Old 4th February 2009, 08:03   #466
vikram_d's Avatar
Thanked: 940 Times
The recommendations that are used for stock tyres are good enough for 195s' also.
Old 4th February 2009, 08:13   #467
DieselFan's Avatar
Thanked: 234 Times
Originally Posted by D1ISTHE1 View Post
Guys i just got a 195/60 15" on my new VD1 Swift. Was wondering what tyre pressure will be optimum.. ?
Manufacturer recommends 36 PSI in the front and 33 in the back for stock tyres on VDI. These pressures are too high for 195/60 15" tyres. You may want to use 31 PSI in the front and 28 in the rear for your tyres. If you use 36 and 33 the ride will be very bouncy and may affect your suspension.
DieselFan is offline   Reply With Quote
Old 4th February 2009, 12:19   #468
Fountainheader's Avatar
I follow the same 29 PSI for my ZXi shod with 195 alloys.
OT: How often do you guys check tyre pressure ? For normal city driving that is..
Fountainheader is offline   Reply With Quote
Old 4th February 2009, 12:33   #469
kpzen's Avatar
Thanked: 1,647 Times
Keep 30~32 psi for all four tires. Try both 30 & 32 psi, stick to whichever gives the optimum balance between ride quality and handling.
Once u feel that u have got the right pressure going then stick to the same place where u got the air filled from.. Changing places and machines also causes variation.
Old 4th February 2009, 13:47   #470
D1ISTHE1's Avatar
guys .. i live in SHIMLA and Chandigarh.. that is both hill driving and plains,, in plains while driving the car tends to understeer... in hills it makes a slight noise but not screech.. the tyre is accelare...i hate this tyre.. due to the alloy design the tyres jet out say about an inch.. how wud it affect the tyre wear..?
D1ISTHE1 is offline   Reply With Quote
Old 5th February 2009, 16:40   #471
Zahir's Avatar
Thanked: 28 Times
Very true... I just got mine upgraded to 185/70 and I use 34 in the front and 32 at the back... The fronts more obviously because of the heavier engine... good advice though dieselfan, the bounce will murder the suspension eventually...
Zahir is offline   Reply With Quote
Old 5th February 2009, 18:33   #472
SOUM's Avatar
For my Swift VDi, I stick to 31psi for front and 30psi for my rear tyres - Yoko 195/60/R15. Decent ride and fantastic road grip.
SOUM is offline   Reply With Quote
Old 5th February 2009, 22:09   #473
D1ISTHE1's Avatar
One more thing, does nitrogen help.. ? i did had all my tyres nitro-filled in the swift vxi i owned prior to this ride,i did not feel any significant difference in the ride.
Old 6th February 2009, 08:20   #474
vikram_d's Avatar
Thanked: 940 Times
The reason you did not feel any significant difference is because it does not make any significant difference.
For more information read through this thread - http://www.team-bhp.com/forum/techni...trogen-24.html (Inflating tyres with dry nitrogen)
Old 8th February 2009, 18:56   #475
Machine freak's Avatar
Thanked: 26 Times
can anyone tell me how 195/70/r14s would perform for swift. they are available in michilen xmi+.
Machine freak is offline   Reply With Quote
Old 8th February 2009, 21:39   #476
vikram_d's Avatar
Thanked: 940 Times
What is the stock size on your car? You can use the link below to calculate the difference.
Tire size calculator
Old 9th February 2009, 11:33   #477
Thanked: 26 Times
the stock tyre size is 165/80/14
new tyre size 195/70/14
below is what the site says.
i guess it ll fit.
but how good would it be performance wise? os if you suggest a different size than this then which one would be the best with a peted swift.
Old 9th February 2009, 12:50   #478
vikram_d's Avatar
Thanked: 940 Times
It is only a 1.5 % percent difference. This much difference is perfectly fine. Performance wise also 195 size will be better.
Old 9th February 2009, 13:05   #479
Thanked: 26 Times
and can i put this size on my stock rims...?
i dont wanna go for alloys.
Old 9th February 2009, 13:24   #480
vikram_d's Avatar
Thanked: 940 Times
For the stock rims I would not recommend any thing above 185. 195 will start to baloon outward too much. For 195 you will need wider rims.
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 85 7th March 2018 23:56
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 63 30th January 2018 11:40
Maruti Suzuki Alto : Tyre & wheel upgrade thread abhibh Tyre & Alloy wheel Section 361 24th October 2017 10:36
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 384 3rd June 2017 20:36
