Old 19th May 2009, 04:42   #46
akshay4587's Avatar
Thanked: 1,686 Times
Originally Posted by MMY56 View Post
Is it possible to have radials on a premier padmini?
If yes, what will be the right size? and what brand will be best suited?
Yes you can
we have Bridgestone S248 155\80\R14 on it
Old 19th May 2009, 07:02   #47
Thanked: 49 Times
Originally Posted by akshay4587 View Post
Yes you can
What kind of wheel alignment schedules do you follow? And what kind of life do you get out of the birdgestone's? I usually go hunting for the cross ply tryes for the Premiers but its becoming a hassle.
CrackedHead is offline   Reply With Quote
Old 19th May 2009, 07:52   #48
akshay4587's Avatar
We have these tyres since year 2000 and they might have run only 10-15K kms now,as the car is used only 2-3 times a month now.
I am not sure of alignment schedules,as i havent driven the car since some time now,but it sure rides and handles well with those tyres.
You may need to check regarding availability of these also,as AFAIK bridgestone stopped making S248's in this size.
Old 20th May 2009, 18:24   #49
MMY56's Avatar
I tried looking for 155/80 R14, but I guess these are not being manufactured anymore.
A friend has recomended 165/80 R14..what will be the impact of putting these wider once on padmini? Also, should I go with tubeless once from JK tyres model Tornedo.
MMY56 is offline   Reply With Quote
Old 21st May 2009, 19:18   #50
Thanked: 716 Times
Go hunt for the skinny-looking JK 165/80-R14's that are ripped off the swift right out of the showroom. You get it for 900 bucks...
Whether tubetype or tubeless depends on the rim condition.
ramzsys is offline   Reply With Quote
Old 29th May 2009, 14:30   #51
MMY56's Avatar
I have heard that radials damage the suspenssion on the Padmin. Someone told me that the suspension was not designed to handle radials. Is that valid?
Old 10th June 2013, 12:41   #52
Default Re: Radial Tyres - Pros & Cons
Tell us what car you have..
Tell us what your budget is...
What your driving style is..
What kind of roads you drive on...
and what you want from a tyre the most (eg. high speed stability, comfort, braking, wet performance, insane grip levels, long life, etc)
cya
R
Hi Rehaan,
Am just about get hitched onto a Mahindra Quanto' & am a bit uneasy on the body roll part & sweering @ high speeds..Need ur suggestion
Tell us what your budget is - Not fixed as yet..
What your driving style is - City:Highway:Offroads = 60:30:10
What kind of roads you drive on - City:Highway:Offroads = 60:30:10
and what you want from a tyre the most - Stability (high speed), comfort, long life, & mileage conscious
Akky
Akky is offline   Reply With Quote
Leather Steering Cover - Pros & Cons mithun Modifications & Accessories 31 12th July 2016 19:23
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
BridgeStone Radial / J.K Radial ? nicejits Tyre & Alloy wheel Section 11 14th May 2008 12:43
Pros & Cons of low profile tyres? satish_appasani Tyre & Alloy wheel Section 16 17th September 2004 21:39
