Posted by vardhan.harsh View Post
hey, the map looks nice, how did you export the gpx into jpgs automatically? or is it merging of different screenshots?
Harsh, I generated an oziexplorer map for the gpx. oziexplorer generation involves dumpung out a .map and jpeg file, and then converting it to CE format.
So after the first step,I just opened the file in GIMP and processed it.
Old 9th August 2010, 18:15   #287
Thanked: 13 Times
Hunder Diskit and Panamik are in the Nubra valley!
Oh my bad, do I have such a bad direction sense, anyways thanks TSK for clarifying
somu_john is offline   Reply With Quote
Old 13th August 2010, 22:06   #288
Thanked: 2,407 Times
I have created the scale accurate map. I have mapped sections with GPX available. Rest, I have not added anything.
A couple of suggestions and questions.
Give scale as xxx pixels per Km. This is because how the map will be reproduced is not known. Even if it is at 72 dpi (or whatever) quite a bit of extra calculation has to be done.
On your way to Kyun Tso, you took a detour, which you then trackbacked. This is also shown on the map, but can only lead to confusion.
Overlaid your tracks on your map. Could not find a few trackplots for a few tracks. These are shown in brown.
Sutripta
Ladakh and Changthang : The Wilderness Chronicles-tsk_jpg2trk.jpg
Old 17th August 2010, 11:19   #289
tsk1979's Avatar
Actually, these missing sections were mapped from satellite images, and some tracks I got from friends.
After mapping with satellite images, I verified the track I had mapped, and indeed, it was correct.
Sutripta
Can you also tell me how to convert to meters per pixel for this map.
I tried looking at level 12 zoom in OSM documentation, but it appears, for every latitude, you have to multiply with the cosine to get the actual number.
So different parts of the map would have difference meters per pixel ratio
Old 17th August 2010, 20:35   #290
Since we are trying to represent the surface of a sphere on a plane, we are going to have distortions. Distance, area, bearing, all are affected. We have different projections which will minimize/ eliminate one at the cost of others.
Our map uses what is known as geographic projection:- a fancy name for using Lat/ Long as x/ y in a Cartesian system. Obviously, the further from the equator, the more distances will be magnified.
The scale mentioned on a map is accurate only at one point. If it is a standard projection, one knows where.
In our case we have these options
a) use a GIS package to reproject, preferably to UTM
b) don't manipulate the map. Mention scale along a meridian
c) Compress the image along the x axis by a factor of Cos Phi, Phi being some appropriate latitude. Mention scale along that latitude.
Though c) will look more accurate, it will not be handled by any standard GIS package.
Easiest soln: Load the map in Ozi. Measure edge to edge vertical distance in both Km and pixels. Mention that. (4288 pixels for 270 Km)
Sutripta
Old 18th August 2010, 10:42   #291
tsk1979's Avatar
Thanks a ton suprita. I will start work on the map, and make it better.
I will also create a humongous GPX by stiching the maps together. So anybody wanting to do these sections can just load the GPX in their GPS and go!
Old 18th August 2010, 20:47   #292
BTW, Its Sutripta
Underlying maps:
The most interesting is overlaying the tracks on Google Terrain. Because of copyright reasons, you can't do it, but anyone can do it in his individual capacity.
Also, one can use the old AMS U502 maps, or the Soviet ones. No copyright issues with either. Maybe I'll do that over the weekend, and post it. However, those files will be large (over TBhps size limits)
Sutripta
Old 19th August 2010, 10:57   #293
tsk1979's Avatar
Sorry about the name typo
I am told I can also use open ariel maps. They are not as detailed as google earth, but are free to use.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 29th September 2010, 17:53   #294
Thanked: 28 Times
Hi Tanveer,
By any chance are you able to complete the stiching part. I am going over there, so it will be very usefule for me.
Thanks!
Alok
Crazy4Power is offline   Reply With Quote
Old 29th September 2010, 18:21   #295
tsk1979's Avatar
Not yet, however you can download my individual gpx files from OSM, and use them. They are tagged based on route and region
Old 17th February 2011, 12:26   #296
bornin70s's Avatar
Default Re: Ladakh and Changthang : The Wilderness Chronicles
I'm wondering how I missed this thread. Just amazed by these pictures. I still can't believe i'm going there this May. FOR A WHOLE MONTH
Its for a good cause. Re building homes in areas such as Wanla, Ursi, Achinathang, Hanu Yongma, Hanu Dolma, Dha, Biama, Skirbuchan, Thiksey, Igoo, Urla, Saspol, Bazgo, Ney, Likir, Tyakshi and others.
I wanted to know if these places are close to Leh. The thing is that I will be sponsoring the whole thing myself. And a month of stay/food/travel/misc might get a little too heavy on the pocket. Some pointer from people who have been there can be extremely helpful.
If someone has any idea about renting a place for a month of so then i would probably go for that. Another question is about these places i just mentioned. Would they be closer to Leh or are they far away places?
bornin70s is offline   Reply With Quote
Old 17th February 2011, 12:34   #297
tsk1979's Avatar
IO am glad you liked the T.log Borin.
Leh will be kind of your center point.
As for hotel stay, you get good hotels with car parking and hot water for around 600/month in the month of May.
If you do not require car parking etc., you can search for some nice guest houses for around 300INR.
Outside Leh, the villages have home stay options for 300/night or similar rates.
AS for renting, you should be able to rent a room in a guest house for around 3000/4000 for the entire month.
Get in touch with your local contacts.
What exactly is your budget.
Old 17th February 2011, 12:58   #298
bornin70s's Avatar
Thanks a ton!
Although my plans are definite, the contacts are very busy with other related work in Delhi. I couldn't get to talk to them much but was assured that they would make some arrangements. I just wasn't sure of the kind of place to stay.
My budget is around 20,000 for the whole month including stay. With around 5k for staying expenses. Would around 15k be enough for the rest of the necessities? I would still have around 10 to 15 k extra but I'm gonna make sure that I don't spend much cos I plan to donate the rest before leaving.
Another Q was whether I could get a detailed map of Ladakh District anywhere? Online or through a store in Delhi? I'm also planning to get a GPS phone. Probably like a Videocon V6200 (ducati). Would that be helpful?
Old 22nd February 2011, 19:08   #299
tsk1979's Avatar
Borin, you can look at Openstreetmap.org, I have mapped most of the region. This thread also has some maps from my GPS logs, however, all roads which are there, are mapped on OSM completely.
As for expenses, the biggest expense there can be food if you like to eat "fancy". Stick to small dhabas, or better still cook your own if you can, and you will be saving a lot of money.
If you are renting a place, spend aorund 500rs and get yourself a small cylinder or something with a single burner cooking gas. Saves a lot of money.
For reference, I am attaching a zoom level 10 PNG from Openstreetmap, you can download detailed maps of areas you are interested in
Ladakh and Changthang : The Wilderness Chronicles-map.png
Old 1st May 2011, 14:31   #300
Thanked: 30 Times
Would there be snow in mid May??
Shamsher is offline   Reply With Quote
Polo GT TDI Chronicles: Ladakh and beyond! 5543 km, 13 days, 8 states, 2 souls & 1 car! Gannu_1 Travelogues 76 4th May 2016 19:34
Self-Drive Expedition Travel-Ladakh and cold desert Changthang in "off-season" Oct 10 adc Travelogues 232 28th April 2013 12:48
The Ladakh Chronicles - 5 years of soul searching in the Himalayas! amolpol Travelogues 46 11th March 2013 22:41
Reflecting on Driving Addictions - Bangalore to Spiti and Changthang Coooolcat21 Travelogues 236 21st August 2012 15:25
